Metric/Way to show how Internal DPPM and External DPPM relate to each other
MattB1shop
I am trying find an easy metric/way to show how internal DPPM and external DPPM relates to each other.
IMO you would like to see Higher Internal and a Lower External. Then slowly perform Root Cause Analysis to lower the Internal without effecting External.
Also,
What would be a good goal for Internal.
Company Info: Wire Harness Manufacturer
William55401
Re: Internal vs External DPPM
Hello
It is hard to determine a relationship without seeing the data. I think once you perform the data gathering and analysis, the story will be more clear. The relationship, IMO, is going to be unique to the maturity of the product(s) / process that you want to measure. There's too much unknown right now. For example, there could be a low level of detection (lack of test method rigor) that results in low internal DPPM but causes a high external DPPM. I am sure there are many other scenarios. When doing this sort of analysis, consider comparing newer vs more mature products.
W
A SaMD: Metric for release frequency EU Medical Device Regulations 5
sonflowerinwales Metric or Imperial; that is the question... After Work and Weekend Discussion Topics 6
B Calibration of Thread Gages with Metric Standards with Conversion to Imperial Units General Measurement Device and Calibration Topics 3
M Scrap metric/ Waste metric Manufacturing and Related Processes 1
Ed Panek Sterilization vs Disinfection - Wearable bandages that report a health metric via Bluetooth CE Marking (Conformité Européene) / CB Scheme 3
Sidney Vianna ISO/TS 30411:2018 Human resource management - Quality of hire metric Other ISO and International Standards and European Regulations 1
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
P NPR Metric - What if Customer has relaxed measure? TL 9000 Telecommunications Standard and QuEST 1
leftoverture PPM Defect Rate as a Performance Metric - Are there Flaws? Quality Manager and Management Related Issues 9
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Is PPM a good metric for gathering companywide complaints ? Customer Complaints 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
J Help with a Metric Drawing Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Conversion and Rounding Standard for converting metric to english and vice versa Other ISO and International Standards and European Regulations 4
S US and Metric Measurements in same Document Other ISO and International Standards and European Regulations 4
M Which metric is better for Cost of Poor Quality (COPQ)? Quality Tools, Improvement and Analysis 17
T Red Metric on a Customer Scorecard is a Major Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M Metric Call Out on a print (from Japan) - 40mm +.002/+.015 Capability, Accuracy and Stability - Processes, Machines, etc. 8
T Metric Thread Specifications question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
A Change Control Review Management Success or Effectiveness Metric Quality Manager and Management Related Issues 3
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
M Quantifying "Risk" as a Usable Management Metric Quality Manager and Management Related Issues 3
D ISO/Metric Solid Thread Ring Calibration General Measurement Device and Calibration Topics 1
D Metric Print from Italy - Tolerances - 38.8mm -0.015/-0.045 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M How to increase survey response rate? - Process Effectiveness metric Six Sigma 5
S Internal Auditor Productivity Metric? Internal Auditing 30
Q Does a Procedure need to have a metric assigned to determine its effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A A Metric for Maintainability of a Software Product Misc. Quality Assurance and Business Systems Related Topics 2
T Quality of Product Metric for AS9100 Rev.C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S How to Calculate BCS (Build To Customer Schedule) Metric? Lean in Manufacturing and Service Industries 3
P A standard method of Dual Dimensioning drawings (Inch/Metric) Manufacturing and Related Processes 5
C Microscope Reticule Calibration - Fails 1x metric, passes 3x imperial General Measurement Device and Calibration Topics 3
J Surface Finish Tester Recommendations with both Ra and Rz (english and metric) scales Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E Cost Savings based on 2005 Production - Metric Conversion Problem Misc. Quality Assurance and Business Systems Related Topics 4
R Rolled Throughput Yield - Is anyone using this metric, and if so, how Lean in Manufacturing and Service Industries 6
G Process Effectiveness Metric for the process ?Internal Audit? Internal Auditing 25
Q Supplier Defects Per Million Metric - Best way to depict monthly supplier performance Supplier Quality Assurance and other Supplier Issues 3
Q New Engineering Metric for our Design Engineering Group Design and Development of Products and Processes 4
M The Metric System and the US Misc. Quality Assurance and Business Systems Related Topics 15
B Need to know how to calibrate inch and metric gage blocks correctly. General Measurement Device and Calibration Topics 2
MaHoDie Where to show the Software version IEC 62304 - Medical Device Software Life Cycle Processes 2
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Kpi doesn't show action plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
M How to show the effect of the failure mode on the manufacturing process as a customer of product design process? FMEA and Control Plans 3
Ashland78 Need to show evidence in accordance with QR-11012 and SPB-00001-09 Customer and Company Specific Requirements 5
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
