Medical Device Procedure Pack IFU's (Instructions for Use)
J1980b
Hi All,
I'm enquiring about the supply of IFU's for Procedure packs.
Assuming a company assembles a procedure pack comprising of individual components manufactured themselves and Medical devices by other Manufacturers and the 'other company' states that their product requires an IFU for its safe use. The Pack manufacturer is required to supply the IFU at the same rate as recommedned by the OEM.
I have seen this in the field, however if there are many components all requiring IFUs there could potentially be a selection of 10-20 IFU's per pack - This I have never seen by any Pack manufacturer.
My question is - How do pack manufacturers get around not supplying IFU's? I'm aware of numerous occasions where a device requires one, but it is not available either in the pack or in the supply carton. Are Pack manufacturers doing thier own risk assessment that is stating that an IFU is not required, irresepective of the OEM information?
Please assume that the Pack is CE marked by its own accord and not assembled in accordance with Article 12.
I look forward to peoples thoughts
Ronen E
Problem Solver
Moderator
I'd say a non-article-12 device (a pack for the matter) should have its own IFU. How this IFU is created and what its contents are, are up to the manufacturer and the involved NB (if any). Overriding a component manufacturer's instructions may be addressed in the risk management process.
Cheers,
Ronen.
V
Vlcekad
Dear collegues,
We plan tu put two CE-marked devices into one box. This will be a system pack. We are base in EU and we plant to market it in EU.
We will be the assembler and manufacturer of one of the devices.
Both devices have primary and secondary package labeles and IFUs.
We will put both IFUs into the box this is no problem.
I am confused how to combine those secondary labels on a single paper box, and what should we display on the box so that it is not confusing.
thanks for advice!
MIREGMGR
We do something similar. We are the responsible Manufacturer of a device that is sterile-barrier-pouch-packed. Inside the pouch, we also put a second device that we source from another responsible Manufacturer, that in essence is an accessory to our device. The second device is in its own impervious packaging, so our sterilization process does not affect it. Each device has its own regulatory label and CE Mark.
The MDD is less than clear on how to handle this scenario. Our CB has reviewed the situation and is satisfied with our approach, which is that our device's label on the overpack-pouch and on the overall case includes information describing the presence within the overpack-pouch of the second device. The second device's own labeling is present only on that device's own packaging.
93/42/EEC 13.1 Instructions for use must be included in the packaging for every device.
By way of exception, no such instructions for use are needed for devices in Class I or IIa if they can be used safely without any such instructions.
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
M Informational TGA Consultation: Proposed clarification of the regulatory requirements for medical device systems and procedure packs Medical Device and FDA Regulations and Standards News 2
A Certification procedure for OEM/PLM collaboration in the medical device industry in the US - Who bears the regulatory responsability? Other US Medical Device Regulations 10
alonFAI Please share a medical device company NCMR procedure Other Medical Device Related Standards 5
I Japanese medical device recall requirements & procedure for foreign manufacturers Japan Medical Device Regulations 4
P What is expected in a Medical Device Commercial Release Procedure Design and Development of Products and Processes 3
S What is the procedure to reclassify a Medical Device in Canada? Canada Medical Device Regulations 3
K Medical device procedure tray - Adding products in Custom packs Other Medical Device and Orthopedic Related Topics 3
S Medical Device Clinical Evaluation Standard Operating Procedure / SOP Document Control Systems, Procedures, Forms and Templates 11
S Medical Device Clinical Evaluation Standard Operating Procedure / SOP Imported Legacy Blogs 1
somashekar Electronic data Back-up procedure, for Medical device QMS and regulatory purpose. ISO 13485:2016 - Medical Device Quality Management Systems 4
S Medical Device Reporting SOP (Standard operating procedure) example Other Medical Device and Orthopedic Related Topics 1
J Quality Procedure to handle some standard Medical Device Processes Document Control Systems, Procedures, Forms and Templates 1
T Medical Device Reporting Procedure ISO 13485:2016 - Medical Device Quality Management Systems 2
E Does MDD (Medical Device Directive) Require a CAPA Procedure? Document Control Systems, Procedures, Forms and Templates 3
J Medical Device Recall Procedure example wanted ISO 13485:2016 - Medical Device Quality Management Systems 1
C Storage Managment (Stock Control and Storage) procedure for Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
K Medical Device Software Development Procedure IEC 62304 - Medical Device Software Life Cycle Processes 20
M Non-Conformance Procedure FlowChart for a Medical Device company Document Control Systems, Procedures, Forms and Templates 3
A Procedure for Completing Medical Device Project Plans ISO 13485:2016 - Medical Device Quality Management Systems 5
C Medical Device Reporting procedure - Correction and Removal (21 CFR 806) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Medical Device Advisory Notice Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
M FDA Audit Procedure - SOP - Small Medical Device Company Document Control Systems, Procedures, Forms and Templates 19
Ajit Basrur Control of Medical Device Labels and Labelling Activities - Looking for a procedure Document Control Systems, Procedures, Forms and Templates 15
D Dock-To-Stock procedure - Medical Device Company Document Control Systems, Procedures, Forms and Templates 1
A Mechanical Design Procedure - Infusion pump incorporating software - Medical Device Design and Development of Products and Processes 1
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
