Micrometer Calibration Methods
#11
Our wire tolerance is +.060"/- .003". Unbelievable for reinforcement of concrete but it is engineered to withstand so much pressure and weight. If the wire is too big it can upset the engineered material if it is to be put together with other pieces of structure.
The thing is, if you go to the high side, you are giving away wire. The closer to the negative side the more money you make. We make and sell millions of tons of wire.
Ah - I see your point. Still one might have to ask how much "cost" is involved in keeping to the low end of the tolerance vs "giving away" a bit more wire...Definitely a cost analysis thing...
However, given your current situation and tolerances, it is obvious why you use micrometers. Now it is just a matter of taking a good look at the various pieces of information provided here and developing a sufficiently robust calibration procedure adequate to your needs.
Peace
James
P
palmer
#12
We have been in business for over 30 years and deal with various state DOT's including the one who questioned our methodology in testing. We maintain our test records FOREVER. This is in case something happens like the bridge collapse in Minnesota a couple years ago. Find the responsible party to blame. We have never had a fault where there was a structural failure of our product.
This is the 1st time that has ever been questioned. There are other states that are so much more critical that Texas when we send samples and test results. I think this is someone new who is either got some lean mfg experience or is throwing his weight around.
:topic: I've been removed from the Continuous Improvement role that I had in the past. Our new owner does not want that position at each facility. I now have purchasing as my responsibility and safety coordinator under previous and new owner. As purchaser, I had to get someone to calibrate the scales, my past experience kept them from paying someone to calibrate 10 or 20 micrometers. I still want to be in lean and continuous improvement. Too bad no one will notice what I did to save them some bucks and help them with recording their calibrations.:nopity::notme:
C Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
C One Inch Micrometer Calibration Method General Measurement Device and Calibration Topics 2
S Micrometer Calibration Using a CMM Calibration and Metrology Software and Hardware 12
M Calibration of a Micrometer used as a Standard General Measurement Device and Calibration Topics 5
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
J Calibration of Micrometer Reading up to Three Decimals General Measurement Device and Calibration Topics 3
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
K Micrometer Calibration - Resolution, Accuracy and Range General Measurement Device and Calibration Topics 16
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
J Calibration of Flute Micrometer General Measurement Device and Calibration Topics 3
apestate Thread micrometer questions, discussion regarding MU and calibration. General Measurement Device and Calibration Topics 3
apestate Micrometer Calibration Procedure - Please critique General Measurement Device and Calibration Topics 20
N Calibration of micrometer by gauge block General Measurement Device and Calibration Topics 5
N Confuse: Calibration using master equipment - Resolution - Micrometer General Measurement Device and Calibration Topics 7
D Micrometer Calibration - Seeking actual Calibration Procedure for 0-1" Micrometer General Measurement Device and Calibration Topics 19
S How often for micrometer calibration? General Measurement Device and Calibration Topics 10
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
A Depth micrometer rod adjustment? General Measurement Device and Calibration Topics 8
A Micrometer anvil chipped General Measurement Device and Calibration Topics 19
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
W Micrometer Storage while not in use General Measurement Device and Calibration Topics 4
D Can anyone share a completed Gage R & R on a Micrometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
J Air Micrometer Basics - What are the internal parts and how do they work Manufacturing and Related Processes 7
M Trigonometric Calculation (V-Anvil Micrometer). I'm not getting it. General Measurement Device and Calibration Topics 6
4 Federal Specification GGG-C-105C - Caliper, Micrometer, Gage, Depth Micrometer General Measurement Device and Calibration Topics 7
D Determining Instrument Purchase based on Accuracy (Micrometer) General Measurement Device and Calibration Topics 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
