Metrics to be put in place in our Test department - First Pass Yield and Paretos
Jancen
Other than First Pass Yield and using Pareto chart, are there any other metrics that we can use in Test? Also, we don't get boards for test on a consistent basis. How do we measure our productivity?
Caster
An Early Cover
Re: Metrics to be put in place in our Test department - First Pass Yield and Pareto's
How about tests completed in a timely manner, tests completed correctly, test backlog?
Yield is not produced by test, it is set upstream in manufacturing.
Measures of Yield often lead to pressures to improve results with unintended results. I have been involved all too often in big efforts to prove the test method is incorrect, all the while the process keeps running poor product while the focus is on the test.
Production people live and die by Yield and they are expert at gaming this measure.
I argue that Yield should be number you said were good - 2 times number scrapped/reworked at each downstream process - 5 times warranty claims (account for lost opportunity cost).
This can lead to negative numbers. This idea is a cousin of cost of poor quality and gets about as much interest/support.
bobdoering
Stop X-bar/R Madness!!
I was pondering this, too. But, without a constant flow of product (and if I get the picture correctly, the product flow is intermittent) you have to log your work when you do it (painful overhead), rather than look at the total for a day (not so painful - but erroneous for this case). Not sure if the effort will yield an equal benefit. :cool:
DannyK
First pass yield and a pareto of errors is sufficient to introduce metrics in the test department.
Some companies monitor test times versus the standard time and others measure the time for set-up.
What is important is that the test data gets fed back to manufacturing so that the process improves.
achorste
My tuppence worth - measuring an inspection operation or department on their throughput / accepted could lead to inspectors being put under pressure to pass non-conforming or borderline product. (It certainly happened where I work where inspectors used to work for production & were measured on the same metrics as production ie getting numbers out the door).
Would it be possible to measure them on external non-conformances (where they passed failed components)? Or as DannyK says - the inspection time taken could be used, however there is still a risk the inspectors will rush work to achieve targets and non perform the inspection correctly.
I'm not saying the rest of production shouldn't be monitored by throughput, however there are risks involved with measuring inspection in the same manner.
First pass yield at any station is becoming an accepted metric. It is up to management - as always - to recognize that where the yield loss is detected is not necessarily where the defect was created. Additionally yieid is calculated as the number passed, not as the number ultimately shipped. Any rejection - rework - resubmission is counted as a failure. This allows visibility to the hidden factory. This is now a common lean and six sigma metric. We use it on every station for every product quite effectiveley; and no one blames test or inspection as it's not allowed. I would add SPC trends for each pareto item (We call it: trend - pareto - trend. clever huh?). although we trend these as defect rates and not yield...
I also like tracking output vs the standard time. This helps get a better look at productivity when volume is variable. Alternativley you can use a ratio of output per man hours actually worked but that typically requires a separate tracking system. While the first method is pretty standard for most ERP systems.
As an aside, I don't advocate not usign a metric because others might misuse it. If the metric is correct, educate the 'others'. It's not easy, but nothing worth doing is usually easy....
M Quality Metrics Questions Lean in Manufacturing and Service Industries 2
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
G Defining performance metrics for DFMA implementation Design and Development of Products and Processes 2
W Core Process Metrics AS9100D for Product Planning? Quotes and sales? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
R Visually impacting graphics for Nonconformance status metrics for Management Report Nonconformance and Corrective Action 5
Ed Panek User Feedback both negative and positive and acting upon those metrics 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
D Need Resource for Industry Data - standard metrics for machine shops Lean in Manufacturing and Service Industries 3
V Information Technology Dashboard - IT Department Performance Metrics IEC 27001 - Information Security Management Systems (ISMS) 2
C What types of Calibration Metrics are Collected General Measurement Device and Calibration Topics 2
A Reporting Corrective Action System Performance Metrics Quality Tools, Improvement and Analysis 1
M PPAP Metrics that visually displays the progress through charts and/or graphs APQP and PPAP 7
Mikael Metrics for dashboard, FMEA? Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Definition and Way to Calculate some Metrics Lean in Manufacturing and Service Industries 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
D Metrics on effectiveness of Customer Returns Misc. Quality Assurance and Business Systems Related Topics 9
D How can I determine a process metrics? Manufacturing and Related Processes 1
S Bucket list of all Metrics around Nonconforming Materials Nonconformance and Corrective Action 7
W Design and Development, and Assembly Process Quality Metrics AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
D Software Quality Metrics Software Quality Assurance 8
M Establishing Metrics - Where do you document metrics? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
Z DPMO? Metrics for Engineering Drawings Six Sigma 1
J Customer found Nonconforming Product Metrics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Metrics and Statistics for Improvement - Easy to implement Statistical Analysis Tools, Techniques and SPC 4
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
R Supplier Metrics Analysis question Supplier Quality Assurance and other Supplier Issues 4
R Return Material Authorization (RMA) Metrics - Examples Customer Complaints 9
C Key Performance Metrics related to Process Area Quality Manager and Management Related Issues 6
N Where to begin defining and monitoring Quality Metrics in a Machine Shop Manufacturing and Related Processes 9
D Quality Metrics and OFIs in a Metal Stamping Company Manufacturing and Related Processes 7
K KPI (Key Performance Indicators) Metrics for Management review Quality Manager and Management Related Issues 4
V Ideas, Measures/Metrics for making Quality Proactive? US Food and Drug Administration (FDA) 2
D Quality Metrics to use to solve Problems Quality Tools, Improvement and Analysis 5
R Control Chart Metrics/KPI - Measuring Effectiveness of Control Charting System Statistical Analysis Tools, Techniques and SPC 4
S LDMS (Lean Daily Management System) HELP: No Daily Metrics in HR Lean in Manufacturing and Service Industries 14
A Process Objectives and Metrics - Should every documented process have objective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V What are suitable "Leading Indicators and Metrics" for QA Quality Tools, Improvement and Analysis 7
S How to develop Productivity Metrics Quality Manager and Management Related Issues 3
D Six Sigma Savings Metrics - Six Sigma Project on OTD Six Sigma 11
P Quality Engineer's Role in Tracking MRT Metrics & PDT Metrics Customer Complaints 2
Y Metrics for the Management Process AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 15
Ajit Basrur Dashboard Software for representing Quality Metrics like DPPM, On Time Delivery, etc. Quality Tools, Improvement and Analysis 4
L Metrics (Measurables) Required by ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 10
T Quality Metrics Report for the Management Review Meeting Document Control Systems, Procedures, Forms and Templates 16
N What are typical Software Life Cycle Metrics Software Quality Assurance 5
C KPI (Key Performance Indicators) Metrics for R&D (Research and Development) Records and Data - Quality, Legal and Other Evidence 10
V Concepts and Industry Practices of Measurement-Metrics-QA (Pharma/Device Industry) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
Q RMA (Return Material Authorization) KPI's (Key Performance Indicators) and Metrics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P QMS Metrics Dashboard development Quality Manager and Management Related Issues 7
