Measuring Supplier Quality Performance
biggina
Hello all, new to this site, been viewing from afar and using the shared knowledge to assist us setting our company's quality objectives, measures and targets, it has been a tough few weeks!!
So we are collecting a lot of data but our system is not user friendly so we are having to do a lot of manual calculations, using spreadsheets, etc.
All has been going well until we hit a brick wall, supplier quality performance.
We want to score our suppliers on a monthly basis, the score is on delivery and quality.
Delivery is easy we have that sorted but we have hit a snag with quality performance especially with our sub contractors.
An example:-
In April supplier X delivered 2 line items in but we raised 9 NCR's against him. The reason being we inspected parts in April that were delivered in March or Feb.
So in essence when we send the performance figures out they are going to look rather odd!!
This is an ongoing problem because we dont inspect incoming parts instantly many a time they are inspected in the following month?
Anybody hit the same problem, and if so how did you resolve it?
Basically we are looking for a strong robust way of measuring supplier quality by analysing NCR's.
Many thanks
Tara Monson
Have you thought about doing a cumulative, running calculation? Instead of checking numbers my month, just keep a running total - but report that total at end of month. Use the trending of nonconformances (hopefully going down) as a way to assess your suppliers, not how many/month.
Just an idea!
Good luck!
biggina
Many thanks for the speedy response Tara, didn't expect feedback that quickly.
I follow what you mean, that is how our customers score us but how do I turn this months 9 NCR's for example into a percentage?
G
G_arion
With the way you inspect equipment some time after it is returned to you it seems the only sensible way of measuring it is to do assign NCRs to the relevant month. It does mean the monthly report you generate will have to show the entire year rather than just the month previous however.
I would say doing this cumulatively is the best option. Perhaps create a basic spreadsheet where you have a tab for each month with a list of suppliers, a list of items delivered for the relevant month and number of NCRs - that way you can back date things and keep a cumulative record.
The system we use relates to inspection upon delivery, so wouldn't be effective in terms of your requirements. Although as stated might be a more prudent system in any event.
silentrunning
Have you considered changing your incoming materials inspections process to be more timely?
That would benefit the company in more than one way. A supplier should be notified of an NC immediately. If not they may start running the next month's delivery and keep making the same mistake. You could run out of parts or receive a second delivery of NC parts. It would be far better if the supplier was notified of a NC in a timely fashion.
normzone
I've been down this road before, and here's my question.
If you do all this, what are you gaining from it?
If you can actually drive improvements in supplier performance, or reduce the trauma and drama in your production line by doing this, then there may be justification to go further down this road.
But often such concerns are driven by the perceived need to crunch the available data down to smaller and more timely bites. At the end of that road is a massive team of inspectors going through every piece of every lot of materials upon arrival and real time communications to the supplier.
Assess your organization's situation and figure out where the sweet spot is. Sometimes less is more. Some of the time spent crunching this data may be better invested in other projects.
Just my opinion, don't let me rain on your parade.
normzone has it spot on. don't worry about the time lag - work on solving the problems. Think about it this way - how does tagging the failure to a different month in the data change the actions you should be taking. We often issue NCRs/CARs fro failures that aren't detected until later in IQA, mfg or even the field. at some point we need to know what part range affected but this can be done ad hoc as needed. The reason for reporting the NCRs isn't to make pretty charts - its to fix the problems...
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
I Supplier Controls and Monitoring and Measuring ISO 13485:2016 - Medical Device Quality Management Systems 3
eule del ayre Clause 7.1.5 Monitoring and measuring resources IATF 16949 - Automotive Quality Systems Standard 11
armani Monitoring and measuring equipment for occupational health and safety purposes Occupational Health & Safety Management Standards 10
Q Class I Medical Device with measuring function (UK MDR 2002 / MDD) UK Medical Device Regulations 3
G Calc uncertainty of angle; by measuring x,y points Measurement Uncertainty (MU) 0
R Gage Measuring 15 Parts at a Time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A ISO 13485 Calibration Requirements- Assess and Record validity Previous measuring results ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 17025:2017 Clause 6.4 - Measuring Equipment Validity ISO 17025 related Discussions 2
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
S Classification of product (measuring or not?) CE Marking (Conformité Européene) / CB Scheme 5
D Measuring Radii Measurement Uncertainty (MU) 6
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 2
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
Cats Clause ISO 9001:2015 Monitoring and measuring resources. Application a service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
