Micrometer & Caliper Calibration (ISO-9001)
JDJohnson
#21
Just remember, YOU can't get everything fixed. Its going to take buy in from the top to the bottom. If you don't have top management support, and they just want a cert on the wall, you will be fighting a never-ending battle.
They brought me in because I have the experience I do and they seem to and was told that I basically have free reign to get the things done i need to. I report to the plant manager and work with the rest of the top management here at the plant. We are under an umbrella but we basically govern ourselves here. although it is only my 3rd day. lol
Mike S.
Happy to be Alive
#22
Make sure none of your customers require calibration to a certain standard. I don't know who you customer base is, but in aerospace and defense a lot of customers demand calibration iaw ISO 17025 or some other standard for all M&TE as part of their flowdowns. In such case, just any old self-calibration or verification won't cut it.
Good luck in your new job. Working in a target-rich environment can be rewarding or soul-sucking depending on the culture.
JDJohnson
#23
In my previous work everything was required to be calibrated to NIST and was in the aerospace and medical industry, now im in the industrial bearing industry.
Jen Kirley
Quality and Auditing Expert
#24
Lots of good advice here. Let's summarize.
  1. Calibration is needed to make sure the right product is going to the customer. So at a minimum, calibrated instruments are needed for final inspection. It is perfectly fine to question how many are needed to be active at any given time, but if some are placed inactive they should be secured from being confused with being in a calibrated status.
  2. If product is to be final inspected, then in theory reference instruments can be used for the earlier steps: setup and production. But this could cost you badly in waste.
  3. Internally calibrating and verifying (the terms are used almost interchangeably) with NIST traceable standards is fine, but technique matters. Personnel who do this need to be competent. Calibration/verification needs to be done within the range the instrument is used. Most of us use 10:1 discrimination, but I have never seen this as a requirement in print so I would consider setting out your own procedure to define it.
  4. It is not okay to verify the gage blocks with the same instruments they are used to calibrate.
  5. It is perfectcly okay to calibrate/verify before use, but you'll need a record of having done that. (Job router or shop traveler?)
  6. If instruments are to be used all day, I question whether an annual cycle is enough and I question if you never find it necessary to check for flatness of anvils on micrometers. Calibration is planned based on the accuracy needed, as well as risk introduced by amount and type of usage, the environment of usage, how the tools are stored and their sensitivity.
  7. Make sure there is an effective process for understanding potential effect on product if an instrument is found to be out-of-tolerance when it gets calibrated/verified, and taking action as needed.
I hope this helps.
CaliperJim
#25
JD, do your customers or regulations require you to adhere to any specifications such as MIL-STD-45662A or pass audits such as NAV04? Those are the documents I reference when making decisions regarding calibration.
CaliperJim
#26
You should not label anything "reference only." That's an like an engraved invitation to an auditor, asking him to start digging. The standard says that devices must be calibrated "if necessary to ensure valid results." If you feel like a given device doesn't need full-blown calibration, you should label it "Calibration not Required," and be prepared to provide the rationale. Also, "calibration" is nothing more than comparing a device to a standard, and doesn't imply adjustment. There are different levels of calibration. What's commonly referred to as "verification" of a device is a form of calibration.
Thank you for your dedication in helping people understand what calibration means. I'm very tired of vendors and customers insisting on using verification if no adjustment is possible.
JDJohnson
#27
No not that I am aware of. Only by ISO 9001 requirements. When I came in to this position the guy before we was in his infancy putting together a QMS for ISO 9001 and wanted to use an exclusion clause for all micrometers (even final inspection). I am looking to make critical to quality inspection equipment calibrated (final inspection/assembly and surveying/engineering departments) and in process inspection equipment at the machine to verify to a standard prior to use without the requirement of documenting the verification in order to keep it all manageable.
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Cats Clause Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
G Procedure Creation specifically for dimensional (caliper, micrometer, dti) Document Control Systems, Procedures, Forms and Templates 8
G Uncertainty Budget Examples for Caliper, Micrometer and Dial Gauge Measurement Uncertainty (MU) 3
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
G Manual Procedure with Uncertainty Budgeting for either a Caliper or Micrometer General Measurement Device and Calibration Topics 6
4 Federal Specification GGG-C-105C - Caliper, Micrometer, Gage, Depth Micrometer General Measurement Device and Calibration Topics 7
G Calibration of Angle microscope stage micrometer General Measurement Device and Calibration Topics 1
C Uncertainty budgets and meeting 4:1 TUR for digital calipers and micrometer Measurement Uncertainty (MU) 0
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 4
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
A Depth micrometer rod adjustment? General Measurement Device and Calibration Topics 8
A Micrometer anvil chipped General Measurement Device and Calibration Topics 19
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
M Uncertainty Budget for a Micrometer Measurement Uncertainty (MU) 5
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
C One Inch Micrometer Calibration Method General Measurement Device and Calibration Topics 2
W Micrometer Storage while not in use General Measurement Device and Calibration Topics 4
D Can anyone share a completed Gage R & R on a Micrometer? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Thread Micrometer Standard Tolerances General Measurement Device and Calibration Topics 4
S Micrometer Calibration Using a CMM Calibration and Metrology Software and Hardware 12
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
M Calibration of a Micrometer used as a Standard General Measurement Device and Calibration Topics 5
S Laboratory to Calibrate Objective Micrometer needed General Measurement Device and Calibration Topics 4
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D Procedure on How to Calibrate a External Micrometer General Measurement Device and Calibration Topics 1
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
J Air Micrometer Basics - What are the internal parts and how do they work Manufacturing and Related Processes 7
M Trigonometric Calculation (V-Anvil Micrometer). I'm not getting it. General Measurement Device and Calibration Topics 6
J Calibration of Micrometer Reading up to Three Decimals General Measurement Device and Calibration Topics 3
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
D Determining Instrument Purchase based on Accuracy (Micrometer) General Measurement Device and Calibration Topics 3
A Generic or Specific Gauge R&R on Standard Equipment (ie.: Micrometer) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Micrometer Calibration Methods Calibration Frequency (Interval) 11
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
K Micrometer Calibration - Resolution, Accuracy and Range General Measurement Device and Calibration Topics 16
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
P How to Calibrate Laser Micrometer when no Calibration Company in the Country? General Measurement Device and Calibration Topics 3
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
D Results of a GR&R study done on a 0-1" Digital Micrometer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
G Dispute - Checking a thin walled, round, hollow part with micrometer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
D GRR (Gage R&R) procedure for Mitutoyo Digital Micrometer wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
