Micrometer Calibration - Seeking actual Calibration Procedure for 0-1" Micrometer
Q
Qualqueen
#11
Re: Micometer calibration - Seeking actual calibration procedure of a 0-1" micrometer
Be sure to check the flatness of the anvils for valid calibration - either using gage balls or optical flats. It is one of the most overlooked aspects of micrometer calibration in in-house labs.
This is a very valid point. Does anyone have a procedure for checking with optical flats? :cfingers: I know it pertains to the number of bands.
bobdoering
Stop X-bar/R Madness!!
#12
I do know that the Edmunds Scientific Optical catalog has a nice overview of the general use of optical flats (may also be on their website), but I do not have a procedure specifically to use them for micrometers (or other measuring surfaces of hand gages!) Other optical flat/monochromatic light suppliers have good info, too.
For those that have never used optical flats - you need the optical flats and a monochromatic light! I have been places where they had flats, but no light - and no idea how to use them!
John Nabors - 2009
#14
This is from mcnallyinstitute.com. It refers to measuring mechanical seal faces rather than micrometer anvil faces, but it might still be edifying:
There are several ways you could measure flatness :
  • You could place a straight edge on the surface and look for daylight between the straight edge and the sample. As you would guess this method is not accurate enough for our purposes.
  • You could place "machinist's bluing dye" on a know flat, rub the sample piece against it and look for transfer of the dye. Again this method would not be accurate enough for our purposes.
  • You could read the flatness by using an optical flat and a monochromatic light source, and this is the method that is used by all of us in the sealing industry.
To understand this last method of measurement you only have to know that it is a characteristic of light that when two lights of the same wave length interfere with each other, the light disappears and the reflecting piece goes black. When you discuss visible light, color and wave length mean the same thing, so to make the measurement we use :
  • A monochromatic or single wave length light source. Any color (wave length) could be used, but most companies use a pink color that comes off a helium gas light source. This color has a wave length of just about 0,6 microns (0.000023 inches).
  • You will also need a precision ground and polished clear glass of optical quality that has been lapped flat on at least one side.
The optical flat is placed on the piece to be measured. The monochromatic light is aimed at the piece and this light reflects off of the piece back through the optical flat causing interference light bands. If the distance between the optical flat and the piece we are measuring is one half the wave length of helium, or an even multiple of the number, the band will show black. This is referred to as a helium light band and because it is one half the wave length of helium it measures 0,3 microns or 0.0000116 inches.
So call one helium band roughly 10 millionths of an inch. Hope this helps.
Regards -John
John Nabors - 2009
#15
Lord only knows how many Q-labs out there have one of those B&S micrometer checking sets (you know the ones, in the wooden box with the 10 gage blocks stepped .105" apart and the two optical flats) that have no monochromatic light, but still think that they are really calibrating flatness on their micrometer anvils. I wonder what it is that they see?
bobdoering
#16
I know! I have seen that!
John Nabors - 2009
#17
If I may step outside the box for just a minute..
I once calibrated a micrometer using optical flats and He light, then, just out of pure darn curiousity, clamped the mic into a Zeiss CMM with a scanning head and checked flatness. Guess what? I got about .00003" by both methods.
chriswhitehead
#20
dbulak: Not meant to hijack your original thread, apologies.
JStain1,
We dont have that procedure 33K6-4-15-1. We custom developed internal procedure for our micrometers.
Just curious about one point; while measuring master between between the anvils,Is there any mention about "Number ratchet rotations"?
I was told by a senior metrologist from the old school as 2 clicks. About right?
Govind.
I've been trawling all avenues for micrometer calibrations. Opinion is devided on the number of clicks needed. I've seen in writting the need for two or three clicks, never one. If I have a play I would say I do indeed need two or three clicks. In my procedure I'm writing I've stated two quicks, later changed it to three, then put it back to two. I feel two is enough from my trials on the real thing.
C Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
C One Inch Micrometer Calibration Method General Measurement Device and Calibration Topics 2
S Micrometer Calibration Using a CMM Calibration and Metrology Software and Hardware 12
M Calibration of a Micrometer used as a Standard General Measurement Device and Calibration Topics 5
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
J Calibration of Micrometer Reading up to Three Decimals General Measurement Device and Calibration Topics 3
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
P Micrometer Calibration Methods Calibration Frequency (Interval) 11
K Micrometer Calibration - Resolution, Accuracy and Range General Measurement Device and Calibration Topics 16
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
J Calibration of Flute Micrometer General Measurement Device and Calibration Topics 3
apestate Thread micrometer questions, discussion regarding MU and calibration. General Measurement Device and Calibration Topics 3
apestate Micrometer Calibration Procedure - Please critique General Measurement Device and Calibration Topics 20
N Calibration of micrometer by gauge block General Measurement Device and Calibration Topics 5
N Confuse: Calibration using master equipment - Resolution - Micrometer General Measurement Device and Calibration Topics 7
S How often for micrometer calibration? General Measurement Device and Calibration Topics 10
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
A Depth micrometer rod adjustment? General Measurement Device and Calibration Topics 8
A Micrometer anvil chipped General Measurement Device and Calibration Topics 19
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
W Micrometer Storage while not in use General Measurement Device and Calibration Topics 4
D Can anyone share a completed Gage R & R on a Micrometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
J Air Micrometer Basics - What are the internal parts and how do they work Manufacturing and Related Processes 7
M Trigonometric Calculation (V-Anvil Micrometer). I'm not getting it. General Measurement Device and Calibration Topics 6
4 Federal Specification GGG-C-105C - Caliper, Micrometer, Gage, Depth Micrometer General Measurement Device and Calibration Topics 7
D Determining Instrument Purchase based on Accuracy (Micrometer) General Measurement Device and Calibration Topics 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
