N
n25philly
OK, here is the deal, the company I work for is a small precision machine shop doing mostly aerospace work. We already got our Rev C certification last year on a surveillance audit. Up until that point every auditor we've had come in has pretty much audited us completely on compliance. As long as everything in our book matched the requirements and we did what we said we did everything was good.
We have two major problems (not findings, but could turn into them if not addressed) that we need to straighten out for our next audit. #1 is out interaction of processes. Well, we've neverlooked at this from a true process standpoint (hell, we were ISO long before we got AS9100 and no auditor even looked at our interaction of processes until our first AS audit) and apparently it is wrong. Our original Interaction of processes was basically a listing of all of our procedures that was put into a flowchart that showed how work flowed through our shop. That did the job until this last audit. This time we were told any process we have needs to be measurable. Well, it's been more than half a year since the audit and I am still lost on the Interaction of processes. It seems the more I read about it the more confused I get. Can someone point me in the right direction? I don't know how to post files here, but I am certainly willing to provide copies of the old IOP and attempts I've made to revise if it helps.
The second issue I have is with internal auditing. I think it ties into the other problem as we were told that we are auditing wrong in the last audit as we are not auditing processes. The way that our audits work is that we would take each of our processes, and for each other we had a matrix that identified every paragraph in the procedure applied to it. Auditors needed to go into the procedure and the actually work being done involved with the procedure and identify that those requirements were being met as well as making observations on how effective they are. The audits are then reviewed by another auditor to verify that the requirements are met and that the auditor doing the audit provided significant evidence.
I can see how this method of auditing is not enough as by auditing every single procedure individually, it creates an audit nearly every single month (23 procedures, 3 full order audits, and 1 shop floor audit) as there are only three of us on the auditing team and we all have enough other works that it becomes overwhelming. Two of our findings on the last audit were things that should have been caught on internal audits. I think the audits would work better in process audits if they work they was I think they do (for example auditing quality assurance as one audit instead of inspection, control of non-conformities, and calibration as separate audits) I just need to figure out how we are supposed to do that. Should we be using PEARs or is that just for the auditors coming in?
I'm not looking for anyone to do this for me. I just want to get pointed in the right direction. Our next surveillance audit is in October so I need to get these things moving, but the more research I do I only get a bigger headache as it seems no one can give a straight answer on anything. It certainly doesn't help that whenever I start researching as soon as I seem to get anywhere I get pulled away for days to weeks and end up having to start over.
Any help that can be provided would be very, very much appreciated.
