Mentioning Special Characteristics in SOP
Casana
Blueberry Nut
It was identified during an internal audit that our procedures are not compliant with IATF 16949 8.3.3.3 requirements regarding special characteristics… specifically the procedures do not identify them directly. For reference, here’s a snip from the standard:
"The organization shall use a multidisciplinary approach to establish. document, and implement its process(es) to identify special characteristics, including those determined by the customer and the risk analysis performed by the organization, and shall include the following:
  1. documentation of all special characteristics in the drawings (as required), risk analysis (such as FMEA), control plans, and standard work/operator instructions; special characteristics are identified with specific markings and are cascaded through each of these documents;"
All I can come up with is maybe including a line item in the WI stating that Special Characteristic X is affected by this procedure… will that do?
How are others documenting this requirement?
John C. Abnet
Teacher, sensei, kennari
Good day @Casana ;
Are you SURE your organization does not identify special characteristics? Since you reference IATF 16949 , I'm going to assume your organization is certified. What about in your control plans? How is that information carried to point of work? (i.e. how is the associate and supervision made aware so that there is an opportunity for them to escalate properly/uniquely when there is a problem related to a special characteristic?
However, your organization chooses to do this, don't do it in a manner that simply satisfies an 'audit". Do it in a manner that is sustainable and BENEFITS your organization. Be selfish.
Hope this helps.
Be well
Sebastian
Not going into much details, let's take an example.
Internal diameter 50 is a special characteristic.
It is identified with "!" symbol in certain PFMEA and control plan lines.
In control plan column "Control method" within line for internal diameter 50, you have reference to work instruction used for inspection of this characteristic.
This work instruction has to have "!" symbol next to area where wording "internal diameter 50" is.
In rare cases, when company has know how and ability to match product characteristic with process characteristic, it can identify also process characteristic with "!" symbol.
In this case it could be tool external diameter 50.
Tool capability to produce good parts is controlled through maintenance.
One of inspection items within maintenance standard is measuring this external diameter.
This maintenance standard has to have "!" symbol next to area where wording "external diameter 50" is.
Purpose is make staff aware of some items more important than others and send a message "hey look, there is "!" symbol in document, it is special characteristic, stay focused."
Casana
Blueberry Nut
Thanks for all the comments!
John C. Abnet – yes, you are correct that we already include the SC in the PFMEA & the CP. What was confusing me was the need to *also* include it in the Work Instructions.
Sebastian- thanks for clarifying the requirement in your comments. I’ll have to think on how to implement since (to be honest) I see absolutely no value to including a “!” in the work instructions for our product other than paperwork and making the auditor happy. I can tell you the operators are going to ignore it b/c they are going to follow the WI the same way whether there is a ! there or not.
But your comments will help in doing that at least! :LOL:
John C. Abnet
The purpose is to ensure that the special characteristic is identified at the point of work. If it is only in the "office" documentation, then what will cause the team on the production floor to recognize any potential unique requirements of those with "special characteristics" ? How will the team on the floor be aware if they are not identified at point of work?
Let's switch gears and talk about 4.4.1.2 Product Safety for a bit. It is common for characteristics related to product safety to ALSO have a special characteristic applied. Product Safety 'likewise" has a requirement for, (as applicable) for ..identification and controls at the point of work" . How does your organization currently manage that? I found that there is usually overlap, and, therefore, instead of creating new/separate approaches...a common approach often works well.
The point in all of this is that the production floor can not initiate any specially required controls, actions, escalation, etc...unless THEY are aware. Food for thought.
Hope this helps.
Be well.
J Special Characteristic Symbols On FCA Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
L CQI-30 Special Process: Rubber Processing System Assessment - Mixing & Molding IATF 16949 - Automotive Quality Systems Standard 4
V Sample Size rationale to reduce size and use special levels EU Medical Device Regulations 6
Z 10993-7 Special Populations and Area Other Medical Device Related Standards 1
S Defining special characteristics beyond customer drawing FMEA and Control Plans 11
N 8.3.3.3 Special characteristics - Auditor said we are required to create our own, if no customer char. exist. IATF 16949 - Automotive Quality Systems Standard 10
G Special needs operators : how to treat trainings and etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Traditional or Special 510(k) US Food and Drug Administration (FDA) 7
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Contact with special interest groups IEC 27001 - Information Security Management Systems (ISMS) 1
B SPECIAL PROCESS VALIDATION & REVALIDATION Qualification and Validation (including 21 CFR Part 11) 5
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Special Controls and Standards Other US Medical Device Regulations 0
A Special Characteristic question from Automotive CSR Customer and Company Specific Requirements 9
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
John C. Abnet Special Status Notification IATF 16949 - Automotive Quality Systems Standard 1
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 18
A IRIS audit - Discussion about Special Processes General Auditing Discussions 11
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 9
B AS9102 - 3D printing a special tool required for assembly (counterfeit risk?) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Nihls MSA Study Type 2 (special conditions ) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
S Special 510(k) for orthopedic implant 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Riveting - special process Manufacturing and Related Processes 12
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
L Special Processes for SERVICES AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K PSA Special characteristics Customer and Company Specific Requirements 0
Watchcat Advantages to pursuing a Special 510(k) instead of a Traditional 510(k) Other US Medical Device Regulations 5
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
M Special Controls and Class II Medical Devices Medical Device and FDA Regulations and Standards News 18
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 12
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
F Replacement Bone Screws - Traditional 510(k) or Special 510(k)? Other US Medical Device Regulations 7
F Assignment of Special Characteristics to government regulations IATF 16949 - Automotive Quality Systems Standard 5
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
S VW Special status condition IATF 16949 - Automotive Quality Systems Standard 3
