Metal Stamping Process Audit / Knowledge required!
CarolX
#11
OK - your torquing a plastic screw into 18 gauge material - frankly, I am not surprised that you are having problems.
I know very little about screws made from plastic, but I am sure that it is much softer than your metal part - btw - what type of material are you using?
Could you have some burring on the threads of the metal part that is cuting into the plastic part?
Could the screws be cross threaded when inserted?
Have you checked both components with go/no-go gages? I would highly reccommend doing this, especially on a defective part.
You stated that you measured the screw - what did you measure? Major diameter, pitch diameter?
Have you considered replacing the threads in the metal part with a threaded insert such as a PEM type nut?
Golfman25
#12
Certainly seems like a design issue to me. The plastic screw is going to loose vs. the metal every time. And plastic threads aren't really the same as metal threads (been down that road). Sounds like you need more holding power. Good luck.
terranceyu
#13
Thanks for the swift response. Please see my reply.
Plastic screw outer diameter tooling insert and actual part was measured by Quick Vision : 2.76 ~2.85 mm. Spec: 2.85 ±0.10 mm. Material : PC Lexan.
The Metal part hole was confirmed with Go-Nogo jig with M3 thread attached to drill press m/c. Metal part attached to the jig for thread checking. All pass.
I do not want to go back to R&D yet, until I confirmed the findings, which is related to weakness of design. FYI, we have been running fine for past several months, and this is the only first issue encountered.
Currently, we have sent the plastic screw for measurement, it is within spec as above said. For metal part with M3 hole threaded as spec, still waiting supplier to actually come back with investigation report.
Any comments?
CarolX
#14
What does "m/c" stand for? Are you checking the threads with a tap or a gage?
I am not familiar with "Quick Vision". Does it check all the thread attributes?
Have you check a "failed" part?
Thread tapping on sheet metal is normally done as a "hand" operation", not in an automated machine. There are a lot of opportunities for mistakes to be made.
alspread
#16
What does this mean? I don't understand the reference to a drill press when checking a thread with a Go-NoGo gage.
Look very closely (10x magnification) at the condition of the hole of a bad part, and a hole before and after threading. The design does not leave you with much material to create a thread (3-5 turns maybe). There could be something left over from the punch press causing an irregular shaped hole (i.e tapered). because the material thickness is so thin it may be difficult to determine how much of the hole many acceptable and how much is questionable.
You mentioned that things were working okay for some period. Maybe another way to attack this is to evaluate any changes during the time the failures occurred.
I'm with CarolX on a couple of ppoints
somashekar
#17
Any comments?
Is the 1.2 thick sheet embossed and then tapped ? This will get you more depth of the hole to have sufficient threads. How does a standard metal screw M3 work in the tapped location ?
Another thought ... Can you use a standard clinch nut of M3 in the 1.2 mm sheet by pressing it into an accurately punched hole in the sheet ?
terranceyu
#18
Quick vision stand for Smart scope, which is non-touch-part approach, different from CMM machine (touch probe concept).
Thanks for your recommendation. I will actually arrange a trip to go to supplier to verify the Go-NoGo-jig condition. It is a good approach to see whether any changes made during the time the failures occured, as this is first time encountered, and the quantity is very less, 1 in 100 pcs.
Any other items I need to watch this?
G Metal Stamping Process Audit Questions Manufacturing and Related Processes 8
V Standard for Metal Stamping Deburring Process APQP and PPAP 5
W Sample of Process FMEA for Progressive Metal Stamping needed FMEA and Control Plans 20
Q Looking for example EC process flow that addresses feasibility - Metal Stamping ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
J Internal PPM's in a medium sized metal stamping plant Quality Manager and Management Related Issues 6
T Technical automotive metal stamping cliffnotes needed! Training - Internal, External, Online and Distance Learning 4
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
H Determining Takt Time in Metal Stamping Lean in Manufacturing and Service Industries 9
C How to Reduce Inspection Frequency in Metal Stamping Company Quality Manager and Management Related Issues 4
T Metal Stamping Defect--Need Help with Corrective Action Manufacturing and Related Processes 5
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Quality Metrics and OFIs in a Metal Stamping Company Manufacturing and Related Processes 7
S Laboratory Scope for a Small Metal Stamping Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Metal Part Identification Methods (Stamping) Manufacturing and Related Processes 7
D Metal Stamping Tooling Transfer Checklist Manufacturing and Related Processes 7
M Product resourcing or transfer Checklist (APQP) to satellite metal stamping facility APQP and PPAP 3
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
H Capability Studies and Monitoring Runs at a Metal Stamping Facility Statistical Analysis Tools, Techniques and SPC 5
H Ink for Stamping P/N and Revision on Metal Parts (instead of labeling) Manufacturing and Related Processes 6
L What to monitor using SPC in Metal Stamping industry Statistical Analysis Tools, Techniques and SPC 4
W PPAP Submission Items - Metal Stamping - Tooling Transfer, Replacement, Refurbishment APQP and PPAP 6
L Beginning SPC data collection: Metal Stamping Company - Need some advice Statistical Analysis Tools, Techniques and SPC 14
B Request: Bare Bones ISO9k2k DESIGN procedure and Forms - Metal Stamping (small) Design and Development of Products and Processes 16
Howard Atkins SPC in Injection Moulding and Metal Pressing/Stamping Statistical Analysis Tools, Techniques and SPC 19
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
R Statutory/Regulatory for NACE Code 25.9 (Manufacture of fabricated metal products) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Metal Radiographic and Ultrasonic Testing - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Receiving Inspection for Metal Strips & Wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
Ron Rompen Help with Corrosion (Humidity) Testing Procedure - Sintered Metal Steel Parts Manufacturing and Related Processes 9
C DFAR 252.225-7008 - Is aluminum, say T6061, considered specialty metal (i) steel? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Ron Rompen Sintered Metal Machined Parts Rust Removal Methods Manufacturing and Related Processes 8
G Metal Scale (SIP-Societe Genevoise) change in size over time? General Measurement Device and Calibration Topics 8
