Method needed to measure 2000mm lengths to ?0.5mm - Alumin(i)um extrusions
Mezzaluna
Method needed to measure 2000mm lengths to ±0.5mm - Alumin(i)um extrusions
Hello Folks!
Trying to set up a method of controlling the length of alumin(i)um extrusions. These can be anything from 800mm - 2000mm in length. The tolerance specified is +/- 0.5mm. Any suggestions on a measuring device? I don't want to resort to a 2m steel rule bolted to a bench.
The cross sectional dimensions are 20mm X 20mm.
thanks for the help!
Mezz.
Mezzaluna said:
Hello Folks!
Mezz.
If you can develop a method for establishing a repeatable nominal to set the gage to, the Mitutoyo Digimatic Scale Unit would work well. You can program an absolute position into it one time, and it will hold the position even turned off.
See http://www.mitutoyo.com/catalog/pdf/I-22-23-24.pdf
sarasheed
We have procured one Digital Vernier caliper of size 0 to 3000mm from M/s. Trimos.This vermier will be useful for your purpose.
S.A.Rasheed
Paul F. Jackson
Use an beam with a stop on one end and an adjustable test indicator on the other. Master it with artifacts and measure the part at a common stabilized temperature every time or your readings will not repeat.
Wes Bucey
I'm just curious - how many extrusions do you have to measure of a specific size in an order (1? 10? 100? more?)
Depending on the quantity of a size to be measured each time, it does make a difference whether to have "a 2m steel rule bolted to a bench" (I think something more like a variation of miner's suggestion) or to use an instrument like a 3 meter vernier. I wonder about the burr after cutoff - I've seen some "interesting ones." Obviously, you will want to assure the cutoff is square and not slanted - I could envision a piece with a cut NOT perpendicular to the long axis which could be within tolerance along one side of the 2000 mm length and on the other side of the 20 mm width be out of tolerance.
In any event, you will have to have a flat surface to lay the piece on to avoid sag affecting the reading.
M Biological Monitoring Program Environmental Bioburden Test Method Needed ISO 13485:2016 - Medical Device Quality Management Systems 1
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
A Test Method - DIN ISO 1133 for melt flow needed to verify supplier results Manufacturing and Related Processes 1
O HPLC Impurity Method Transfer help needed Document Control Systems, Procedures, Forms and Templates 4
A Training slides on Method validation & Traceability needed General Measurement Device and Calibration Topics 1
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M Test method validation - Is MSA (MSA1, MSA2, MSA3 and linearity) a good solution? Medical Device and FDA Regulations and Standards News 1
Pau Calvo How to motivate colleagues to use 8D method or similar Quality Manager and Management Related Issues 37
M Proper method to test flow of a regulator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
Y Post Market Surveillance Indicators and Analysis method EU Medical Device Regulations 1
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
M Issuing NCR for improper method statement submissions Internal Auditing 10
F Irradiation Sterilization Validation Maximum Dose - VDmax 25 method (ISO 11137) EU Medical Device Regulations 2
I "Method" vs "Process" - Differences Document Control Systems, Procedures, Forms and Templates 33
P Test Method Validation for Tensile Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M Control Method correspondence between PFMEA and CP FMEA and Control Plans 8
qualprod Qualitative or Quantitative? Risk method evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ron Rompen Dual level holes - Measurement method suggestions wanted General Measurement Device and Calibration Topics 9
D Sampling method that is representative of the devices supplied by that distributor EU Medical Device Regulations 5
P Production Line Pump Cleaning Validation Method Question Qualification and Validation (including 21 CFR Part 11) 0
A Risks related to Method Validation and Stability Studies Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
qualprod ISO 9001 Risk control method - What could be the better way to control risks? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Ford Method - Position Capability with MMC Modifier Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Inspection method for T10 Hex driver General Measurement Device and Calibration Topics 13
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Stakeholder analysis Method Six Sigma 1
T ER Checklist - Method(s) of conformity EU Medical Device Regulations 1
T ISO 17025 Method Verification - One sided “F” test or two sided “F” test ISO 17025 related Discussions 1
B Dosimeter Calibration Method General Measurement Device and Calibration Topics 5
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
T Method to assess Measurement System of a Continuous Process Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
