Merging of Quality Management of 3 Business Units
N
nidhir
I work for a company which manufactures and distributes consumer and industrial chemicals. I am responsible for the quality management system.
We form part of a group which has several other companies which deals in the chemical business.
In line with a clustering of these businesses under one hat, I have been asked to look after the QMS the 3 companies and to provide a plan.
Now each company has undergone ISO 9001:2008 certification. Two of the businesses do not have a dedicated quality team. Its more like the production manager looking a bit after quality.
Each of the company has its own quality policy and so on.
So I would like some guidance on how I could go about this.
I already have a meeting scheduled with each of the company MRs to understand their processes and so on.
Please help.
thx
somashekar
Simple. Decide which is your central location or the Lead site. Define its activities of the ISO 9001 QMS. These will be the central functions, and the lead site will deploy them across all other locations. Now the other companies are remote sites. Define its activities of the ISO 9001. These will be common functions documented, implemented and maintained at these sites. Now decide how the interactions and communications between the lead site and remote sites are established.
I have a draft GHTF guideline about multisite auditing for medical device manufacturers, however it can give good inputs to your proposed multisite QMS. Hope it is helpful. Find same attached.... Good Luck.
As it happens, I have similar issues at hand. Our comparatively small site is part of a large group where all the sites have built their own systems. We are now set to integrate them (which is part of the reason for my current abysmally low post count :notme: ). Anyway, as somashekar says this should not be too tricky (though it does create a lot of work). In our case the top documents will be owned by corporate management.
This is also an opportunity for improvement: Comparing different systems is bound to reveal good and not so good points in all of them. It is quite possible that you have solved similar issues differently, and now would be a good time to look for and spread best practice.
/Claes
harry
Good advices given so far but from the management aspect, I think you need to look at the 'soft' side of things. What kind of culture exists in each of the 3 sites, how mature are their existing systems? I mean - don't force a marriage, they ought to be ready for it in order for the marriage to work better and last longer.
N
nidhir
Guys,
Thanks so much for great feedback.
2 of the sites have recently been certified with Certifying body X while the other site has been certified 2 years ago with CB Y.
Should all the sites be certified by one same CB?
rgds
Ajit Basrur
Guys,
rgds
Absolutely, that will make your co-ordination easy. In my organization, I did the same and trust me, it reduces pain and headache :)
I couldn't agree more. Different CB's would not be a good idea: There would inevitably be slightly different interpretations and outlooks, and you would find yourself in the middle. Ajit's advice is very sound.
/Claes
suildur
Please help.
thx
As far as I can understand, there are "different" companies under a group, but the top management of the group wants those to be merged or gathered for quality. Then, I would recommend something different.
As there are three different companies and a headquarters for the group, you will implement 4 different management systems anyway. Whether merged or not, first of all, define the processes of the management system of each company/site. Then, decide to merge them or not. Also, keep in mind that, if the legal status of that three company is different, there may be problems in the clauses ISO 9001. I think, you would consult to the certification body, so ask them if they would accept what you think. Because, the certificate is issued to one legal body. (I m a consultant, and, I just had a similiar case last December. I implemented 3 different QMs, but the procedures were the same. However, the scopes of the companies were identical to each other, in my case. Also, the CB(s) may require different QM for each company, as the legal entities are different at all.)
Anyway, after defining the processes for the three sites and the head quarters, just go on with the usual documentation work. You can consider the HQ of the group as the management department and the other three site as sub-departments in a merged system, or, you can consider the HQ as the main company and the other three as suppliers in the non-merged version. In any case, you would clearly identify the needs of the HQ, and define the processes/inputs/outputs of HQ based on those. Because, (I think :D) the HQ/top management will like/see the QMS as a tool for their management activities on the three company, before anything.
And, to make your work easy, I recommend you to act as the quality coordinator, not the QMR of the whole three companies. Authoritize QMR for each company and one for the HQ, and prefer that QMR would be someone different from the top manager of that site (maybe, a sub-manager), then, each QMR would built and implement own QMS and you would coordinate the all work.
Finally, one body would be good for certification of all. However, every audit is also a training. If you have enough resources (especially time and patience :D ), having audited using different bodies at least for the first two years would help you improve your complex quality system. Yes, you will sometimes find yourself in the middle like the other quality professionals told in previous posts, but every risk comes with its own opportunity ;)
N
nidhir
Thank you for this insight.
You are right, the 3 companies have different legal entities.
We will be transfering some manufacturing processes to X, Y or Z so as to have better synergy among the companies.
Handling organisational change will be a major challenge.
Each company has their own policy, Would it be advisable to have a common policy for the 3 companies.
Acting as the Coordinator sounds very practical.
I will definety come back for more feedback/advise.
The cove rocks!
suildur
The cove rocks!
In that case, I would have prefered a non-merged system if I were you. Because, implementing a system has lots of hard paths to walk, and in this case, there are 3 different companies, different manufacturing processes, different managers, different quality cultures and approaches, a separate managing level... The worst thing I always encounter is the human factor; you must achieve the leadership of the top management and the involvement of the people at the same time. When you achieve that, anything comes easy.
In fact, that was the only thing in my mind when I replied in previous post.
Most of the time, people react reverse(?) when you try to implement something new. There are several causes for that but the main causes are:
1. A new system means change: change in the positions, change in the work done, change in the responsibilities... "People fed by the existing system doesnot let the system change." I always take this into account.
2. Human is a rebellious creature. You must let people to feel that the system belongs to them. In other case, you must convince or achieve people that you are doing the right thing and the only thing to be obeyed is what you do or say.
3. On the other hand, people are really easy going. If you convict others that you are the only one to be listened or obeyed to, then they willnot even move their finger without you saying them to do.
So... It is a very thin line to implement and sustain a "working" quality system. That's why I say to implement separate systems within each site and HQ with 4 QMRs and a QMS coordinator. Yes, there are identical documents, processes, but different people will apply those!
If you want to discuss more, send me a message with your questions/problems, I will be returning a reply soon.
M Merging Two Quality Management Systems when a Company is Acquired Misc. Quality Assurance and Business Systems Related Topics 8
J Merging EMS (Environmental Management System) with QMS (Quality Management System)? Miscellaneous Environmental Standards and EMS Related Discussions 9
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
M 2 Quality Manuals after merging with another company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
howste Merging sites on one AS9100 certificate - expiration date? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Merging Post Market Surveillance and Complaint Handling ISO 13485:2016 - Medical Device Quality Management Systems 3
P Merging 2 sites into 1 new site and certifying product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Merging Companies - Companies acquiring other companies that are not ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P ISO 9001 and flat pack 'New Company' (Two companies merging) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Merging multiple systems into one ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Document Control - Merging two Document systems (small company incorporated)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
RoxaneB ISRS Rev. 6 - Any advice on implementing and/or merging with QMS/EMS? Various Other Specifications, Standards, and related Requirements 4
H Merging Companies & Compliance Misc. Quality Assurance and Business Systems Related Topics 3
G Merging of 2 Registrations Registrars and Notified Bodies 2
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
D Quality plan for moving locations ISO 13485:2016 - Medical Device Quality Management Systems 3
was named killer Job Opportunity-Quality Engineer-Tampa Florida Job Openings, Consulting and Employment Opportunities 0
Marc Job Opportunity – Quality Assurance Specialist - Suspense 7 April 2021 Job Openings, Consulting and Employment Opportunities 0
J Quality Objective for QMS prior to Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
C Budgetary cost to obtain ASME NQA-1 Quality Program Certification Quality Management System (QMS) Manuals 0
O Soft and technical skills for a VP of Quality Career and Occupation Discussions 1
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
M Unique Quality Management System for 2 sites ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Application to Chartered Quality Institute - MCQI ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
K Quality Agreement MDR - The manufacturer is outside of EU Other Medical Device Related Standards 4
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
T 21 CFR 820.20 - Quality Planning Requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Supplier protocol for the Quality Supplier Quality Assurance and other Supplier Issues 6
bruceian Software Quality Metrics Software Quality Assurance 11
R Quality System Functional Safety Checklist / Guidance IATF 16949 - Automotive Quality Systems Standard 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
optomist1 Automotive News The Cost of Inspecting In Quality IATF 16949 - Automotive Quality Systems Standard 7
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
John Broomfield CIOB - Code of Quality Management Misc. Quality Assurance and Business Systems Related Topics 1
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
D Are Supplier Quality Agreements Quality Records ? Other Medical Device Regulations World-Wide 9
D Big companies suffer from quality management system? ISO 13485:2016 - Medical Device Quality Management Systems 1
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
Pau Calvo Quality Management process is mandatory in ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
NDesouza No Quality Professional vs Having a Quality Professional Benchmarking 24
