Mechanical Test Under FDA Freedom of Information Act
Good Morning everybody,
I need to request some mechanical test results to make a side-by-side comparison between a predicate device and my subject device which I'm seeking clearance through a 510(k).
The doubt is if this kind of information could be released under a FOI request or not? If not, how would I know if the predicate mechanical properties are equivalent my subject device?
yodon
Even if so, it may take months to get it.
*Sometimes* if you go to the device product code on the FDA site, you can see the relevant standards. Sometimes test labs can identify appropriate tests. I hear presubs are getting hard to come by but if you can arrange one and propose your testing strategy, they may indicate where it falls short.
pziemlewicz
Depending on device type the easiest route is usually to order one and test the two side-by-side. If there is specific materials info you're looking for, you can send the predicate to a lab for analysis.
FOIA takes forever and device-specific test data is very often redacted.
Thanks for the answer!
So, maybe I can send my test results in a Pre-Sub and ask to FDA if it is equivalent to the identified predicate? So they can compare? Is that right?
Thank you for the attention, but in our case, it is not feasible to buy a predicate component to make the tests.
R Standard for Reliability/Performance Test on a Electro Mechanical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S Medical Device Mechanical Test Method Validation Design and Development of Products and Processes 8
R BOMs & Test Procedures - Electronic and electro-mechanical systems Document Control Systems, Procedures, Forms and Templates 4
C Mechanical Aptitude Test needed Training - Internal, External, Online and Distance Learning 14
P Destructive Test MSA's - Mechanical properties of adhesives Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Strange Juan HP 85054B Standard Mechanical Calibration Kit Calibration Procedure General Measurement Device and Calibration Topics 1
G Pricing Structure for Physical Mechanical Testing of Labs Manufacturing and Related Processes 1
J Defining staff competence - Small mechanical workshop Occupational Health & Safety Management Standards 20
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
J GLP accreditation for mechanical tests of medical device? Other Medical Device and Orthopedic Related Topics 1
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
shimonv Design input/output traceability for mechanical parts ISO 13485:2016 - Medical Device Quality Management Systems 31
R Essential Performance of Mechanical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
J Mechanical Press Machine Foundation Requirements and Recomendations Manufacturing and Related Processes 2
G Senior Project for BS Mechanical Engineering Student Career and Occupation Discussions 4
M Mechanical Testing for Orthopaedic Implants for CE Marking EU Medical Device Regulations 2
A Auditor's certificate for newly employed graduate? (Mechanical Engineer) Professional Certifications and Degrees 1
T Measurement of uncertainty for standard mechanical properties General Measurement Device and Calibration Topics 1
alonFAI Mechanical Drawing Version Change Document Control Systems, Procedures, Forms and Templates 8
N Need Calibration Service for Mechanical Tester - Zwick Roell General Measurement Device and Calibration Topics 1
D Contract Manufacturer & Mechanical Assembly Supplier Warranty Liability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Mechanical Tubing Mill Tolerance Reference Manufacturing and Related Processes 5
S Mechanical/Electrical Forces Gage Calibration Methods Calibration and Metrology Software and Hardware 1
W Seeking a Freelance Mechanical Inspector - Source Inspection in Bangalore, India AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Uriel Alejandro Trouble with a Mechanical Design Technical Verification Check List AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Mechanical Auto Repair Shop requires ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Fastener Manufacturing Research - Mechanical and Engineering Theories Manufacturing and Related Processes 3
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Failure Analysis Procedure for Electro-Mechanical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A HSE Regulations and Legislation for Design of Mechanical Wind Turbine Components Miscellaneous Environmental Standards and EMS Related Discussions 4
P Dimensional Mechanical Inspection only as a Service - ISO17025 or ISO17020 ISO 17025 related Discussions 5
somashekar Insight about Air Changes per hour (ACH) in Mechanical Ventillation Occupational Health & Safety Management Standards 2
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
J FAA Requirements for Design and Manufacturers of Engine Turbine Mechanical Components Federal Aviation Administration (FAA) Standards and Requirements 2
D Material Handling, Storage & Preservation Procedure for Aerospace Mechanical Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R Inspection Humidity Control - Range for Mechanical Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
V Mechanical Testing Lab - PT vs. QC questions General Measurement Device and Calibration Topics 4
P Calibration Standard - Rules of Calibration for Mechanical Comparators General Measurement Device and Calibration Topics 3
N Help please - Mechanical Latch Design Principles? Design and Development of Products and Processes 2
Q REACH Declaration requirements for Mechanical Components RoHS, REACH, ELV, IMDS and Restricted Substances 6
V PPAP for electronics - What do we have to require for PCB compare to mechanical parts APQP and PPAP 4
V Letter of Guarantee - EN 12546-3 (Mechanical & Physical testing on an ice pack) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Mechanical Maintenance Procedures for Oil & Gas wanted Document Control Systems, Procedures, Forms and Templates 4
ScottK National Pipe Straight Mechanical (NPSM) Specification? Various Other Specifications, Standards, and related Requirements 6
A How to Search for Jobs Abroad - Mechanical Engineering Field Career and Occupation Discussions 3
D Can an Electrical Design Engineer audit the work of a Mechanical Design Engineer? Design and Development of Products and Processes 6
