Sam Lazzara
The proposed FDA regulations regarding UDI (Unique Device Identification) mentions GS1 and HIBCC data technology as acceptable alternatives.
The rule will establish a UDI system that requires manufacturers to include both a plain-text version of the identifying data and a version encoded using Automatic Identification Data Capture (AIDC) technology such as linear/two-dimensional bar codes, RFID tags, etc.
What are the pros and cons surrounding GS1 and HIBC barcode systems?
I have more experience with GS1-128 barcode symbology than the corresponding HIBC. Here are some of my ideas (which could be wrong) from my limited experience. Am I right, am I wrong? Any other input.
1. GS1 barcodes are in a pure numerical format. No alphabetical letter characters are permitted. Many companies have alpha-numeric item/catalog (REF) codes with numerous digits. The HIBC format appears to allow the actual catalog number (alpha, numeric or alpha-numeric) to be directly encoded and in the readable text.
2. For GS1 format, the digits available for the item/catalog (REF) code can be as few as 3 numerical digits depending on how you answer some questions. Maybe you can have 5 numerical digits if you answer "correctly" - saying you have more than 999 items. This seems to require the company to maintain a cross-reference between the barcode item number and the actual item number. Is this what companies do? Then the supply chain customers must have this cross-reference so their databases work properly? Note - HIBC does not appear to have a limit for the number of digits, and alphanumeric characters are permitted.
3. Just looking at "128" symbology, the GS1 format is a single barcode, and it takes up less space than the corresponding HIBC barcode which is actually 2 separate barcodes - one with company identifier and item code, and the second with lot/serial number and use-by-date. Does HIBC have a condensed (single bar) format?
Some Questions
- What are the direct cost differences for company's choosing between GS1 and HIBC? By direct costs, I mean start-up and annual fees due to GS1 or HIBCC to get/maintain company identification code.
- It appears that the upcoming FDA regulation will allow either symbology, but on a worldwide basis, is GS1 the "best" solution?
- Might some companies end up using both symbologies?
- What is up with the 2D "QR" symbology? Can that be a good way to go?
- How are implant manufacturers going to identify implants that are very small? What symbology works best for bone screws and the like? Can microscopic barcodes be read economically? Is it expected that the barcode will be readable after implantation? Yikes!!!
Some Questions
