Medical Device Servicing ? What Terminology?
SteveK
Medical Device Servicing – What Terminology?
As well as manufacturing Class IIa and IIb devices, we also service them for our customers (on-site) as part of a Planned Preventative Maintenance (PPM) programme. I would be interested on what terms and definitions of term other companies use. We indicate that our products are serviced annually either by ourselves or a hospital EBME department. Service terms that seem to be used are Inspection (but if a part is worn/damaged then replace – e.g. an O ‘Ring’), Minor service, Standard service, Major service etc. In the case of a mobile electrical suction unit, we currently recommend that an annual “Standard” service involves replacing filters, washers, external tubing and some parts on the receiver jar. We then recommend a “Major” service every 5 years. This involves the above plus stripping down and servicing the pump motor (with a service kit), replacing internal tubing etc. If anybody out there does this type of stuff I would be interested in some comments/suggestion on what should be the “correct” industry usage of such terminology.
Thanks!
Steve
Marc
Re: Medical Device Servicing – What Terminology?
Any thoughts on this, folks? My Thanks in advance!
V
Vincnet
Hi Steve,
I have no idea of what the standard wording is in the industry.
But I follow the idea as yours with my clients generally calling them Servicing level 1 Level 2 etc... as many levels as required by the type of product, and just defining in each level what needs to be done.
I know that in the automotive industry they do more or less do the same in defining what should be done for each servicing for my motorbike Honda has a very good web based database where they tell you what needs to be done for each servicing.i.e. 2000Km, 6000km, 12000km 18000km.
Vincent
V
Vincnet
Just a quick update on this one Steve,
as we are in a strange small world, I just have this issue to deal with for a client. And digging the current regs, I would warn you to check with local and European laws regarding product and service both general and medical device related, and to the warranties and liabilities you will have to deal with in offering such services.
V
S Medical Device Servicing - Forms and Signature ISO 13485:2016 - Medical Device Quality Management Systems 1
F Mexico Medical Device Importing and Servicing Other Medical Device Regulations World-Wide 2
S Manufacturers Obligations for Medical Device Servicing and/or Repair EU Medical Device Regulations 10
A Are Medical Device Servicing Instructions Part of Labeling? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
J Medical Device Engineering, Manufacture, and Servicing Document Storage US Food and Drug Administration (FDA) 1
T Definition Servicing Activities - Definition - Medical device accessory manufacturer Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
L Medical Device Registration in Macau Other US Medical Device Regulations 1
A Medical Device Registration in the Dominican Republic Other Medical Device Regulations World-Wide 4
