Measuring the True Position of a Cylinder's Pierce Point
Mr. Friend
Hi Friends,
I'm pretty good with GD&T (1994 & 2009), but wish to verify something before acting.
I'm interested in measuring the actual position of a pierce point (i.e., "Point G") of a cylinder axis intersecting a plane. This point is given three locating Basic dimensions: one in Z, one in X, and one in Y. I typically would discover the deviations from the print's true position and input them into the formula 2SQRT(x^2+y^2) to get the actual. But here, we have a third Basic. How would I measure a pierce point's true position?
I would be so grateful for any help on this.
Mr. Friend
Ok. I have sketched a drawing of my own (see attached). Please take a look.
The sectional view is drawn at the wrong angle, but this shouldn't disrupt our inquiry.
Michael_M
This will be measured the same as normal true position. The pierce point is telling 'where' to specifically measure the cylinder at. The GD&T frame is calling A B C.
Think of it this way: you have a cylinder, we will project the cylinder to be 20 inches long (or miles for extreme effect). Lets say the pierce point is called out to be at the exact center, the end points of the cylinder usually are required to fit within the GD&T but at 20 inches (miles) long any angle deviation from perfection will probably fail because of the high length, In these cases, I usually see another call out for cylindricity call out, or another GD&T call out, independent of the measurement at the pierce point.
David DeLong
You do not measure a point but you do measure the feature which in this case is two holes which share the same center. The basic dimensions to point G develop the axis in which the two holes lie. So, there should be a positional tolerance with a diametrical tolerance zone for the two hole having a location shown with point G with a basic angle.
Mr. Friend
Thanks guys. Your input is much appreciated.
Unless new insights arise, I will proceed with interpreting this positioning as being a position requirement for the cylinder at Point G's location only (the point G itself not having anything to do with being toleranced with a sperical tolerance zone, halting translation of the cylinder along the 18 degree axis, etc.). Point G merely designates a point where the Basic axis exists, and at 18 degrees. This means the cylinder may translate for infinity up and down the axis, as long as the cylinder's axis does not violate the .010" (plus bonus tolerance) cylindrical tolerance zone existing around the center of the 18 degree Basic Axis.
Using a cmm, people had been constructing a pierce point out of the intersection of the cylinder's axis with the Flange's face, and testing its distance from Point G's location using a spherical tolerance zone.
Instead, we'll merely translate our origin to Point G, and take several hits around the inside of the Flange's hole to see if the hole's center violates the diametrical tolerance zone at that point. I should also do the same with the back of the cylinder (2nd flange) in order to prove that this cylinder as a whole does not violate the tolerance zone.
Thanks again, guys!
Q Measuring the True Density of Spheres in a Container Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
R Tools used for measuring (New to metrology) General Measurement Device and Calibration Topics 9
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R ULM Measuring Pressures General Measurement Device and Calibration Topics 1
M Missing measuring equipment General Measurement Device and Calibration Topics 6
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
V Ammeter calibration - Measuring head (on pic.) problem General Measurement Device and Calibration Topics 1
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
G Posting Measuring Equipment Accuracy for User Information General Measurement Device and Calibration Topics 4
S ISO 9001 7.1.5.2 - Actions Taken When Measuring Equipment is Found to be Unfit for Use General Measurement Device and Calibration Topics 13
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
G Measuring customer parts on a CMM - How many decimals to report to the customer? ISO 17025 related Discussions 28
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
U Measuring a Golf Club Face/Grip/Shaft Rotation General Measurement Device and Calibration Topics 7
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
H Measuring Design Process Design and Development of Products and Processes 4
C AS9100D 7.1.5.2 / Calibration of Employee Owned Measuring Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Effectiveness Measuring and Efficiency Measuring In ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
johnny johnson New measuring equipment selection (Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
S IOQ protocol for a Micro-Vu measuring system - Is a PQ required? Qualification and Validation (including 21 CFR Part 11) 2
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
L Radius Measuring Tools General Measurement Device and Calibration Topics 4
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
Claes Gefvenberg Worst measuring equipment ever? Coffee Break and Water Cooler Discussions 6
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
P Tool for Measuring - Do I have to do more than one Gage R&R for the PPAP? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
A Monitoring and Measuring Resources (7.1.5) - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
