Microbial Standard for Bacteria, Fungus & Mold for Equipment
sidmishra - 2008
hi
can anybody tell me about the microbial standard for bacterias, fungis & molds for the equipments used in a personal care manufacturing unit?
Jimmy the Brit
Re: microbial standard
hi
Hi Sidmishra,
It depends what equipment you are talking about: If you mean manufacturing equipment/environment then ISO14644-1 sets the limits for non-viable particulate levels based on the room classification. USP states the suggested microbial limits for pharmaceutical manufacturing facilities based on the room classification in General Chapter 1116 and for the EU Eudralex Volume 4 Annex 1 does the same. These limits apply to process equipment as well (surface count limits)
The different references use different classification names/numbers, but if you reconcile the particulate limits you can work out which is which easy enough.
I don't know of any specific microbial limits for medical device manufacturing, but the limits in USP and Eudralex for class 10,000 and 100,000 rooms are generous and I believe easy to meet in a well designed cleanroom.
If you mean the actual bioburden on items for sterilization then that is set by your sterility assurance program and validated sterility assurance level.
Let me know if I have misunderstood your question,
Jimmy
YellowQCPro
This post most resembles the forum to post my question, please let me know if there is another place!! Anyways, I just received my lab report for bioburden. The results is "samples with "<" numbers indicate 0 cfu were recovered". Now, it's hard to believe that products sent non-sterile to the lab, actually came back with 0 bioburden???? Does this mean that we are producing sterile devices, and there is no need to sterilize? Does this mean that we can state non-pyrogenic? we are validating our sterilzation cycle with PCD's, so i don't think that this result will damage the validation, just wondering how to interpret the information. Thank you in advance for your help!
Ajit Basrur
Just because the device has 0 cfu does not indicate it could be always sterile. 0 cfu could be due to multiple reasons - the main being, the material being inert does not give chance for bacteria and others to grow.
If the device is intended to be sterile, it should be sterilized through one of the known sterilization methods. Therefore, even if your device has 0 cfu, you can not be sure of those results "consistently".
You should also remember that even if an article is intended to be sterile, the bioburden prior to sterilization should be low enough to assure a Sterility Assurance Level (SAL) based on the criticality of the device.
MIREGMGR
Another way to get an apparent 0 CFU datum--not likely your problem, but worth mentioning so that you can rule it out--is to have a tested material turn out to be non-biocompatible, and in fact sufficiently toxic (or using other language, anti-microbial) that it cannot be evaluated using normal methods.
Materials containing silver or copper at their surface, or sometimes other metals, will do this at times even if not designed to do so. So might a material that contains significant levels of certain other elements, or of course intentionally antimicrobial additives.
So, less favorably, can materials containing certain flame retardants, heat stabilizers, preservatives and flexibilizers.
Ajit Basrur
You are absolutely right - sometimes, the microbiological media may inhibit growth and thus the analytical method needs to be validated for Recovery Test.
This is a prerequisite for carrying out the microbiological testing.
siju234
Dear Sir,
I request your help regarding total plate counts in Bottled water:
Occasionally, I am getting a Total plate counts bacteria of more than 300 cfu/ml from our Bottled mineral water. As per specification the maximum limit is 25cfu/ml. Because of this problem a huge quanity of finished products have been rejected and destroyed. Whether the bottled water with high total plate counts consumption will cause any serious harm to the consumer? What are the main bacteria used to present in total plate count ? Can you please name some examples for plate count bacteria?
Ajit Basrur
Dear Sir,
Pls give more details on your water generation system and your past investigation done subsequent to high bacterial counts.
siju234
Our plant is equippped with Reverse Osmosis Filter system, located in Saudi Arabia..The source water in this area contains high amount of bromide ions result of that high amount of bromate contents in product water, because of that we are treating our product water with very less quantity of Ozone (0.03mg/l). If we increase Ozone that leads to the formation of Bromate in Product water ,so we need to maintain ozone lessthan 0.03mg/l. Our factory is already warned by the Health department for the high amount of Bromate in product water in the past, So we are not in a position to increase the ozone quantity . I have found that this ozone quantity is enough to get rid off the bacteria but not 100 % , I meant occasionally we are getting high aerobic microbial counts. Usually we are getting 1 or 2 aerobic counts only (from the pour plate method).
Q US FDA Standard Limit for Swab Test Microbial and ATP Other US Medical Device Regulations 1
P Standard for Microbial Limits for a Combination Device - Impregnated Retraction Cord EU Medical Device Regulations 1
J How to Set Microbial Limits in Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
A Microbial exposure during use - Requirement 11.1(c) EU Medical Device Regulations 1
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
V Are microbial limit tests required for sterile products? Qualification and Validation (including 21 CFR Part 11) 3
J What Control Chart should be used for Microbial Limit (NMT 100 cfu/m3) Statistical Analysis Tools, Techniques and SPC 12
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Class 8 100,00 Cleanroom - Airborne Microbial Count ISO 13485:2016 - Medical Device Quality Management Systems 6
D Food Sampling Matrix for Microbial Testing (number per batch) for Fast Food Processor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
W Environmental Monitoring - Microbial Identification - Small medical device company ISO 13485:2016 - Medical Device Quality Management Systems 9
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 0
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
