Hello all,
I was looking in the forum because there are so many medical device topics using a USB interface. Unfortunately, I'm not sure if I was able to answer my own question. Your help would be much appreciated.
We have a watch that contains an electrode (ECG measurement) on the wrist side. So, definitely, it would be a CF applied part. There is only one interface in it, the USB connection that will allow charging a lithium battery and the USB interface to transfer data from the device. The device is intended to be self-powered while being in use.
I intended to provide a certified external AC-DC power supply, 2 MOPP compliant for charging the device. For the data transfer, it would require the watch to be connected to a PC.
The way the connection is located will prevent the patient from using it while the watch is charging. We intend to use some pogo pins connector to reach 4 exposed pads under the watch (+5, GND, D+, D-). However, the electrode could still be reached if used during the charge.
I'm trying to keep the watch as small as possible.
Here my questions,
1- Knowing that the personal computer should at least be compliant with IEC 60950-1, I presume that we still have to have one MOPP between the electrode and the USB connection?
2- If I'm able to hide the electrode underneath the watch while charging it completely, should it be enough to remove the need for additional isolation?
3- If I replace the USB data transfer with a Bluetooth connection and use a connector for a dedicated power inlet with a medical-grade PSU, it would be the easiest solution, I presume?
Thank you for your help !
Here my questions,
