Medical Equipment Low Voltage Air Pumps
raymond02302
Hello every fellows,
There are Low voltage(DC Voltage) powered air pumps in some medical equipments for its function (such as NIBP measurement etc.). It is commonly used in secondary circuit, the only hazard it maybe causes is heat and temperature. So, we can do the temperature test in normal condition and SFC( block pump ventilation hole).
Is analysis right ?
There is no temperature limit in the manufacturer 's sepecifiction or in the standard(IEC 60601-1), therefore, how can we determine the result for the test?
Or, we can do nothing for it just regarding the air pump not critical component
Any fellow has idea for it ?
thanks in advance.
Marc
Re: What should be concerned about Low Voltage Air Pump
Another quick "Bump". My Thanks in advance to anyone who can help with this one.
Peter Selvey
From a normal condition (NC) point of view it is common that test labs attempt to measure the temperature of secondary motors by simply placing a thermocouple on the outer case. But, this is somewhat useless as the case temperature is not reflective of the winding temperature, and to measure the winding temperature would would be very difficult.
The focus on windings is a hangover from primary (mains) circuit testing: primary windings often work directly off the mains supply which is unregulated, and to limit weight (core material) they are often run close to the temperature limits at the extremes of supply voltage. Plus they usually contain safety related insulation (pri/sec; mains/earth). Thus every winding needs to be closely checked.
Secondary components operate off regulated circuits and are usually low power. They rarely run close to temperature limits. And, they don't contain safety insulation. So, an air pump used within it's ratings (voltage, pressure etc), would have no justification for checking the winding temperature under normal condition.
For secondary motors under single fault condition (SFC), the key point is fire. For this the standard (3rd edition) gives three effective options:
1) confirm < 15W or 900J avaliable in NC/SFC
2) confirm PCBs, wiring, connectors are flame proof, or
3) do SFC tests (i.e. locked rotor)
Use the option that is the easiest. If it is a simple DC motor, it may be possible to measure the resistance of the winding and use V-squared-R to confirm that 15W is simply not possible. Example: 12V motor, 10 ohm winding = 14.4W, no further action required.
And, it is normal that PCBs, wiring and connectors are flame proof anyway. If so, no further action.
Finally, many dc motor such as fans are easy to lock, and control circuits include overcurrent and locked rotor detection. So, it may be just a quick test.
For a air pump this may be difficult to access the "rotor" (or moving part). Just blocking the outlet is not locking the moving part. So, it is most likely to use (1) or (2).
raymond02302
Thanks for peter selvey's suggestion and interpretation.
one question i have faced is that the power of air pump is more than 15 W. On your stand of point, the only way to evaluate the pump is locking the rotor, should i think of it? but doing this is very diffcult.
Thanks and best regards
Peter Selvey
There is still the option (2) above to confirm that PCBs, wiring, connectors and nearby enclosures meet the requirements in 11.3 (e.g. are FV-2 + other fire enclosure requirements).
If Clause 11.3 is met, and there is no safety insulation involved, there is no need to perform fault tests.
But, since the pumps are low cost, it may also be an option to pull one apart and lock the moving parts. Air pumps sometimes don't have rotors, just a kind of solenoid part that moves back and forth.
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
R Classification of USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
D Software validation in Medical Equipment Other Medical Device and Orthopedic Related Topics 20
A Handling of contaminated medical equipment Other Medical Device and Orthopedic Related Topics 0
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
K USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Medical device development - Custom test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
E Multiple socket-outlets - Medical Device Electrical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Airborne Medical Equipment EMI/EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E Doubts about the FCC regulations for the use of Bluetooth in medical equipment Other Medical Device Related Standards 3
K Difference between Medical Electrical Equipment and Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
F Functional connection between ME and non-medical equipment in different rooms IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Medical Equipment in Simulated Animal Enclosures IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R IEC 60601-2-18 Endoscopic Medical Electronic Equipment question IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Is EN ISO 10079-1 same as YY 0636.1? (Medical Suction Equipment) Other Medical Device Related Standards 1
O F-typed isolated barrier of medical electrical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Strategy to allow for OTS computer use as part of a Medical Equipment System EU Medical Device Regulations 14
S Import of Medical Equipment into Cambodia Other Medical Device Regulations World-Wide 1
L Medical Device Manufacturing Equipment Design Other Medical Device Related Standards 2
T What is Medical Device Classification for diagnostic equipment in ASEAN ? Other Medical Device Regulations World-Wide 2
Marc Medical Equipment Inmetro Certification Process in Brazil - Part 2 Other Medical Device Regulations World-Wide 3
2 High-tech medical equipment to reduce medication errors Medical Information Technology, Medical Software and Health Informatics 5
thisby_ Medical Device Battery Powered Equipment connected to Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Options for OTS Computer as part of Medical Equipment System IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Is this Medical Equipment System or ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Cl 5.7 Humidity preconditioning required for all Medical Electrical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Testing to clause 15.4.6 - Actuating parts of controls of Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I IEC 60601-1 Least Favourable Working Conditions for Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Medical Device Manufacturer Demonstration Equipment Other US Medical Device Regulations 6
E Does R&D Equipment in Medical Device Industry require IQ/OQ Qualification and Validation (including 21 CFR Part 11) 9
P Amendment 1 to 60601-1, 3rd Edition Medical Electrical Equipment Standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Is our equipment a Medical Device under US regulation ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
R Should be Hospital Grade Plug be used in Class II Medical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Confused about application of ISO 13485 - Manufacturer of Medical Equipment & Device ISO 13485:2016 - Medical Device Quality Management Systems 14
G Old Medical Device Equipment - Compliance with New or Old Standard - What to do? Other Medical Device Related Standards 3
R Is FCC required for Medical Equipment without Radio Frequency Energy? Other US Medical Device Regulations 6
J Marking (Labeling) Requirements on Medical Equipment per IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K Using a Circuit Breaker instead of Fuses in Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Testing Medical Equipment used in conjunction with Oxygen Rich Environments IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Where does the definition of ME (Medical Electrical) Equipment originate? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
F Help with Electrical Safety Testing - Medical Equipment Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
P ESD and Bio-Hazards in a Medical Equipment Repair/Maintenance Facility Manufacturing and Related Processes 2
M Medical Diagnostic Equipment Control Computer Repair Other US Medical Device Regulations 3
