Medical Equipment in Simulated Animal Enclosures
Roland chung
Hi forum,
Test laboratory just declined our CB application for a home use nebulizer shaped like a panda.
The reason is that IEC 60335-1 (household appliance) does not allow the equipment to shape the enclosure like a toy. Although, the IEC 60601-1-11 does not address cases where the device is designed to look like a toy. It is not convincing that the "children playing" is an unacceptable risk for household appliance, but an acceptable risk for home use medical device.
Should be grateful for your advice, if any.
Peter Selvey
The test lab's concern sounds reasonable.
Technically, the manufacturer should have documented the issue in the risk management file. If was not in the file, that's already a bit of a red flag since since it is a fairly obvious misuse.
Regardless, once it is in the file, the manufacturer will have to look at the various possible event sequences, assign probability and severity numbers, and judge if the risk is acceptable. As it is a critical point, these details (both sequences and numbers) would need to be plausible and realistic.
A nebulizer is a lower risk device than most household appliances, so there is a faint possibility that it works out OK (acceptable risk). But the high probability of misuse makes it hard to justify even low severity events.
Roland chung
Thanks, peter.
It would be difficult to assign plausible probability and severity numbers. If the conclusion of usability validation in a simulated use or actual use environment is positive, can the risk be considered acceptable?
Peter Selvey
For usability, real user testing is a actually a weak verification tool as mentioned in the rationale of IEC 62366. It's hard to get enough data to be statistically relevant. Instead usability is mostly about adding common sense usability related specifications like on a touch screen having user buttons with a minimum size and space from other buttons, touch gives user feedback within 0.1s; verification then just checks these usability related specifications have been implemented.
Following that thinking, a common sense usability specification might simply be "don't make it look toy" :)
Apart from the possible damage if a child mistakes it for a toy (e.g. playing somehow influences the effective delivery of medication), to prove it is safe a manufacturer would also need to study the standards for toys as they will raise a lot of special issues e.g. small parts, toxicity and so on.
I think it is a big task and there is a high chance the end result is that some problem is raised that clearly kills the idea (risk is unacceptable).
That's why IEC 60335 applied a "blanket rule" to ban appliances looking like toys.
Roland chung
I agree with your points. But the team said neither IEC 60601-1 nor IEC 60601-1-11 bans this design. The Philips "Sami the Seal" nebulizer is shaped like a seal to attract children.
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
R Classification of USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
D Software validation in Medical Equipment Other Medical Device and Orthopedic Related Topics 20
A Handling of contaminated medical equipment Other Medical Device and Orthopedic Related Topics 0
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
K USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Medical device development - Custom test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
E Multiple socket-outlets - Medical Device Electrical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Airborne Medical Equipment EMI/EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E Doubts about the FCC regulations for the use of Bluetooth in medical equipment Other Medical Device Related Standards 3
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Functional connection between ME and non-medical equipment in different rooms IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R IEC 60601-2-18 Endoscopic Medical Electronic Equipment question IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Is EN ISO 10079-1 same as YY 0636.1? (Medical Suction Equipment) Other Medical Device Related Standards 1
O F-typed isolated barrier of medical electrical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Strategy to allow for OTS computer use as part of a Medical Equipment System EU Medical Device Regulations 14
S Import of Medical Equipment into Cambodia Other Medical Device Regulations World-Wide 1
L Medical Device Manufacturing Equipment Design Other Medical Device Related Standards 2
T What is Medical Device Classification for diagnostic equipment in ASEAN ? Other Medical Device Regulations World-Wide 2
Marc Medical Equipment Inmetro Certification Process in Brazil - Part 2 Other Medical Device Regulations World-Wide 3
2 High-tech medical equipment to reduce medication errors Medical Information Technology, Medical Software and Health Informatics 5
thisby_ Medical Device Battery Powered Equipment connected to Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Options for OTS Computer as part of Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Is this Medical Equipment System or ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Cl 5.7 Humidity preconditioning required for all Medical Electrical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Testing to clause 15.4.6 - Actuating parts of controls of Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I IEC 60601-1 Least Favourable Working Conditions for Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Medical Device Manufacturer Demonstration Equipment Other US Medical Device Regulations 6
E Does R&D Equipment in Medical Device Industry require IQ/OQ Qualification and Validation (including 21 CFR Part 11) 9
P Amendment 1 to 60601-1, 3rd Edition Medical Electrical Equipment Standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Is our equipment a Medical Device under US regulation ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R Should be Hospital Grade Plug be used in Class II Medical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Confused about application of ISO 13485 - Manufacturer of Medical Equipment & Device ISO 13485:2016 - Medical Device Quality Management Systems 14
G Old Medical Device Equipment - Compliance with New or Old Standard - What to do? Other Medical Device Related Standards 3
R Is FCC required for Medical Equipment without Radio Frequency Energy? Other US Medical Device Regulations 6
J Marking (Labeling) Requirements on Medical Equipment per IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K Using a Circuit Breaker instead of Fuses in Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Testing Medical Equipment used in conjunction with Oxygen Rich Environments IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Where does the definition of ME (Medical Electrical) Equipment originate? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
F Help with Electrical Safety Testing - Medical Equipment Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
P ESD and Bio-Hazards in a Medical Equipment Repair/Maintenance Facility Manufacturing and Related Processes 2
M Medical Diagnostic Equipment Control Computer Repair Other US Medical Device Regulations 3
C Safe Handling of Non-Device Refurbished Medical Equipment US Food and Drug Administration (FDA) 3
