Methods in Measuring Angles or Checking Angles for tools?
E
Edgarf
I have a tool that needs angle to be calibrated,i have attached a simple drawing.
Can anyone give their ideas on checking angles for tools?
I've tried calculating the measurements in reverse,although i was able to get the angle,I want to know how the experts do it.
Thanks for replies.
bobdoering
Stop X-bar/R Madness!!
CMM, optical Comparator, Sine Bar or angle blocks...just depends on the budget and availability. Biggest problem? Getting your 10:1 resolution at 0.01 degree. Need to measure at .001 degree. That is incredibly tight. I guess it is about 4 seconds (angular) resolution.
I
iamtroll
If you really mean calibration and not just measurement, you would probably use an autocollimator and also the angle surface for flatness with an optical flat.
bobdoering
The digital protractors from Insize only have a 0.1 degree resolution. Even those are not "good enough".
bobdoering
It is best to you can measure directly, if possible. You eliminate possible calculation error. Every calcualtion and additional measurement step is a potential, additive probability of cause for error.
BradM
It is best to you can measure directly, if possible. You eliminate possible calculation error. Every calculation and additional measurement step is a potential, additive probability of cause for error.
That's true. Good points.
However... sometimes we take what we can get. :D
I had a task of verifying a tool once with lengths and angles. I didn't have the correct equipment to accurately measure the angles. I could measure the lengths fairly accurately. It wasn't the best process, but it sufficed. :)
David-D
I tHink the first question that really needs to be asked is how big is the part? Is it 1 inch? 1 foot? 1 mil? Depending on the size/scale its going to be a significantly different problem. Also, what is the shape of the tool? Rectangular (w/ a flat reference surface)? Round/cylindrical? I'd think it makes a big difference trying to make the measurement. Also, for all the accuracy being called for, I'm a bit surprised it isn't specified with GD&T.
David
Mikey324 Testing Methods to Qualify Operators (Measuring Devices) Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Discrepancy Costs Measuring Methods - Excel spreadsheets or other methods Quality Tools, Improvement and Analysis 3
P Methods for Measuring Cycle Time in Assembly and Machining Activities Manufacturing and Related Processes 4
J Measuring the progress of Continuous Improvement Program - Methods and Criteria used? Lean in Manufacturing and Service Industries 6
J Objective Methods of Measuring for Employee Of The Month Awards Career and Occupation Discussions 8
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
S EU MDR Annex XIV - Clinical Evaluation Plan - What do these methods mean? EU Medical Device Regulations 16
O Software development plan : development methods IEC 62304 - Medical Device Software Life Cycle Processes 2
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
M Informational US – National Evaluation System for Health Technology Coordinating Center (NESTcc) Solicits Public Comments for Data Quality and Methods Frameworks Medical Device and FDA Regulations and Standards News 0
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
D Do Test Methods completed to a standard require validation? ISO 13485:2016 - Medical Device Quality Management Systems 7
qualprod Methods to Calculate Available Production Rate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
S Methods to reduce relative humidity in Datacenter IEC 27001 - Information Security Management Systems (ISMS) 3
K Alternate Control Methods (IATF 16949 Cl. 8.3.6.1) IATF 16949 - Automotive Quality Systems Standard 1
H ISO13485:2016 Measurement System - Methods General Measurement Device and Calibration Topics 4
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S CAPA Investigation Methods Nonconformance and Corrective Action 3
A Monitoring and Measurement Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R OSHA - How often an employee needs to be Re-Trained on Safety Methods Occupational Health & Safety Management Standards 4
Ron Rompen Sintered Metal Machined Parts Rust Removal Methods Manufacturing and Related Processes 8
B Gage R&R MSA - Variation, Tolerance, Variance by different methods IATF 16949 - Automotive Quality Systems Standard 23
X Acceptable methods to store and archive records ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Rapid screening methods for antibiotic residues in Chicken Meat Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A What are methods and tools to measure Workload analysis ? Human Factors and Ergonomics in Engineering 1
Q Management Review - Alternative methods Management Review Meetings and related Processes 20
Gman2 Control of Records - Lets talk about modern methods Records and Data - Quality, Legal and Other Evidence 5
R Gage Identification Methods in a Job Shop Calibration Frequency (Interval) 8
K Control Plan vs PFMEA Control Methods FMEA and Control Plans 1
S Consolidation of Testing Methods Using Minitab Software 3
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
O Automotive Physical Testing Methods (Norms) and Requirements Various Other Specifications, Standards, and related Requirements 1
M Practical Methods using Sampling by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Are 'Error Proofing Methods' required to be mentioned in Control Plans? FMEA and Control Plans 7
D Hotplate Temperature Verification Methods General Measurement Device and Calibration Topics 5
S Methods used for Preservation of Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 5
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
H Methods to Ensure that we are Purchasing what we've Designed Benchmarking 16
M Difference B/W Calibration Methods & SOPs General Measurement Device and Calibration Topics 4
drgnrider Internal Auditor Evaluation Methods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
