Medical Device Traceability Matrix - Examples
Masey B
Hello All,
Our Notified Body has requested we provide a traceability matrix with "detailed verbiage of indications statement, contraindications, warnings and precautions and complications showing traceability across IFUs, Risk Assessments and Clinical Evaluation Report".
We have attempted to provide the information numerous times in different formats but we just cant seem to satisfy our NB.
Does anyone have a template of a traceability matrix for labelling, risk assessments and CER which has been deemed acceptable by their NB which you would be willing to share please?
Many thanks in advance
Masey:thanx:
yodon
Well, I was hoping someone would jump on this and give the perfect answer. Maybe this will get the discussion going at least.
Sounds like a rather strange request / requirement. What, exactly, are they citing as non-compliant?
When we develop anything that defines risk controls, we always tag each control and trace to where implemented. So if we have identified a need to put something in the IFU based on the risk analysis, we tag the requirement and trace that to a test case that demonstrates the IFU does, in fact contain the required information.
Not sure that I've ever heard of any tracing regarding contraindications, warnings, precautions, or complications UNLESS driven by the risk analysis.
Getting into the Clinical Evaluation report, I can't even begin to imagine what they're expecting. Certainly the intent (at least partly) is to confirm that the risk analysis is complete and accurate but I don't know about traceability. I could see a case where the clinical evaluation identifies new risks or other updates needed to the risk analysis but I would think this would be identified through the standard change controls (maybe that helps traceability - referencing the change request opened?).
Again, hopefully others will weigh in.
E
experimentalparadigm
Hi All,
Does anyone have a traceability matrix template they'd be willing to share? Looking for reference/a starting point for this process.
Thanks,
D_Young
I agree with Yodon, seems a rather strange requirement. Who is your NB? Traceability matrix is well defined in CE mark standard, and what it should contain, and this is not one of the requirements. Risk evaluation should be part of the traceability matrix. Other than that the basic TM should contain:
  • Specification,
  • Version,
  • Risk design assessment,
  • Input,
  • Output,
  • Review,
  • Verification,
  • Validation,
  • Transfer,
  • Changes,
  • Label,
  • Test case/use case.
Plus, a good one should let you add other inputs. In excel that means adding an extra column with specifics related to your device.
The Cross-referencing in a TM is demanding, it takes a lot of time to put together, I know that very well, my boss repeats that ad nauseam how it took him one and half months (probably exaggerated) to put together the traceability matrix for our last FDA submission. He was adamant we would do something different the next time.
I would use a dedicated Traceability tool.
Certainly never try and maintain a manually created traceability matrix.
Use of such a traceability tool does usually require that you have a reasonably well defined development process,
(which I assume you have). It is then possible to configure the tool to automatically match the links between
artifacts created in different tools (i.e. Requirements, Tests, Code etc).
Subsequently generating the traceability matrix, is a trivial task as it is one of the primary use cases of such tools.
Teyla
Hi everyone.
Hope my experience can help. As David A mentioned there a lot of Traceability tools available... We're using the one for organizing the DHF. I wrote about it in another thread. Find it here.
But, the matrix can be built according to the specific needs. So, you can build the required structure.
If you want to have complete overview, the additional columns (inputs) can be added to your DHF one.
M Medical Device Traceability ISO 13485:2016 - Medical Device Quality Management Systems 9
P Medical Device Raw Material Traceability Requirements Other Medical Device and Orthopedic Related Topics 6
S Three Questions on Finished Medical Device Traceability, Labeling and Packaging US Food and Drug Administration (FDA) 3
M Medical Device Outsourcing Batch Traceability Requirements Other Medical Device and Orthopedic Related Topics 2
E Traceability Requirements for Medical Device History Records (DHR's) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
G Medical Device Accessories (e.g.: ECG Patient Cables) - Traceability Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
thisby_ Components Traceability Requirements of a Class I Medical Device US Food and Drug Administration (FDA) 5
P Component Traceability Requirements in a Class 2 Electronic Medical Device Other US Medical Device Regulations 5
Le Chiffre Component Traceability for a Class 2 Electronic Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 1
J Identification and Traceability in Medical Device Tracking - FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
L Medical device registration in Iran Other Medical Device Regulations World-Wide 0
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
R Compatibility studies - Medicinal Product and Medical Device Other ISO and International Standards and European Regulations 0
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
J Medical Device Regulations in Lebanon? Other Medical Device Regulations World-Wide 2
S Medical Device MRI Compatibility EU Medical Device Regulations 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
J Warnings/Cautions in Medical Device IFU Medical Device and FDA Regulations and Standards News 4
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
E Medical Device - CE marking - Local market notifications EU Medical Device Regulations 2
S Medical Device Registration in Qatar Other Medical Device Regulations World-Wide 1
M Medical device substance based-leachables Other Medical Device Related Standards 2
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F Mobile app regulations - Class II medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
U Medical Device CE Marking - Using a disposable bearing CE Marking (Conformité Européene) / CB Scheme 3
