Medical Device Intended Use Document - Risk Analysis Documentation Requirements
V
vishal.cpdm
During a casual discussion about risk analysis documentation I was advised to freeze on a intended use document as a first step for the ME device we will be developing.
Clause 4.2 in the ISO14971 document says, "For the particular medical device being considered, the manufacturer shall document the intended use and reasonably foreseeable misuse. The manufacturer shall identify and document those qualitative and quantitative characteristics that could affect the safety of the medical device and, where appropriate, their defined limits."
It would be greatly appreciated if someone can please help me or advise me further with a sample intended use document so that I can get an idea of how to document this (in terms of its structure, content titles, etc.).
Thanks in advance.
Vishal.
yodon
We don't create a separate intended use document, just a statement (paragraph or so) on intended use. That's generally propagated throughout various documents.
Certainly you need to have a common understanding of intended use to ensure the review is properly focused.
Things to consider when establishing your intended use (just winging it here - maybe someone can fill in with a more comprehensive list): level of expertise of operator (does the operator need to be trained), type of patient (children, adults, seniors, etc.), environment the device will be used in (indoors, OR, outdoors, etc.), and so on. Of course, you need to also identify what the device does (what condition are you treating / action are you performing, etc.).
The intended use goes well beyond supporting a risk assessment; you will need to be able to substantiate any claims you make in the intended use so wordsmith wisely. Input from a regulatory consultant / expertise is recommended.
V
vishal.cpdm
Thank you Yodon! That is a good insight. :agree1:
And yes, the point about being wise about intended use claims is noted! :)
If I understand well, (sorry if i'm being dumb) all the points mentioned should be covered in the paragraph/statement itself? Shouldn't it be under separate headers (like intended use, contraindications, stakeholders, description, operating parameters, etc.)? Please advise and clarify.
Many thanks!
Vishal.
yodon
First off, you're not being dumb. We all had to go through the learning curve.
Second, it sounds like you're getting a good handle on the documentation. The intended use is typically just a few paragraphs focusing on what the device treats. I mentioned stakeholders because it's sometimes necessary to frame the intended use; e.g., a trained clinician will operate an ultrasound device for detecting tumors. Contraindications, description, stakeholders, and operating parameters are generally covered in the IFU.
V
vishal.cpdm
Thanks Yodon and Ronen! :agree1: Thank you for your advice, help and encouragement!
This brief discussion has been very helpful. :thanx:
Marcelo
The importance of intended use in ISO 14971 is really not clear stated, in my opinion. Besides being the basis for the regulatory compliance process as Ronen mentioned, it´s really the base for all risk management activities.
Most of the time people ask me why risk management is focused in thinking about anything that can happen to a medical device, so it´s a pointless activity. I answer that if your device can be used for anyone, by anyone, everywhere, you really need to risk manage the entire world. However, if you have a clear definition of patient, user, use environment, and other factors, you really need to manage those situations (which might be many, but not the entire world).
Standards speaking, intended use for medical devices is better defined in IEC 62366 where it requires, for the specification of intended use, the following information:
- Device description
- Medical purpose
- PATIENT population
- Part of the body or type of tissue applied to or interacted with
- Intended USER
- Application
For each of these, several different info is required (for example, for application, environment conditions and frequency of use. For intended use, expected experience, knowledge or education).
Without this information, any risk management is really pointless :)
So, my suggestion would be to use IEC 62366 and other usability/human factors standards, guides and techniques do develop your device intended use.
V
vishal.cpdm
Thank you for the suggestions Marcelo!
So if I get this rite from the discussion, intended use is a definitive set of statements that should be scripted and completed before starting the risk management activities. It could become an individual document (although a very small doc) in itself which should be referred to through out the risk documentation activity. Correct?
Marcelo
Yes, that´s a way to view it. If you have a separate document (and this is important enough for you to have so, with analysis and other info) you need to include it in the risk management file.
Just mind you - it´s not really "statements" only, but a base for device design. And device risk management. And device usability. And any device claims......and there goes!
I Medical Device - Bundled 510(k) for multiple intended uses Other US Medical Device Regulations 11
P Updating a Medical Device's Intended Use Other US Medical Device Regulations 2
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
L Medical Device Registration in Macau Other US Medical Device Regulations 1
A Medical Device Registration in the Dominican Republic Other Medical Device Regulations World-Wide 4
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
T B2C Medical Device Shipping across the US Other Medical Device Related Standards 0
M Medical Device Registration In Malaysia Other Medical Device Regulations World-Wide 2
N Adding unclassified product to the medical device registration US Food and Drug Administration (FDA) 1
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
K CE Marking for Class I Medical Device? CE Marking (Conformité Européene) / CB Scheme 8
