Medical Device Raw Material Traceability Requirements
psp1234
We are a contract manufacturer for medical device companies.
I am new at the Quality team and I see that the practice here is to report raw material (for the making of a component) lot numbers on the COC.
I have two questions, if you may:
1. Is it necessary to list ALL materials used with traceability (including glue lot number) or only the main/high risk?
2. Is it necessary to have one-one lot ratio. So, if we need two lots of raw-material-x, we would need to breakdown a finished lot to not create a situation, where two raw materials are "mixed" in our finished component lot (even though we would have traceability to both).
3. If we don't have a customer's explicit requirements for one-one raw-lots usage, is there any FDA requirement to do it?
(we are not FDA registered, only ISO-13485.):confused: :ca:
Thanks in advance,
Sue
somashekar
Hi Sue.
The traceability requirement is a risk based decision, and it is based on your product made and its intended use. So if the glue gets recognized as a material requiring traceability, it gets included.
Any sort of mix will kill the purpose of traceability, if that specific material is identified as traceability required.
psp1234
Hi somashekar,
Thanks for your reply,
For the purpose of a possible recall, if I mix two materials in my lot, I can still identify in which lot the "bad raw material" was in. It will only increase the number of lots I recall, which is my risk (ok, and the customer's too:notme: - but customers don't dictate lot size for us, so it will be irrelevant).
And what if 100% of functionality (of raw-part) is performed? that reduces the risk altogether - can I remove traceability for a raw material (let's say an o-ring) if 100% tested?
(Is it all driving from the PFMEA risk factor?)
Thanks again,
Sue
somashekar
Yes it is, only if you are exactly sure you can identify in which lot the "bad raw material" was in ..... meaning you have established traceability adequately.....
pkost
It reduces known risk, there are still the unknowns. I'd argue that even the known risk isn't reduced to 0.
BarryTaylor
In general terms I agree, traceability of raw materials should be managed with a risk based approach where there is no customer specified requirement. One could argue that you may decide to take a more robust line than required by your customer.
Factors that should be included in the risk assessment are:
- the potential for, and severity of, injury to the patient or user if the material failed by failure mode "x" or by failure mode "y"
-the potential business risks if the material should fail.
these, and other factors identified in the risk assessment, should be used as input to your risk management process that may say, for example that mixing of two raw material batches has an acceptable risk profile even if it were to double the number of finished devices affected.
A word of warning, my experience suggests that too radical an approach to risk management does not sit well with regulators and their inspection teams.
psp1234
Thank you all!
Based on "risk analysis" only, most our materials are rather risk free. Our processing that adds the value, adds risk to the product. But I don't see any customer that will approve (or see favorably) losing resolution of raw material.
I guess I will push for bigger lots at incoming...
Regards,
Sue
M Are Medical device Raw material suppliers required to be ISO 13485 certified ISO 13485:2016 - Medical Device Quality Management Systems 13
J Risk Assessment of Raw Materials? Medical Device product ISO 14971 - Medical Device Risk Management 2
H Medical Device Manufacturer: Incoming Raw Material Inspection ISO 13485:2016 - Medical Device Quality Management Systems 5
A Raw Material Specifications - Medical Device Company ISO 13485:2016 - Medical Device Quality Management Systems 8
J Endotoxin testing - Raw materials and components of a Class III medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
L Medical Device Registration in Macau Other US Medical Device Regulations 1
A Medical Device Registration in the Dominican Republic Other Medical Device Regulations World-Wide 4
Aymaneh Medical Device Cybersecurity Risk Management IEC 27001 - Information Security Management Systems (ISMS) 2
T B2C Medical Device Shipping across the US Other Medical Device Related Standards 0
M Medical Device Registration In Malaysia Other Medical Device Regulations World-Wide 2
