Measuring the Profile of a Surface
Stijloor
#11
Why would the bore need to be involved. Datum -B- is the minor diameter of the spline. This establishes a datum axis.
The bore was an assumption on my part; more to be used as an example. However, the datum feature symbol -B- is not visible on the drawing that was attached... ;)
The center of the slot between the two larger tabs is the tertiary positioning reference. If the radius was manufactured in the wrong place, more than one of the dimensions relating to it would be out of tolerance. I'm still not sure the print doesn't contain enough information.
So I was not too far off track with my assumption of the tertiary datum feature... Again, the attached drawing did not show that either.
With the datums identified, and the basic dimensions provided, you should be able to produce the profile at the correct size and its correct location.
P.S.: Why did your drawing not show the datum feature symbols for the secondary and tertiary datums?
Best!
Stijloor.
H
Hodgepodge
#12
Best!
Stijloor.
I suppose I could have used the entire drawing in my attachment. I didn't because the point was to highlight what I believed to be the proper positional characteristics (unfortunately it was not a "stand alone" document). The OP's attachment has the full drawing in which you can see Datums -A- & -B-.
Although the print does not designate the center of slot with a datum status, I was thinking this is what must be used as a tertiary datum. Take a look and see if you agree.
Stijloor
#13
I agree!
Stijloor.
optomist1
A Sea of Statistics
#14
for those not yet up to speed (still learning studying for the exam) ; a full drawing or another drawing shot would sure help out.....
Thanks,
Marty :thanks:
Stijloor
#15
Thanks,
Marty :thanks:
Yes, I agree! A complete drawing is always helpful, but may not always be posted/attached because of confidentiality reasons. :nope:
Stijloor.
optomist1
A Sea of Statistics
#17
Hi Stijloor,
Boy oh boy I can't wait for 2009!!! In this case I am assuming this "clocking" jargon is used to address a Datum or other related positions along the perimeter or circumference of what appears to be a shaft/spline combo. From Hodgepodges entry, "The center of the slot between the two larger tabs is the tertiary positioning reference."
Are the subject tabs at approx. 10-11 or 2-3 o'clock?? Thanks for your help.....
Regards,
Studying on a holiday weekend for my exam - Marty
optomist1
A Sea of Statistics
#20
Thanks Hodgepodge,
this is very good example/helpful instruction for a newbee!!!!
Regards,
Marty
M Measuring a circle's profile Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
P Tool for Measuring - Do I have to do more than one Gage R&R for the PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
A Monitoring and Measuring Resources (7.1.5) - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
