Medical Devices: Initial Design - Sterile or Non-sterile
Jimmy the Brit
I am currently writing a procedure to define the design control requirements for sterile medical devices. Can anyone suggest a reference for the initial design choice: "does this device need to be sterile".
Usually this is an intuitive decision, but for a high level procedure I want to be able to offer a process for making the decision, and all of the standards I can find appear to assume that you have already made the choice before they become applicable.
Can anyone help me?
Yours, in hope!
JtB
chris1price
Hi
How about because either a) the device is going to be used in a sterile part of the body. b) is going to contain substances which are subsequently to be used in a sterile part of the body, or c) is going to contact another sterile device; and there is a risk of infection if a non-sterile device was used.
Jimmy the Brit
Look at 820.30 (c)
ISO 13485, section 7.3.2
I think that may be why...
:bigwave:
Thanks Gert, I have a nasty feeling you may be right. Probably too hard to regulate so best to give responsibility to the customer and manufacturer.
I'll probably have to bite the bullet and try to define something for the design controls process.
JtB
Jimmy the Brit
Hi
Thanks Chris, that is a good starting point. Where I run into trouble is when certain standards (e.g. ANSI/AAMI ST67) include mucosal contact devices (tongue depressors) and topical devices (ECG electrodes) that go beyond conventional sterility assessments. I imagine that there is some basis of litigation avoidance in the choice to sterilize these devices. For example a patient with severe burns could possibly catch an infection from an ECG electrode, although if their tissue is that compromised a Staph infection is the least of their worries. It is so hard to put your finger on a cut-off point between the need for sterility and the routine acceptance of non-sterility. I know that an MRI scanner is not supplied sterile and I know that a tracheotomy tube is supplied sterile - I just can quite define why?
:frust:
burovoy
... It is so hard to put your finger on a cut-off point between the need for sterility and the routine acceptance of non-sterility. I know that an MRI scanner is not supplied sterile and I know that a tracheotomy tube is supplied sterile - I just can quite define why?
:frust:
The cut-off point is the risk acceptability within the framework of your risk management, as it was mentioned in the previous responses.
1. Write up the intended use for your device
2. Identify contamination/cross-contamination /infection hazards
3. Evaluate probability and severity
4. Decide, based on your established risk acceptability policy, whether the risk of using non-sterile device is acceptable or not. If not acceptable then supply sterile.
Hope this helps,
I.
chris1price
Hi Jimmy
I agree, there is no technical reason for some devices to be sterile. However another driver for the design inputs could be "Custoomer Expectation - all competitors are sterile and there would be potential loss of business if the device is non-sterile".
Roland Cooke
I would add that there are (at least) two further options.
The device could be offered in both sterile and non-sterile configurations.
Alternatively your device could be offered non-sterile for subsequent decontamination/sterilization by the end-user (perhaps repeatedly so).
(In addition, some sterile products are often subsequently placed into kits, which are then themselves sterilized. Thus designing/proving your device to be able to withstand a second sterilization process might also be a requirement.)
MIREGMGR
Along the lines of Roland's comment above, my employer makes hundreds of products that almost always are sterile when used, but that we sell in both sterile (individually pouched) and non-sterile (usually bulk packed) form. We also have a few products that are usually used sterile, but that for some reason a particular customer wants to buy non-sterile in pouched form, appropriately labeled of course.
Our take on "need for sterility" as "what the responsible physician, or persons acting under his or her authority, wants or expects to buy".
Because of that, we don't distinguish in our design control procedures as to what products must be sterile when sold. We do, on the other hand, determine as an element of design control whether a product must be able to be sterilized.
Hypothetically I could imagine a scenario in which we might make a product that by its nature could not be effectively sterilized after manufacturing, and for which we had a high level of confidence that our clinical knowledge was adequate for us to determine that it could never be used safely in non-sterile form. In that case, we might provide high-level pushback if someone tried to obtain that product from us in non-sterile form.
Other than that, we supply what the clinical-user customer wants.
I Do initial importers need a contract with suppliers - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 2
R Quality Manual for Initial Distributors in US - European Mfg'r of Medical Devices Quality Management System (QMS) Manuals 1
Howard Atkins Initial sample approval guidelines - PPAP, FAIR, etc. for medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
A Brexit Mandate for EU Authorised Representative for non medical devices CE Marking (Conformité Européene) / CB Scheme 3
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 0
B Procedure packs with non-medical devices EU Medical Device Regulations 1
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
D Electrical Medical Devices class I EU Medical Device Regulations 0
J Are complaints applicable to development of medical devices? Customer Complaints 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
Brian Benzarti Medical Devices CLP Regulation Quality Assurance and Compliance Software Tools and Solutions 2
dgrainger Informational Medicines and Medical Devices Act 2021 UK Medical Device Regulations 0
B Free Sales Certificate for Non Medical Devices Other Medical Device Related Standards 2
K Usability for custom made medical devices IEC 62366 - Medical Device Usability Engineering 5
dgrainger Informational MHRA - Regulating medical devices in the UK - Post Brexit - 2021-02 UK Medical Device Regulations 0
M Europe GMP medical devices - Combination products - Ancillary medicinal substance CE Marking (Conformité Européene) / CB Scheme 4
L Shelf life of medical devices Other Medical Device Related Standards 4
M Medical Devices - Ancillary - ISO 10993-17 Medical Device and FDA Regulations and Standards News 6
S How is the service life for class I reusable medical devices described in MDR? EU Medical Device Regulations 7
S How is the service life described for class I reusable medical devices in MDR? Elsmar Xenforo Forum Software Instructions and Help 1
M Brexit The Medical Devices (Amendment etc.) (EU Exit) Regulations 2020 UK Medical Device Regulations 1
P New Global HQ Suggestions for Virtual manufacturing/own brand labelling of medical devices? EU Medical Device Regulations 4
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Subcontracting a repair of Medical Devices Canada Medical Device Regulations 0
S Regrind Material in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 1
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
P Monolithic application and medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
N Medical Devices in oxygen rich environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Medical Devices Shelf Life ---INDIA Other Medical Device Regulations World-Wide 3
JoCam Warranty of Medical Devices EU Medical Device Regulations 2
R Obsolesce medical devices ISO 13485:2016 - Medical Device Quality Management Systems 1
dgrainger Informational UK - Medicines and Medical Devices Bill 2019-21 UK Medical Device Regulations 0
S Call it refurbish or not? Medical Devices Manufacturing and Related Processes 2
C Registering Medical Devices in Australia and New Zealand - ANZTPA Other Medical Device Regulations World-Wide 0
S Requirements for "Claims Guide" for medical devices Medical Device and FDA Regulations and Standards News 6
C FDA Establishment registration - Buying some medical devices from another manufacturer Medical Device and FDA Regulations and Standards News 5
G Accelerated stability of medical devices Other Medical Device Related Standards 1
A Medical Device Vigilance decision tree for Japan for class 2 devices. Japan Medical Device Regulations 1
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
G Free Sales certificates for Medical Devices - List of countries EU Medical Device Regulations 4
dgrainger Informational Parliament to vote on postponing new requirements for medical devices -17th April Medical Device and FDA Regulations and Standards News 1
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Who needs a MDEL? How to buy and sell medical devices on my own Canada Medical Device Regulations 14
D Social Media Feedback process for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
