Medical Device Notified Body Surprise Audits Required in 2014
L
Lucky57
#11
Re: Notified Body Surprise Audits Required in 2014
Is there any written regulation or directive in force, that we as manufacturer of class II products have to allow unannounced audits from our customer's NBs? Would appreciate any news regarding this. Thanks a lot.
MIREGMGR
#12
Yes. If you (as the physical manufacturer of a medical device for which your customer is regulatorily responsible) refuse an unannounced inspection, your customer's NB is obligated starting this year to escalate the situation toward (if no resolution can be arranged) removing your customer's certification.
Ronen E
Problem Solver
Moderator
#13
2. GENERAL GUIDELINES FOR AUDITS AND ASSESSMENTS
The notified bodies should apply the following:
(c) To verify the day-to-day compliance with legal obligations, notified bodies should, in addition to the initial, surveillance or renewal audits, visit the manufacturer or, if this is likely to ensure more efficient control, one of its subcontractors in charge of processes which are essential for ensuring compliance with legal requirements (‘critical subcontractor’) or a supplier of crucial components or of the entire devices (both: ‘crucial supplier’) without prior notice (‘unannounced audits’) in accordance with Annex III.
COMMISSION RECOMMENDATION on the audits and assessments performed by notified bodies in the field of medical devices (2013/473/EU)
http://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:2013:253:0027:0035:EN:PDF
pkost
#14
I'm going to be pedantic, but I believe it is an important distinction
The directive/guidance/recommendation places no obligation on the sub contractors of manufacturers to undergo audits....HOWEVER....
The requirement comes from the manufacturers obligation to enable access to to their subcontractor for their notified body, the consequence of not enabling this is ultimately certificate revokation (as stated by MIREGMGR)...Therefore the manufacturer should be putting contracts in place with their sub contractors that essentially say that the subcontractor will permit the manufacturer, notified body AND competent authority on site to audit AND that this may be unannounced...Subcontractors will therefore have a contractual obligation to permit an NB unannounced audit
This clause would be a requirement of any business being placed on the subcontractor by the manufacturer....It may (and probably should state) that the subcontractor will have a similar right in place with any of their suppliers/subcontractors ad nauseam to the point of raw material supplier
Ronen E
Problem Solver
Moderator
#15
I mostly agree but how did you conclude that the obligation goes beyond the 1st tier? In principal it makes sense but I doubt that NBs will take it that far, and I assume that even the Commission has some business sense to allow them to understand that this may be perceived as an unreasonable burden by 2nd or lower tier suppliers; and the last thing the Commission wants is to unduly disrupt business with EC impact. Either way, it's not spelled out in the Recommendation.
Cheers,
Ronen.
#16
My understanding is that the NB audit of suppliers only applies to critical suppliers, that is those suppliers that are named on your type examination certificate.
From my experience this would only have applied to the sterilisation provider when I was at an implant company - that was the only example I have seen of a supplier being named on the certification.
I believe that this information comes from a webinar delivered by a very senior NB supervisor.
pkost
#17
Not all notified bodies list suppliers on certificiates
Ronen: Critical supplier is the key term that could potentially allow/require audit back to raw material supplier, take for example orthopaedic implants, certainly the form and shape is critical, however the material, it's processing and consequential composition and microstructure are also critical. A manufacturers sub contractor may only machine down a bar received by a foundry,
#18
The listing of a supplier here is on the Type Examination Certificate, so only really applies to a Class III devices or AIMD.
The active implant company I previously worked for only had the sterilisation service suppliers listed - material suppliers (including silicones) were not classed as critical suppliers.
The company I now work for does various Class I and II products (including some sterile). With no Type Examination certificates involved we do not have any critical suppliers.
Ronen E
Problem Solver
Moderator
#19
I understand the approach stated above, but I think it is a bit risky. The Commission recommendation has its definition of Critical Subcontractor, and it says nothing about them being the ones stated on a certificate. If this is based only on the opinion of a single NB specialist (as senior and knowledgeable as they may be), I'd look for something in writing or for second opinions or for some para-legal analysis of the Commission's wording, before concluding that if suppliers are not on certificates they will not be subject to unannounced audits.
Cheers,
Ronen.
#20
The bloke in question is the current chair of NB-MED, the co-ordination board for Notified Bodies.
But, of course, the NBs and the EC do not always agree!
M Notified Body audits -Class Ia medical device product EU Medical Device Regulations 4
M Informational EU – October 2019 update – State-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 2
M Informational EU – State-of-play of joint assessments of Notified Bodies in the medical device sector – June 2019 Medical Device and FDA Regulations and Standards News 0
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
M Informational EU – Update on state-of-play of joint assessments of Notified Bodies in the medical device sector Medical Device and FDA Regulations and Standards News 1
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
M Medical Device News State-of-play of joint assessments of Notified Bodies in the medical device sector EU Medical Device Regulations 0
C QR Code on Medical Device Packaging and Notification to Notified Body EU Medical Device Regulations 1
N How to register a non notified Medical Device in India Other Medical Device Regulations World-Wide 5
P Medical Device Notified Body meeting - April 2012: Brussels EU Medical Device Regulations 9
D Choosing a notified body for a new start up company in the UK - Medical Device area Registrars and Notified Bodies 6
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
