Measuring the progress of Continuous Improvement Program - Methods and Criteria used?
JBAND
Has anyone attempted to measure the progress of CI programme? If so what was the method and criteria you used?
harry
Re: Measuring the progress of Continuous Improvement Program - Methods and Criteria u
Welcome,
A Gantt Chart for tracking planned versus actual progress and reporting/indicating percentage ahead or behind planned progress should be useful in most circumstances.
Kales Veggie
People: The Vital Few
The results of the projects that are part of the CI programme should drive your plant performance metrics (scrap, uptime, ppm, ontime delivery, cycle time). The metrics should show a positive trend if the CI programme is effective. If not, you will have to look into the reasons why and augment your CI programme. (Why continue a project, if we do not see and/or can nt measure the benefits).
bobdoering
Stop X-bar/R Madness!!
For precision machining the correct way to evaluate continuous improvement is to attempt to reduce the slope of tool wear, as shown in the X hi/lo-R charting methodology. This represents slower tool wear rate and fewer operator adjustments. Compressing the control limits - often the result of incorrectly using the X-bar-R chart - will only create more operator intervention and adjustment, or classic overcontrol.
For more information see: Statistical process control for precision machining
Citizen Kane
Hi !
I think the measurement comes from the target you defined. You coul associate some actions to the progress.
This is a measure of definition. We do this also in our location.
AdamP
I have a similar question with respect to rolling out an enterprise wide improvement program (think Lean here). We have had good discussion on how best to measure and report on the overall program and have converged on using the business metrics (KPIs), rather than program metrics such as # of people trained, etc.
However, we are looking for a good indicator of employee engagement. So far we have "# of kaizen suggestions per employee per month" on the basis that if they are making suggestions, they are engaged.
Does anyone have a good/great way to measure this aspect of a program? Any help is appreciated.
Cheers,
Adam
N
ngkjrs
I do agree that we need to focus on process and results follow. A day-to-day monitoring of the parameters like OEE, SMED, AM steps activities, 5S score-card and making them visible for all in the facility would boost this.
Gopalakrishnan
Q Measuring Monthly Progress in Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Measuring Radii Measurement Uncertainty (MU) 4
J Register of the monitoring and measuring equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 2
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
P Tool for Measuring - Do I have to do more than one Gage R&R for the PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
