Medical Device Label Acceptance Criteria
Hello there - I work at a company that makes a class 2 single use medical device. We are investigating our label printing process and are trying to benchmark what acceptance criteria other companies/organizations use for their product labeling. The regulations mainly state that the labels must remain intact/legible during shipping, handling, and use, so I understand the regs. However, the regs aren't specific to state "only scratches 1" by 1" are ok" or "missing print must not exceed 0.5" in diameter".
My questions is: Can anyone point me to some acceptance criteria that other orgs use for med device labels?
Currently my company only allows very small scratches and missing ink and am wondering if we are being too stringent with our requirements. All of our labels are customer facing.
yodon
I'm not exactly a labeling expert but I'll toss in my 2 cents and maybe get the ball rolling.
I've never seen anything for label acceptability other than, as you say, legible (and that barcode is readable). What I generally see is, during a manufacturing run, to capture (a copy of) the first and last label as a level of evidence that the labels were good. If you are able, a vision system on the line checking each one is obviously best.
I would worry about "missing ink" since that could potentially cause a barcode read failure (worst case).
indubioush
I suggest that you specification says "no scratches or missing ink." It isn't that difficult to make a pristine label print that is able to withstand shipping, etc. Are you using outdated label printing equipment or supplies? Your specification should show an example label as a standard to judge label prints. I would not want any labels with scratches or missing print to be seen by customers. Other things that should be looked at are size, color, barcode verification, font type, label stock, and probably other stuff that is not coming to mind...
Thank you both for your insight. I have extensive experience with label printing and we are using old printers on vinyl label stock. So, basically worst case scenario.
It seems like it's up to the company "what good looks like" as far as all printing is legible.
What i'm hoping is to find someone with an example of what dimension of missing print is ok vs. not ok. For instance, any missing print spots must be 3mm or smaller. Something like that.
indubioush
It is up to your organization to determine the acceptable label defects based on the associated risk and customer requirements.
I am looking for a better way of label verification to follow FDA medical device regulations. Currently, we are doing it on paper and our goal is to go paperless. What are some of the ways you all are doing your label verifications?
It is my understanding that yes you need to check for ink and all that, but you also need to make sure that you are:
a. putting the right label on the right product
b. make sure if it needs an IFU, exp date or any additional info or symbols on it
c. and believe it or not, make sure the label is on straight, not crooked.
How much money are you willing to spend? Vision systems can do 100% verification.
I'm not sure. I just wanted to see what is out there. We have sooooo many different software systems in place, I would hate to add another one. I just wanted to see what others were doing out there. . . Thanks for your input, I will check Vision Systems out!
S FDA Requirements for Medical Device Label Reconciliation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
M Labeling for off-label use - Prevention of off-label use of a medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C FDA Medical Device Label Requirements - serial numbers Other US Medical Device Regulations 2
S Medical Device Research Use Only (RUO) label Other Medical Device Regulations World-Wide 4
J Label on Miniature Active Class I Medical Device EU Medical Device Regulations 0
shimonv Off-Label Use of a Medical Device in Japan Other Medical Device Regulations World-Wide 2
Pmarszal Label Printing: Medical Device related UDI Requirements - GUDID Aspects Other US Medical Device Regulations 0
I Label Expiration Date - Single Use Combination Medical Device EU Medical Device Regulations 2
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
F CE and FDA Mark on same IVD/Medical Device Label EU Medical Device Regulations 12
E ISO 15223-1 (Medical Device Label Symbols) - Revisions, EU commission? Other ISO and International Standards and European Regulations 1
R Medical Device Packaging Label Validation Other US Medical Device Regulations 8
shimonv Changing the Label of a Medical Device product in the field Other US Medical Device Regulations 5
I Label of a Medical Device sold in EU - Non translated information EU Medical Device Regulations 7
E How do you monitor Medical Device Off-Label use by Customers & Medical Professionals EU Medical Device Regulations 5
S Medical Device Label Information Requirements in the EU EU Medical Device Regulations 3
M How to best prioritize Medical Device Label Contents Other Medical Device and Orthopedic Related Topics 16
C CE Mark Label Symbol Requirements on a Medical Device CE Marking (Conformité Européene) / CB Scheme 3
D Class II Disposable Medical Device Label Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D Off-Label Medical Device Use US Food and Drug Administration (FDA) 7
E Brazil Medical Device Label Issues Other Medical Device Regulations World-Wide 3
P Medical Device Label Location Requirements Other US Medical Device Regulations 6
W Question re: Class II Medical Device Software - Label / Device Definition Other US Medical Device Regulations 4
R Medical Device Label Revision Level Requirements Other Medical Device and Orthopedic Related Topics 24
H Medical Device RUO (Research Use Only) and 'Sterile' Label Claims 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Medical Device Registration in Brazil for Private Label Manufacture Other Medical Device Regulations World-Wide 6
J Class IIa Medical Device - Can I over label to change an address? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Off Label Usage (Class II Medical Device - Blood Bank Software) US Food and Drug Administration (FDA) 3
J How do I qualify a Label Design for Medical Device Design and Development of Products and Processes 4
N What needs to be on the label? Medical Device Labelling Requirements EU Medical Device Regulations 12
A US FDA Medical Device Label Requirements Other US Medical Device Regulations 2
thisby_ Medical Device with Barcode - How to label it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Address on Label - Medical Device Labeling Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
P Control of Serial Number Label in Medical Device CE Marking (Conformité Européene) / CB Scheme 7
L Rx Only vs. Professional Use Only - Class II Private Label Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 17
L Label placed on medical device by subcontractor based outside USA ISO 13485:2016 - Medical Device Quality Management Systems 4
somashekar Mark on Medical device label marketed in Canada ISO 13485:2016 - Medical Device Quality Management Systems 1
N Reference to FDA on Label or Labelling - Class II Medical Device US Food and Drug Administration (FDA) 7
C Labeling of Medical Devices - Distributor replacing device serial number label 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A QMS inside a Non medical device firm ISO 13485:2016 - Medical Device Quality Management Systems 3
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
A Labeling Requirements for Medical Device Travel Case US Medical Device Regulations 6
Judy Abbott Guideline as for devices utilizing plants and their derivatives in medical device US Food and Drug Administration (FDA) 6
B Registration of a CE-marked medical device in Japan -Will they accept conformity with GSPRs? Japan Medical Device Regulations 0
B Software as a Medical Device - Language Requirements EU Medical Device Regulations 6
C Medical Device registration CE Marking (Conformité Européene) / CB Scheme 3
B Software as a NON-medical device Medical Information Technology, Medical Software and Health Informatics 22
M Can you import medical device not FDA approved into the USA under an IND application? US Food and Drug Administration (FDA) 2
A Algorithm As a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 3
