Metal Scale (SIP-Societe Genevoise) change in size over time?
greif
I have a 400 mm scale that came from a SIP MU-214 measuring machine (vintage 1960). It is steel about 20x20mm square with a slightly recessed area on one side which has very fine engravings every mm.
The original calibration data says the max deviation for this scale was 0.7um, when calibrated by SIP in 1960.
I have sent this off to be calibrated by an ANAB accredited cal lab and they have given me a preliminary report of a reasonably gradual stretching of dimensions, ending at 400.019mm
Original SIP cal was at 20 C, the new cal was at 69F.
Is it possible a chunk of steel would grow by 19 microns in 400mm?
Seems like an awful lot.
Ninja
Looking for Reality
Not an answer, but some perspective...
depending on the type of steel...let's say TCE is ~6.5x10^-6 mm/mm/F
Let's say that 20C = 68F...the one degree F difference across 400mm is ~3um all by itself.
How accurate is the temp each time? another 3-5um worth?
How much error reported in the measurements in 1960 and today?
And lastly...19um on a scale with engravings every mm across 400mm is not so bad...especially when your markings are only every mm.
It would be interesting to see how much error there is between marking pairs...
greif
The uncertainty reported with the prelim 2016 report at 400mm was 2.5um.
The original SIP report did not state uncertainty. The chart was in the form of a correction to be made with each mark (add or subtract), in tenths of microns.
The SIP manual states the thermal expansion of the scale and for the difference between 20C and 69F ((0.56C), the scale will be 2.58um longer at 69F.
The guaranteed measurement accuracy of the MU-214B that the scale came from was 2um in 400mm (from their lit.)
Still - 19 um is quite a bit!
Ninja
Looking for Reality
Quite a bit....compared to zero.
does 19um matter for a scale where 1000um is a single tick?
greif
The number of graduations is not particularly important- it is to be used to check the accuracy of various measuring machines...... so the 19um is rather important (at least the determination if it really is off by 19um!)
Ninja
Looking for Reality
Silly question coming...
1. If this is a critical part for machine setup, and
2. has to be accurate to within much better than 19um on 40cm, and
3. has been used since 1960....
Why is it being questioned now?
Point of the question:
If you've been using it since 1960, and 19um is way too much...then you've been making bad parts for 50+ years?
Or if you haven't been making bad parts for 50+ years...19um is really that important?
Easiest solution....buy or make a new one.
greif
"If you've been using it since 1960, and 19um is way too much...then you've been making bad parts for 50+ years?
Or if you haven't been making bad parts for 50+ years...19um is really that important?"
Nope, pretty much been on the shelf and not used since we acquired it. Being such a high quality scale (Swiss!) I would have like to have used it as a handy (unbreakable) check tool.
My concerns are;
-is metal really that unstable?
-Did this accredited lab really do a proper job?
Ninja
Looking for Reality
Ah, understood.
I'm not sure there are really answers to your question...but food for thought...
metal is not unbreakable...especially in the um ranges.
Drop it, leave it in the sun...um is not unreasonable to expect.
for um over 400mm...everything is unstable to some degree, even granite.
When faced with a choice between questioning a current certified lab and questioning "Swiss made in 1960"...I would likely question the 1960 side of things. (All the same, what was the reported measurement error on your recent test?)
HTH
greif
Summary;
SIP cert from 1960 says off ~.4um at 400mm at 20C.
new 2016 cert says big by 0.019mm at 69F
Taking the temp. difference into account (SIP lit states the coef. of exp.), the new cert says it is 16.5um bigger than 400mm.
C Mistake Proofing Winding Direction Stamped Metal Parts Manufacturing and Related Processes 2
O New metal detector, ccp -help! Food Safety - ISO 22000, HACCP (21 CFR 120) 2
A Critical Characteristics - Sheet metal stamping APQP and PPAP 9
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Metal parts bonding/grounding on Class II, internally powered with functional earth? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J ISO 13485 for Metal Finishing Medical Device and FDA Regulations and Standards News 5
A Metal Enclosure Connected to PCB Ground for ESD Reasons IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
K Quality Control/Assurance in the Metal Industry Quality Tools, Improvement and Analysis 10
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
E IEC 60601-1 - Unearthed Medical Device Metal Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
R Statutory/Regulatory for NACE Code 25.9 (Manufacture of fabricated metal products) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Metal Radiographic and Ultrasonic Testing - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Receiving Inspection for Metal Strips & Wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
C DFAR 252.225-7008 - Is aluminum, say T6061, considered specialty metal (i) steel? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Ron Rompen Sintered Metal Machined Parts Rust Removal Methods Manufacturing and Related Processes 8
J Internal PPM's in a medium sized metal stamping plant Quality Manager and Management Related Issues 6
G Metal Stamping Process Audit Questions Manufacturing and Related Processes 8
B Mitigation of emission of flames, molten metal, poisonous or ignitable substance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Control of Metal Plating Baths - Contamination from base metals Service Industry Specific Topics 4
T Technical automotive metal stamping cliffnotes needed! Training - Internal, External, Online and Distance Learning 4
L Caliper Calibration Standards - One for CNC and one for Sheet Metal? General Measurement Device and Calibration Topics 9
E Composites - Metal Bond - Removal of excess film adhesive Manufacturing and Related Processes 1
P Validation of Class I Metal Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
P Testing Zinc Coating on Expanded Metal Manufacturing and Related Processes 7
L Calibration of Metal Rulers General Measurement Device and Calibration Topics 13
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
B Plating Shop - Forums specifically related to the plating / metal finishing industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
H Determining Takt Time in Metal Stamping Lean in Manufacturing and Service Industries 9
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
T Electrical Surgical Tool with Big Metal Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
