Microscope Power to use for Visual Inspections in an Aerospace Machine Shop
Corkie
We are a machine shop which services the aerospace industry. For visual inspections under microscope, we use 10x as our standard power whenever the customer has not specified a different one. Recently, one of our customers rejected one of our parts and, when we couldn't see any defects at 10x, were informed that they inspect at 30x. This customer had not specified any particular requirement on the print or PO. Question: is there any reference manual or standard that could help guide us on this subject? Thank you in advance.
dsanabria
Re: Microscope power to use for visual inspections
Did the company flowdown the requirements in a different document that contract review missed.
Can you provide the name of the customer - we might have had similar experiences.
  1. What kind of defects?
  2. What do the specifications say about pass/fail criteria?
Corkie
Answers to questions in both replies:
1) name of customer: it's not a prime, so I would rather not pass that along publicly
2) there were no other requirements other than those stated in the print and PO
3) defects were burrs and scratches
4) pass/fail criteria were generic: part must have no burrs and no scratches on sealing surfaces
The customer has the advantage here because they were allowed to get away with subjective specifications. A lot depends on the amount of money involved and the general relationship with the customer, but the specifications should be made objective and measureable. There is no applicable standard because in order for it to be a standard, you and the customer would have had to agree to it in advance.
N
NumberCruncher
Hi Corkie
There are two different issues here. Firstly, you need to use the tool which is suitable for the job. If you know what size of defect you are looking for, you can choose the magnification accordingly. I am not aware of any standards on this. Quite simply, because the final detector is a human eye, what is correct depends to an extent upon your eyesight. However, in reality you will be employing people with normal to somewhat myopic eyesight for close up inspection tasks.
From personal experience, with a x15 binocular microscope fitted with a 1mm graticule, I can measure in increments of 0.1mm. I can see defects smaller than that, but I can only estimate the size. (The graticule is 1mm square, but divided into 10x10 squares, each of which is 0.1mm per side).
The other issue is (somewhat ironically) purely about reading the small print. What did the contract say? Is there a clause regarding acceptable defect size? If so, you should have used the correct magnification to see and presumably measure such defects. Did you inform your customer of how you would be checking your product and if so, did they accept your method?
Time for some forensic contract reviewing.
NC
optomist1
A Sea of Statistics
Hi Corkie,
the drawing may have vague notes.....the customer may be using it to his advantage.....many drawing notes are poorly worded and bad for both parties ex: "part must be free of burrs and break sharp edges"...(just so happens there is a spec for "Corners of Undefined Shape", I think it is ISO 13715) too vague and open to interpretation.
I had to deal with this at one (casting porosity) point, the first go around the (DCAS)customer won out....shortly thereafter, a meeting was held and a revised drawing/spec was issued...including the required magnification power to be used for verification....hope this helps
Marty
G Calibration of Angle microscope stage micrometer General Measurement Device and Calibration Topics 1
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
A Is there any Light for a surgical microscope? Other ISO and International Standards and European Regulations 3
M Microscope slide warmer temperature control General Measurement Device and Calibration Topics 4
L Inspection Plan for Microscope Objective Lens Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J FDA Microscope IQ (Installation Qualification) Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Best X-Y Microscope Stage for Submicron Accuracy Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Source of a Clear Fixture Block on a x-y Video Microscope - Rafaelco? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Uncertainty Budget for the Optical Microscope - Deriving Linearity Uncertainty Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J MU (Measurement Uncertainty) for an Optical Microscope Measurement Uncertainty (MU) 7
S Nicolet IN-10 and IZ-10 FT-IR Microscope - Work instructions wanted General Measurement Device and Calibration Topics 2
B MSA (Measurement Systems Analysis) on a Video Microscope Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A MSA and Gage R&R for Measuring Microscope Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Microscope Failure Modes and Horror Stories ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Microscope Reticule Calibration - Fails 1x metric, passes 3x imperial General Measurement Device and Calibration Topics 3
B Out of Calibration Microscope Used for Development Work General Measurement Device and Calibration Topics 4
ChrisM Re-labelling purchased power supply EU Medical Device Regulations 1
XRAY_3121 Class II heating pad - does the power supply have to have IEC 60601-1 testing?? US Medical Device Regulations 5
Y Is Power Switch button mandatory IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M MOPs of power socket for battery powered device IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
K IEC Maximum Power Density for Muscle Stimulator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
Icy Mountain Contingency plans, Back-up Power Generation IATF 16949 - Automotive Quality Systems Standard 38
PQ Systems The Power of Pareto Charts Using SQCpack Software 0
F Configurator for a power unit - Software or other solution? Manufacturing and Related Processes 0
H Using/Selling power banks with your product as a "mobile version" CE Marking (Conformité Européene) / CB Scheme 3
S Class I Equipment with mobile power inverter IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L Class II (Double Insulated) Power Supply with Output Tied to Earth: FE or PE? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Hand Held medical device - power supply requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 23
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
C Power Supply EN60601-1 vs EN62368-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S DC-AC Power inverter with two MOPPs IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Surge Protectors and other power protection Manufacturing and Related Processes 7
Sidney Vianna Informational APQP4Wind - Advanced Product Quality Planning for the Wind Power Supply Chain APQP and PPAP 3
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
M MS Power Automate/Sharepoint Files Document Control Systems, Procedures, Forms and Templates 1
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
L IEC 62368-1 / Electrical Energy Source vs. Power Source? CE Marking (Conformité Européene) / CB Scheme 2
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
