Medical Device Software (Firmware) Validation with using IEC62304
sl344
Dear all,
The firmware I 'm working on is developed using 62304. However, since 62304 does not cover software validation. I'm done with all the software verification activies, how should I handle the software validation? please help. thanks.
sagai
what is it mean that you are using 62304?
Is your medical device will be marketed in the US?
Regard
Szabolcs
sl344
the firmware was developed following 62304 processes. No, the device will be marketed in EU only.
Pads38
The validation requirements are specified in EN 60601-1:2005 clause 14 (which replaces 60601-1-4).
It overlaps with 62304 but is complimentary.
sl344
Thanks all for your replies. I reviewed the FDA software validation guidance. Based on the definition in the guidance below. I feel the only thing I really need to do for software validation is to make sure the SRS conforms to the users need, which could be done through traceability analysis. As the firmware was developed following 62304 processes, all the tasks below SRS have been completed such as design, implementation, unit testing, system level testing, etc.
We did not go through the 60601 Clause 14 PEMS path because the device was determined NOT a PEMS, given the fact when the firmware fails, it does not produce an unacceptable risk.
How do you think?
thanks,
Lori
Software validation is a part of the design validation for a finished device, but is not separately defined in the Quality System regulation. For purposes of this guidance, FDA considers software validation to be "confirmation by examination and provision of objective evidence that software specifications conform to user needs and intended uses, and that the particular requirements implemented through software can be consistently fulfilled." In practice, software validation activities may occur both during, as well as at the end of the software development life cycle to ensure that all requirements have been fulfilled. Since software is usually part of a larger hardware system, the validation of software typically includes evidence that all software requirements have been implemented correctly and completely and are traceable to system requirements. A conclusion that software is validated is highly dependent upon comprehensive software testing, inspections, analyses, and other verification tasks performed at each stage of the software development life cycle. Testing of device software functionality in a simulated use environment, and user site testing are typically included as components of an overall design validation program for a software automated device.
Pads38
I tried to use the argument that as no safety function was involved I did not have to consider clause 14 (of 60601-1:2005). But our notified body pointed out the Essential Requirement of the directive.
Essential Requirement 12.1a
For devices which incorporate software....the software must be validated according to the state of the art taking into account the principles of development lifecycle, risk management, validation and verification.
However, I agree that it should be possible to effectively validate your item by confirmation that all parts of the SRS have been delivered as stated.
sagai
I do not think the SRS can be the basis of the validation activity.
Regards
Szabolcs
v9991
1) I agree with Sagai., SRS may not be good idea to base your validation approach. instead focus on URS.
but basing three-way-traceability-matrix for proving/demonstrating validation of application is a good idea.(URS vs Design spec vs test scripts) But that will include other aspects as test plan/strategy, functional/technical design, test scripts etc., which are apparently taken care.
2) I agree with Notified body, Pads38, however they are evaluated for PEMS & not leading to unacceptable risk, the product has to be demonstrated/evidenced with actual results. ( we cannot always rely upon design; nor do we can wait till product performance/feedback from market complaints/failures etc.,)
:2cents:
MDD_QNA Medical Device Software - Is a Help Button required? IEC 62304 - Medical Device Software Life Cycle Processes 1
F Software as a Medical Device (SaMD) Technical File Requirements Manufacturing and Related Processes 1
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
T First 510(k) submission - Class II software as medical device US Food and Drug Administration (FDA) 1
Z Software Library - could it be a medical device? ISO 13485:2016 - Medical Device Quality Management Systems 5
M Informational TGA – Submissions received: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 1
D Requirements for the dimensions / color of medical device labels - Software as a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 2
D Software as an accessory to a Class I medical device EU Medical Device Regulations 4
R Medical device software without user interface Other Medical Device and Orthopedic Related Topics 3
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
Ed Panek Rule 11 Question - CE approvals for software as well as the medical device EU Medical Device Regulations 6
D IEC 60601 for a Software only Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Software Release Note - Class A stand alone software medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
M Professional Use Medical Software French Labeling for Canada -- Not Considered Medical Device Canada Medical Device Regulations 2
S Medical Device Software Distribution for a CE-marked medical device via a USB memory stick EU Medical Device Regulations 8
M Informational TGA – Webinar: An update on the consultation for the Regulation of Software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
J Qualification of a Software as a Medical Device (SaMD) guidance under MDR EU Medical Device Regulations 9
P Software requirement and design specifications - Medical device contains both hardware and software IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational TGA Consultation: Regulation of software, including Software as a Medical Device (SaMD) Medical Device and FDA Regulations and Standards News 0
N Medical Device Accessory Classification - Software as a Medical Device Other Medical Device Regulations World-Wide 5
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
G EU MDR 2017/745 Rule 11 interpretation - Re-classification of a Software as Medical Device Other Medical Device Related Standards 0
M Medical Device News TGA – Regulation of Software as a Medical Device Medical Device and FDA Regulations and Standards News 0
S Two Questions about Medical Device Software 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Medical Device Software Update in Field of AIMD IEC 62304 - Medical Device Software Life Cycle Processes 1
M Medical Device News Health Canada - Scientific Advisory Panel on Software as a Medical Device (SAP-SaMD) - Record of Proceedings – January 26, 2018 Canada Medical Device Regulations 0
R Online / Cloud Based Software as Medical Device EU Medical Device Regulations 8
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
S Labelling in Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 8
S What is considered the complete software medical device? Medical Information Technology, Medical Software and Health Informatics 6
JoCam Medical Device Software - Apps which can control medical devices EU Medical Device Regulations 13
L Software Medical Device - 7.3.8 - Design and Development Transfer ISO 13485:2016 - Medical Device Quality Management Systems 4
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
K Registering a Software medical device (SaMD) in China China Medical Device Regulations 5
N Medical Device Software - Switch from Waterfall to Agile methodology Medical Information Technology, Medical Software and Health Informatics 4
V Software medical device labelling EU Medical Device Regulations 5
I Medical Device Software Risk Analysis ISO 14971 - Medical Device Risk Management 4
S If a piece of software receives approval as part of a medical device system Canada Medical Device Regulations 5
C Controlling Software Versions that are part of a medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
S Cloud-Based Stand Alone Software - Software Medical Device (Class II) US Food and Drug Administration (FDA) 2
Q QMS Software for Startup Medical Device Company Other Medical Device and Orthopedic Related Topics 7
B CQC oversight of Medical device software? EU Medical Device Regulations 3
H Identifying Guidance on Medical Device Software Level of Concern for the EU EU Medical Device Regulations 2
B Is IEC TR 80002-1:2009 applicable to stand-alone medical device software? ISO 14971 - Medical Device Risk Management 1
H ISO 14971 vs. IEC 62304 vs. 98/79/EC vs. ISO 13485 (Software Medical Device) ISO 14971 - Medical Device Risk Management 1
T Are internally found Medical Device Software "Bugs" Complaints? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 510k "Premarket" Submission for Existing Class II Software Medical Device US Food and Drug Administration (FDA) 3
P UDI Registration - Class II Medical Device Software Other US Medical Device Regulations 9
D Medical Device Software Tool Validation - Compilers! IEC 62304 - Medical Device Software Life Cycle Processes 7
N When is Medical Device Software Validation required? ISO 13485:2016 - Medical Device Quality Management Systems 6
