Metal Stamping Process Audit Questions
G
guzer
Next week I'm going to my supplier of metal stamping parts. I would like to prepare my self before an audit because I have a lot of problems with it.
Do you have any specific questions regarding metal stamping process (process parameters, steps, measurements, controls, maintenance, tools etc.) I was thinking about CQI from AIAG but as far as I know AIAG doesn't have anything about metal stamping
Thank you in advance for your help.
So, you're going to attempt an audit of a process you're unfamiliar with? Can you take someone who knows stamping with you?
dsanabria
When you go to a stamping house, - have you identified the issues that you need to deal with. If not you should.
Are they aware of them or is it a shock visit.:nope::nope::nope:
Note: if you are a newbie to the stamp industries, , the sharks will come out... and if you are nice and able to share your concerns in a professional matter then, they will embrace you.
However, Not sure what you want our help with but share the issues with yus and you suppliers.
G
guzer
Honestly speaking I have been few times in this kind of supplier but I looking for some specific questions, parameters, information etc.. I'm building my question data base.
We have a lot of problem with geometry , curvature and length. Until now I have got couple claims from my customer about that, therefore it need to be solved. They are informed about the audit. I guess that they have a problem with a tool moreover I guess that something can be wrong with process parameters. I was looking for some specific questions regarding stamping without success
dsanabria
I would start with the First Piece Article Inspection Report. If one was required or requested. This would identified that at one time, they were able to produce a sample and that they had an effective process.
The best one that you could do is to bring a bad sample and a good sample and have them explain to you the process.
I could let you know that they will blame the tooling and that it need maintenance and that if it is your tooling, they would expect you guys to fix the tooling or give them a PO to fix it.
Note expect a request in the 5 to 6 figures in USA currency)
When you say you're doing an audit, what does that mean? Are you going in reaction to specific problems, or is this some type of routine QMS audit?
If it's a troubleshooting trip, what are the problems? Why does your company think that an audit will be useful? Tell us more about why you're going and what you're expected to accomplish.
Emmyd
Speaking as a stamper, if you are going to review a specific issue bring a copy of the print, along with good & bad samples. There are many issues that could cause the problems you are encountering. Some of them could include design issues - either with the part, tool or process - some tolerances may be difficult to meet and concessions were given to the supplier; material issues from a supplier; tooling changes; misunderstanding on the part of the designer/stamper/personnel; and/or miscommunication between the customer internally, customer/stamper.
When we have had issues in the past and our customers have come in, we always start with the print and part samples. We discuss what the issues are and share knowledge with each other - you know, not like adversaries, but like actual adults who are committed to resolving the issue. Sometimes, the issues stem from internal communications (concessions were given by the customer without understanding their own processes); material issues caused by a customer directed supplier; tool design/maintenance issues (sorry dsanabria, not always at the customer's expense!). If a change to the tool is requested by the customer to improve the parts, that cost is reviewed with the team.
Biggest advice I can offer - don't go in with an adversarial attitude. Bring data, samples, prints to help define the issues. Listen, ask questions, ask them to walk you through their process, see what they are checking on the first articles, review their PPAP's. If you are truly trying to resolve an actual issue you are experiencing (not nitpicking things for very small improvements), going in with this type of open mind attitude will get you more information and greater cooperation over the long run. :2cents:
paccnc
I agree with Emmyd. I am a stamper as well and we found the same thing about bringing samples of good and bad. Another item you may want to bring if you can is what the assembly or what the stamped part goes with. Our engineers have found that this has been able to resolve the issue once they have seen what the part does.
V Standard for Metal Stamping Deburring Process APQP and PPAP 5
T Metal Stamping Process Audit / Knowledge required! Process Audits and Layered Process Audits 17
W Sample of Process FMEA for Progressive Metal Stamping needed FMEA and Control Plans 20
Q Looking for example EC process flow that addresses feasibility - Metal Stamping ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Critical Characteristics - Sheet metal stamping APQP and PPAP 9
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
J Internal PPM's in a medium sized metal stamping plant Quality Manager and Management Related Issues 6
T Technical automotive metal stamping cliffnotes needed! Training - Internal, External, Online and Distance Learning 4
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
H Determining Takt Time in Metal Stamping Lean in Manufacturing and Service Industries 9
C How to Reduce Inspection Frequency in Metal Stamping Company Quality Manager and Management Related Issues 4
T Metal Stamping Defect--Need Help with Corrective Action Manufacturing and Related Processes 15
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Quality Metrics and OFIs in a Metal Stamping Company Manufacturing and Related Processes 7
S Laboratory Scope for a Small Metal Stamping Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Metal Part Identification Methods (Stamping) Manufacturing and Related Processes 7
D Metal Stamping Tooling Transfer Checklist Manufacturing and Related Processes 7
M Product resourcing or transfer Checklist (APQP) to satellite metal stamping facility APQP and PPAP 3
S Work Instructions Required? Precision metal stamping, cnc machining and wire edm Document Control Systems, Procedures, Forms and Templates 7
H Capability Studies and Monitoring Runs at a Metal Stamping Facility Statistical Analysis Tools, Techniques and SPC 5
H Ink for Stamping P/N and Revision on Metal Parts (instead of labeling) Manufacturing and Related Processes 6
L What to monitor using SPC in Metal Stamping industry Statistical Analysis Tools, Techniques and SPC 4
W PPAP Submission Items - Metal Stamping - Tooling Transfer, Replacement, Refurbishment APQP and PPAP 6
L Beginning SPC data collection: Metal Stamping Company - Need some advice Statistical Analysis Tools, Techniques and SPC 14
B Request: Bare Bones ISO9k2k DESIGN procedure and Forms - Metal Stamping (small) Design and Development of Products and Processes 16
Howard Atkins SPC in Injection Moulding and Metal Pressing/Stamping Statistical Analysis Tools, Techniques and SPC 19
T Accessible metal parts connected to secondary ground IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Metal parts bonding/grounding on Class II, internally powered with functional earth? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J ISO 13485 for Metal Finishing Medical Device and FDA Regulations and Standards News 5
A Metal Enclosure Connected to PCB Ground for ESD Reasons IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
K Quality Control/Assurance in the Metal Industry Quality Tools, Improvement and Analysis 10
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
R Statutory/Regulatory for NACE Code 25.9 (Manufacture of fabricated metal products) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
