Our major principle has fixed the GS1 and we are all gearing up to implement in Sept 2016...
Thanks Edward, the customer wants HIBC strip code only on the packaging to scan it at the reception, so i can only register with the GS1 code.I will assume the US market as this is what I am familiar with. When you register the device with GUDID, there is a drop down menu that allows you to select the UDI type you are using (GS1, HIBCC or the other one for blood products). The whole point of this system is traceability. Because of the way the system us set up, I don't see how you can register the same product with two different systems. You may want to ask the GUDID info center for a definitive answer.
The whole system is for traceability, so I might suggest that you verify that the customer will be able to maintain records of all product locations in the event that you or one of your parts supplier initiates a recall. This could also be used as part of your QMS audit regarding traceability (I always use a critical supplier initiating a recall whenever I perform my internal audits, as this tests our system both upstream and downstream of our company).Hello all, i have a strange situation here, we are using GS1 Data matrix, but a customer wants HIBC Code 128 only on the packaging, can i use both codes, GS1 and HIBC on the same label? to avoid 2 kind of labels for the same product thanks
Edward, thank you for the hint. i know that this is for the traceability, but my question is more related to if we can apply both HIBC and GS1 code on the packaging label, is there any rule, directive, regulation in the EU or US against that? i know that this is a very strange question, but we have just introduced GS1 data matrix, now there is new customer in the US who is requesting HIBC. So we have now a few products where we need to use HIBC, so would not start again from the beginning to change everything to HIBC. Just apply the 2 types of codes on the packaging labels for the few products which are sold in the US and also in the EU.The whole system is for traceability, so I might suggest that you verify that the customer will be able to maintain records of all product locations in the event that you or one of your parts supplier initiates a recall. This could also be used as part of your QMS audit regarding traceability (I always use a critical supplier initiating a recall whenever I perform my internal audits, as this tests our system both upstream and downstream of our company).
