sankui
Dear all,
There is an issue related to ME classification. The equipment is powered by inside rechargeable battery and can not operate normally while charging by a CLASS II battery charger.
According to clause 14.5b), INTERNALLY POWERED EQUIPMENT having a means of connection to a SUPPLY MAINS shall comply with the requirements for CLASS I or CLASS II EQUIPMENT while so connected, and with the requirements for INTERNALLY POWERED EQUIPMENT while not so connected. From this point of view, it seems our equipment shall be classified as CLASS II and INTERNALLY POWERED EQUIPMENT. If so, CLASS II symbol shall be shown on the lable of equipment. Do you think it is necessary?
But the rationale of sub-clause 14.5b) states that these requirements do not apply to EQUIPMENT (including any separate power supply unit or battery charger) which is incapable of being connected to a SUPPLY MAINS and to a PATIENT simultaneously. From this point, it seems that our equipment shall only be classified as INTERNALLY POWERED EQUIPMENT because the equipment can not operate while charging. That is to say, it is not possible to connect SUPPLY MAINS and PATIENT simultaneously.
This question is not complicated, but I am a little confused. Please kindly advise it.
Thanks and regards
Thanks and regards
