MEDDEV guideline on Post Market Surveillance (PMS)
N
novemberbirthed
Based on MEDDEV 2.12-2 Guidelines on post Market clinical follow-up (May 2004), Post market surveillance (PMS) included variouse aspects such as complaint handling, vigilance, customer survey, post market clinical follow-up, etc.
In the recent revision (MEDDEV 2.12/2 rev2) published on January 2012, post-market clinical follow-up STUDIES have been explained, which will be used to update the clinical evaluation report periodically without any mentioning of customer feedback, etc.
1. Is there any other guideline that currently explains the PMS plan strategies/procedures?
2. Does it mean that clinical evaluaion report alone is enough to adress post market surveillance reporting, or a post market serveillance reprt is separetely needed? It seems to me that they both cover the same thing..
Y
yana prus
http://www.meddev.info/_documents/R2_12-1_rev11.pdf
Clinical Evaluation report is part of PMS, and separate PMS report is needed. The purpose of them is different: a manufacturer?s postmarket surveillance system is often, but not exclusively, the source of information on vigilance and risk assessment according to Vigilance MEDDEV, while the purpose of the clinical evaluation in the post marketing stage according to MEDDEV 2.7.1 is "periodically review performance, safety and the benefitrisk assessment for the device through a clinical evaluation, and update the clinical evidence accordingly. This ongoing clinical evaluation process should allow manufacturers to communicate with conformity assessment bodies and Regulatory Authorities in accordance with local reporting requirements, any information that has an important bearing on the benefit-risk assessment of the device or that would indicate a need for labelling changes regarding contraindications, warnings, precautions or instructions for use etc."
N
novemberbirthed
Thank you Yana.
As you mentioned, based on MEDDEV 2.7.1, you need a clinical evaluation report that has to be updated on regular basis based on clinical post-market studies, and outcomes of PMS (or so called clinical experience). This has to be a "stand alone" document.
On the other hand based on 2.12, you need a PMS report that includes clinical evaluation..
It just seems to me redundant to have both documents as their contents are more or less similar (?). Don't you think?
red66climb
If you read through the 2012 guidance on PMCF Studies you will realize that these studies resemble more formal retrospective clinical studies to address long-term follow-up and usability by larger user populations. PMS is much broader in scope. The PMS plan is already required in a Dossier, but PMCF protocols and reports are anticipated new requirements in the recast regs. BSI published a white paper on PMCF but it will be more important to see how Annex X1.1c is manifested in the new articles and annexes. High risk products might be subject to more specific requirements.
CBAL08
There are terms like
Post production clinical follow up
Post market clinical follow up
Post market surveillence
I am finding it really difficult to understand all these terms and the process to have in place ( Standrad Procedure).
Is it that Post marketing surveillance is conducted 2 time/ or say one time a year taking into account all complaints, feedbacks from users, experts,services and evaluated. Then the evaluation is fed to Risk managemnet process???
Would really appreciate your help in making me undersatnd all these. Plus would really appreciate if there were example/ sample of these reports and Procedures.
E
edgar123
Rather than "Post production clinical follow up" which I think is only present in the GHTF documentation the directive refers to "post-production phase" during which experience gained from devices must be collected.
This concept of post-production phase includes both PMS and PMCF.
That considered, you would have to conduct the following:
- Perform the PMS on a regular basis (complaints, AER, CAPA, impact on risk management). This is done case by case and through trending.
- Perform the PCMF as per plan (say once a year).
The PCMF would not only take clinical data updates into account but also PMS report as an input. That way a decision can be taken based on both inputs regarding the suitability of the product in comparison with the state of the art.
Hoping this helps a bit...
CBAL08
Thank you for the clarification. However does this Post Market( Production) clinical follow up be done annually for each devices?
Or should it be a part of Post Marketing Surveillence ( Annually)
STill confused.
As such we do look at the complaints, Non conformities.....and update Risk management however do not have a formal way of doing this PMCF ( PPCF?)
E
edgar123
The PMCF would be addressing each category of device depending on the clinical application claimed, and once a year is usually sufficient considering the evolutions of the clinical applications.
Even though complaints are analyzed and risk management updated if required continuously, the occurrence has to be re-assessed for instance based on trending. Hence the annual PMS.
Then the PMCF takes it into account from the clinical specialist point of view (suitability of the intended use, user documentation...).
I guess the frequency of both PMS and PMCF has to be assessed based on the benefit-risk ratio and residual risk, and I don't see why both could not be conducted at the same time provided that there is a clear distinction between them.
My 2 cents on a Friday evening
CBAL08
Anyone to help me with what PMCF plan looks like? Main points that the PMCF plan should have. Same thing with PMS plan. The more I read the more it gtes confused as all the things are leading to one thing how to get feedback on use/ safety of product and how is it fed through the system . How is risk analysis updated by these reports and so on. Need some guidlines from gurus on how can we do it the best and simple way for low risk devices.
N New MEDDEV 2.7/3 Guideline: Clinical Investigations: Serious Adverse Event Reporting EU Medical Device Regulations 4
T The “use-by“ time limit - Terminology discrepancy - MEDDEV & HS EU Medical Device Regulations 0
K Measuring Function MEDDEV 2.1/5 relation with MDD 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 1
Y When will Notified Bodies require MedDev manufacturers to fully implement ISO 14971:2019? ISO 14971 - Medical Device Risk Management 1
F MEDDEV 2.7/1 rev 4 and MDR - Definition of Description of Principles of operation EU Medical Device Regulations 4
E Can we still use MEDDEV 2.4/1 rev. 9 when classifying a medical device product under MDR? EU Medical Device Regulations 4
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
L I'm looking for Translation Procedure Guide MEDDEV 2.5/5 Rev.2 (NOT Rev.3) CE Marking (Conformité Européene) / CB Scheme 0
dgrainger Informational Additional Guidance Regarding the Vigilance System as outlined in MEDDEV 2.12-1 rev. 8 EU Medical Device Regulations 1
J MEDDEV 2.12/1's new MIR & IMDRF terms & codes (IMDRF Annex) EU Medical Device Regulations 1
Ronen E Informational The future of MEDDEV 2.7/1 EU Medical Device Regulations 4
M CEP requirements in MEDDEV 2.7/1, rev 4 and MDR - Are all MEDDEV requirements still applicable? EU Medical Device Regulations 7
K MEDDEV 2.4/1 rev. 9 Classification EU Medical Device Regulations 1
TheMightyWife Clinical Evaluation MEDDEV 2.7.1 Rev 4 demonstration of equivalence EU Medical Device Regulations 6
J CER - Literature search strategy and PMV data Timeline - MEDDEV 2.7.1/ Rev 4 CE Marking (Conformité Européene) / CB Scheme 2
S Gap Analysis MDR req/MEDDEV 2.7.1 rev 4 EU Medical Device Regulations 3
H CER - Equivalent Medical Devices Criteria - MDR/MEDDEV REV 4 CE Marking (Conformité Européene) / CB Scheme 9
R Clinical evaluation Meddev (2.7.1 revision 4) - Example or Template EU Medical Device Regulations 4
M Clinical Evaluation - MEDDEV 2.7/1 rev4 - Literature route Other Medical Device Related Standards 2
C Qualification of Evaluator - Clinical Evaluation Report MEDDEV 2.7.1 Rev 04 CE Marking (Conformité Européene) / CB Scheme 3
T MEDDEV 2.7/1 r4 vs. IMDRF/SaMD WG/N41 Other Medical Device Related Standards 3
P Label Translations - Translation procedure to meet the requirements of MEDDEV 2.5/5 ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Sample of the MEDDEV 2.7.1 rev 4 Clinical Evaluation Report wanted Document Control Systems, Procedures, Forms and Templates 18
Sam Lazzara Clinical Evaluation MEDDEV Guidelines SmackDown - 2017 EU Medical Device Regulations 3
R Qualification of Evaluator - Clinical Evaluation Report MEDDEV 2.7.1 Rev 04 Other Medical Device and Orthopedic Related Topics 1
E CER (Clinical Evaluation Report) MEDDEV Version 4 Template wanted CE Marking (Conformité Européene) / CB Scheme 5
R Clinical Evaluation according to MEDDEV 2.7.1 (Rev 4) - seeking template ISO 13485:2016 - Medical Device Quality Management Systems 6
K MEDDEV 2.7/1 Rev 4 Appendix - A11 - Declarations of Interests EU Medical Device Regulations 2
R Non-Conformity Report from Notified Body - MEDDEV Guide is not Legally Binding EU Medical Device Regulations 16
F MEDDEV 2.7/1 rev 4 - Clinical Performance & Clinical Safety Claims EU Medical Device Regulations 3
E Gap Analysis between MEDDEV 2.7/1 rev.4 vs. rev.3 wanted EU Medical Device Regulations 3
J Where to get meddev FSCA (Field Safety Corrective Actions) trainings EU Medical Device Regulations 7
M MEDDEV 2.7/1 rev.4 published - June 2016 EU Medical Device Regulations 42
Y Transition Period for MEDDEV 2.7.1 EU Medical Device Regulations 8
C MEDDEV equivalent requirement to CFR 806.20 EU Medical Device Regulations 2
J Good training or seminars to attend for MEDDEV 2.12-1 recommendations wanted EU Medical Device Regulations 3
S NB-MED, NBOG, IMDRF and MEDDEV hierarchy EU Medical Device Regulations 3
M Australian Meddev Regulations Updated 5 Nov 2014 Other Medical Device Regulations World-Wide 0
B Inquiry about MEDDEV 2.12/2 rev2 - PMCF studies EU Medical Device Regulations 3
S Revised MEDDEV 2.12-1 rev 8 Vigilance System - Released EU Medical Device Regulations 3
D Vigilance Trend reporting requirements of Meddev 2.12/ver 7 in the EU Document Control Systems, Procedures, Forms and Templates 1
bio_subbu EU publishes revised guidance on Medical Devices Vigilance system MEDDEV 2.12-1 Rev7 EU Medical Device Regulations 8
bio_subbu EU publishes several new & Revised MEDDEV guidance documents (FEB 2012) EU Medical Device Regulations 0
W MEDDEV: Qualification and Classification of Stand Alone Software Published EU Medical Device Regulations 4
A Procedure for Translating User Documentation to comply with MEDDEV 2.5/5 Other Medical Device Regulations World-Wide 14
bio_subbu New MEDDEV Guidance Documents - Clinical investigations and SAE Reporting EU Medical Device Regulations 3
M MEDDEV 2.12.1 rev 6 Trending of Non-Reportable Events question ISO 13485:2016 - Medical Device Quality Management Systems 4
bio_subbu European Medical Devices Classification ?MEDDEV 2. 4/1 Rev. 9 June 2010? ISO 13485:2016 - Medical Device Quality Management Systems 5
B What is the most recent version of MEDDEV 2.4/1 rev8 ISO 13485:2016 - Medical Device Quality Management Systems 6
T Vigilance System MEDDEV 2009 changes - MEDDEV 2.12-1 rev 6 for Vigilance System EU Medical Device Regulations 1
