Medical Device Software - Design Outputs? ISO 90003 and ISO 62304
K
koes0030
Hi all! I'm currently struggling with trying to overhaul a company's design control procedure. The company is trying to follow ISO 90003 and 62304, but must also be compliant with 21CFR820 and ISO 13485. Currently, the company is using a Software Requirements Specification document for design inputs... they have not defined what serves as their design outputs. They have a Software Design Specification document that could be part of the ouput... but it seems that the actual source code is going to be the primary output.
This is the first time I've ever worked with a software device... when working with inputs/outputs at other device companies, I've always seen them presented in some sort of matrix format, clearly showing which outputs satisfy which inputs (drawings, specifications, IFU's, etc.) I can't seem to figure out how it should work in this case with the software device. How can we put the outputs in a form that enables verification against the inputs? Any thoughts would be greatly appreciated!!!
rclanzillotto
Re: Medical Device Software - Design Outputs?
Develop a software customer requirements document that will serve as your design input. This contains functional descriptions. Link it to your specification and V&V tests.
Good Luck
yodon
Several things could be candidates for software design outputs. These include, depending on the project size / levels of documentation you have, Architecture documents (e.g., block diagrams, state diagrams, etc.); Top-Level Design docs, Detailed Design docs, Database Design docs; Interface docs (one level could be requirements <inputs> and another level could be design <outputs>); Software Build reports (more of a CM accounting but can show architecture); & Software Version Description Documents.
Reviews of each should confirm some aspect of a parent doc; e.g., an architecture doc could confirm that required functionality is addressed (at a high level), design docs (immediately traced to requirements) would be reviewed to confirm the design both adequately addresses the requirements and that the requirements are fully 'consumed.'
Marcelo
The way you´re presenting this semms a little weird to me. You should be defining "verifiable" design inputs (which will lead to verifiable design outputs, not forcing the output to be verifiable.
Also, a requirements engineering proccess could help.
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
F Software as a Medical Device (SaMD) Technical File Requirements Manufacturing and Related Processes 1
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 1
Z Software Library - could it be a medical device? ISO 13485:2016 - Medical Device Quality Management Systems 5
M Informational TGA – Submissions received: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 1
D Requirements for the dimensions / color of medical device labels - Software as a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 2
D Software as an accessory to a Class I medical device EU Medical Device Regulations 4
R Medical device software without user interface Other Medical Device and Orthopedic Related Topics 3
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
Ed Panek Rule 11 Question - CE approvals for software as well as the medical device EU Medical Device Regulations 6
D IEC 60601 for a Software only Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Software Release Note - Class A stand alone software medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
M Professional Use Medical Software French Labeling for Canada -- Not Considered Medical Device Canada Medical Device Regulations 2
S Medical Device Software Distribution for a CE-marked medical device via a USB memory stick EU Medical Device Regulations 8
M Informational TGA – Webinar: An update on the consultation for the Regulation of Software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
J Qualification of a Software as a Medical Device (SaMD) guidance under MDR EU Medical Device Regulations 9
P Software requirement and design specifications - Medical device contains both hardware and software IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational TGA Consultation: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
N Medical Device Accessory Classification - Software as a Medical Device Other Medical Device Regulations World-Wide 5
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
M Medical Device News TGA – Regulation of Software as a Medical Device Medical Device and FDA Regulations and Standards News 0
S Two Questions about Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Medical Device Software Update in Field of AIMD IEC 62304 - Medical Device Software Life Cycle Processes 1
M Medical Device News Health Canada - Scientific Advisory Panel on Software as a Medical Device (SAP-SaMD) - Record of Proceedings – January 26, 2018 Canada Medical Device Regulations 0
R Online / Cloud Based Software as Medical Device EU Medical Device Regulations 8
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
S Labelling in Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 8
S What is considered the complete software medical device? Medical Information Technology, Medical Software and Health Informatics 6
JoCam Medical Device Software - Apps which can control medical devices EU Medical Device Regulations 13
L Software Medical Device - 7.3.8 - Design and Development Transfer ISO 13485:2016 - Medical Device Quality Management Systems 4
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
K Registering a Software medical device (SaMD) in China China Medical Device Regulations 5
N Medical Device Software - Switch from Waterfall to Agile methodology Medical Information Technology, Medical Software and Health Informatics 4
V Software medical device labelling EU Medical Device Regulations 5
I Medical Device Software Risk Analysis ISO 14971 - Medical Device Risk Management 4
S If a piece of software receives approval as part of a medical device system Canada Medical Device Regulations 5
C Controlling Software Versions that are part of a medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
S Cloud-Based Stand Alone Software - Software Medical Device (Class II) US Food and Drug Administration (FDA) 2
Q QMS Software for Startup Medical Device Company Other Medical Device and Orthopedic Related Topics 6
B CQC oversight of Medical device software? EU Medical Device Regulations 3
H Identifying Guidance on Medical Device Software Level of Concern for the EU EU Medical Device Regulations 2
B Is IEC TR 80002-1:2009 applicable to stand-alone medical device software? ISO 14971 - Medical Device Risk Management 1
H ISO 14971 vs. IEC 62304 vs. 98/79/EC vs. ISO 13485 (Software Medical Device) ISO 14971 - Medical Device Risk Management 1
T Are internally found Medical Device Software "Bugs" Complaints? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 510k "Premarket" Submission for Existing Class II Software Medical Device US Food and Drug Administration (FDA) 3
P UDI Registration - Class II Medical Device Software Other US Medical Device Regulations 9
D Medical Device Software Tool Validation - Compilers! IEC 62304 - Medical Device Software Life Cycle Processes 7
N When is Medical Device Software Validation required? ISO 13485:2016 - Medical Device Quality Management Systems 6
