Medical Device Manufacturing Environmental Requirements
medguy123
I am part of a med device startup company which is producing a new class 2 product. We are in the process of mfg devices to be used for biocompatibility and animal testing. We are temporarily manufacturing these in a garage, literally, until we find a permanent location. We have a quality system in place, and outsource sterilization and packaging. Provided we pass our sterilization validation, what concerns would you have and what precautions you would recommend?
Thank you.
Ajit Basrur
Thank you.
Welcome to the Cove, medguy123 :bigwave:
21 CFR Part 820.140 on Handling states -
Each manufacturer shall establish and maintain procedures to ensure that mixups, damage, deterioration, contamination, or other adverse effects to product do not occur during handling.
In accordance with above, your manufacturing environment must be controlled to be prevent microbial population as it contributes to the overall microbial load and thus impacts the sterilization cycle.
Since you have mentioned that your manufacturing environment is like a garage, there could be lot of challenges meeting this requirement. All medical devices that are sterilized need to have environmental monitoring program of the manufacturing environments.
medguy123
Thank you for the quick reply. I do not believe it would be difficult for us to establish an environmental monitoring program. However, like the rest of 21CFR, it is left to the manufacturer to determine what is appropriate. I have come across a number of bioburden testing programs. It seems the standard methods involve air, surface sampling, or both and the monitoring can be qualitative or quantitative. I would be interested in hearing what methods people have used and how "acceptable" levels were established at their company.
Thanks!
MIREGMGR
Most FDA regulations are written in outcome format, i.e. if you can make devices in a garage that are suitable for their intended use, that's OK.
Obviously you can't finally validate production processes in a totally different environment than where they eventually will be conducted. You probably can't establish that the environment in the garage is stable, therefore you probably will have to verify bioburden on every manufacturing batch, or every production unit depending on product type, so as to establish that it is low enough to be within the validated capability of the sterilization facility and cycle that your contractor will use; and, that sterilization cycle may need to be rigorous in an overkill direction to suitably assure that the imperfectly managed bioburden is adequately dealt with.
MIREGMGR
All of the bioburden management programs with which I'm familiar, are based on preparatory work to make the managed environment stable and consistent, and unaffected by the activities taking place in it and at its defined boundaries, i.e. goods and people moving in and out. A normal garage is a long, long way from a stable, consistent bioburden environment. I think instead you're going to have to verify bioburden on your actual devices after they leave the uncontrolled manufacturing environment.
Of course, I don't know what your devices are, so the above is a generalization.
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
S Contagious Diseases in Medical Device Manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 5
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
N Is there a standard / rules pertaining to eating in medical device manufacturing area? Manufacturing and Related Processes 5
V Removing final inspector for medical device manufacturing Lean in Manufacturing and Service Industries 4
C Medical device manufacturing (class 2 ISO 13485:2016) - Is a Deviation allowed? Other Medical Device Related Standards 5
S 21 CFR 810 - Medical Device Recall Authority - Contract Manufacturing Other US Medical Device Regulations 1
B Manufacturing site relocation of pre amendment Class II medical device Manufacturing and Related Processes 4
A Medical Device manufacturing Facility Test audit IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W Requirements for Contract Manufacturing of a Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C Medical Device Packaging Manufacturing - How should product be stored on the pallet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Help on Medical Device Manufacturing - New Medical Device Company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M When is a Manufacturing Date required on Medical Device Labeling? Other Medical Device Regulations World-Wide 12
L Medical Device Manufacturing Equipment Design Other Medical Device Related Standards 2
H FDA/PMA/Medical Device/Before submission/Manufacturing facility change US Food and Drug Administration (FDA) 1
D PPE Requirements in Manufacturing Area of Class IIa Medical Device Other Medical Device and Orthopedic Related Topics 3
M Building Production / Manufacturing Facility for Class 2 Medical Device US Food and Drug Administration (FDA) 1
F Definition Medical Device Contract Manufacturing PAI (Pre-Approval Inspection) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J FDA Compliant Quality System for Virtual Manufacturing (IVD Medical Device)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Medical Device Manufacturing Process Monitoring Best Practice ISO 13485:2016 - Medical Device Quality Management Systems 2
S Steam Sanitization Requirements for Parts for Medical Device Manufacturing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Medical Device Manufacturing Enterprise License from SFDA China Medical Device Regulations 2
U Manufacturing vs. Production for Medical Device Software in a FDA context 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Risk Management Methods in Medical Device Component Manufacturing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B ISO 13485 and Medical Device Manufacturing Outsourcing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Medical Device Manufacturing in Controlled Environment? How to decide? Other Medical Device Regulations World-Wide 1
P Loctite as Manufacturing Material use in Medical Device Assemblies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 12
P Control of "manufacturing material" that has adverse effect on the medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Please share a SOP on Medical Device Good Manufacturing Practices (GMP) US Food and Drug Administration (FDA) 8
I Medical Device Exclusivity Period if granted a PMA (Parts Manufacturing Approval) Other US Medical Device Regulations 2
D Sub-Contract Manufacturing of a Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Sample Manufacturing Plan or Template for Medical Device Contract Manufacturer Document Control Systems, Procedures, Forms and Templates 5
H Cooling Equipment Qualification for Medical Device Manufacturing EU Medical Device Regulations 3
Q Class 3 Medical Device Manufacturing Companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
somashekar Medical Device Manufacturing License from FDA and State of Location Required? Other US Medical Device Regulations 10
G Medical Device Contract Manufacturing Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
U Medical Device Manufacturing License - ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q CAPA - Process - Class III Medical Device Manufacturing Nonconformance and Corrective Action 7
E Recording Scrap - Problems in the Medical Device Manufacturing Sector ISO 13485:2016 - Medical Device Quality Management Systems 4
M Odd Contract Medical Device Manufacturing Situation - Medical Device Packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M PQ and PPQ - Process Qualification for medical device manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Class II medical device manufacturing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q A Non-Quality Culture at a medical device manufacturing company Career and Occupation Discussions 13
C Contract Manufacturing of Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 11
P Startup Medical Device Manufacturing Company Guidance ISO 13485:2016 - Medical Device Quality Management Systems 7
S Components Cleaning for Manufacturing Sterilized Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
R Interim Stages of Medical Device Manufacturing Production ISO 13485:2016 - Medical Device Quality Management Systems 4
G Medical Device 510k Requirements - Plan to expand the manufacturing site in Malaysia US Food and Drug Administration (FDA) 11
S Environmental Control Standards - Sterile medical device manufacturing environment ISO 13485:2016 - Medical Device Quality Management Systems 3
V Ratio of Quality vs. Manufacturing Staff in Medical Device Industry ISO 13485:2016 - Medical Device Quality Management Systems 8
