Microsoft Excel 2003 Formula Restrictions
X
xtaticblue
I am trying to 're'-produce a spreadsheet for the recording of steel castings dimension checks.
I have already managed to produce the spreadsheet once (see attached).
The spreadsheet allows me to choose which Casting Tolerance range i want to use, and then automatically enters the tolerances depending on the dimension entered.
Works well :)
....but only in excel 2007. :(
I need to save it as a 2003 spreadsheet but i have to many 'If' functions in one of the cell formulas. (cell d2, calculations sheet). 2003 will only allow 7 per formula.
Does anyone know how to perform the same operation, but without using such a long winded formula.
Please help!!:mad::mad:
If I can get it to work i promise to post the finished spreadsheet on this site!!:tg:
Bogie
Re: excel 2003 formula restrictions
I ran into this once and had to make the first IF statement reference tolerance ranges, then it was directed to a cell with the correct range, which offered another IF statment that was specific.
PITA, but works for 2003. I'll try to dig up the file if I still have it.
Kales Veggie
People: The Vital Few
Works well :)
The formula to determine tolerance is too complex to analyze. Simplify.
Change to "Indirect" or Vlookup.
Bogie
Wonder of Wonders, it was in the first place I looked. look on the "AQL" Tab. I have it set up to automatically figure how many parts are to be inspected (according to an AQL level) - all you have to do is enter the # of parts available (D9). If you look at the code on D10, it does not give the full range, but directs it to look at R10 if it doesn't find the # in the string given. R10 gives the rest of the options.
Hope this makes sense and helps.
X
xtaticblue
Bogie; Thanks, that might work. I'll let you know.
Kales Veggie; thought about using vlookup, but i don't often use this function, and i've never used "indirect".
I know lookup can return one result based on an input, but how would it be used to return a result if the input falls between 2 figures? ie if the input is between 0 and 10; result is "a", if the input is between 10 and 20; result is "b" etc?
hogheavenfarm
There is a workaround for it. unfortunately my old Databases are not on this computer. And I dont remember how I accomplished it without looking up those old files. I will try to dig it out tonite.
rob73
looking for answers
Use the vlookup with "true", you may need to change your reference values to return the right tolerance, but will cut out all of your IF functions.
From MS help site "If TRUE or omitted, an exact or approximate match is returned. If an exact match is not found, the next largest value that is less than lookup_value is returned."
Good luck
Rob
H
Hodgepodge
INDEX/MATCH is the fastest method to use. See the attached spreadsheet. In D2 I tried using the IF(AND... which reduces the # of IF statements by 1/2, however, your table requires 10 IF(ANDs, so that won't do.
In D3 I used a VLOOKUP & added a table on the tolerances sheet to show how that would work. Way more than necessary but still dynamic enough to be helpful.
In D4: D21 I used the INDEX/MATCH function. It uses the table you already have on the tolerances sheet. Copy & paste this formula in D2:21 in your workbook and your set. =IF(REPORT!$E11=0,0,INDEX(tolerances!$B$25:$D$35,MATCH(REPORT!$E11,tolerances!$B$25:$B$35,1),3))
Let me know if you have any questions.
X
xtaticblue
Hodgepodge:
:applause: Thank you,
Used the INDEX/MATCH method and it works a treat!!
Also less of a headache when trying to de-bug a formula!!
Here is the finished spreadsheet, adapted slightly for multi page.
2003 still didn't like the conditional formatting, but hey, you can't have everything.
Thanks all for the help :agree:
X
xtaticblue
FINALLY cracked it.
The spreadsheet now looks up the required tolerances depending on the tolerance range entered.
On a different note, I've also added an automatic 'dimension reference' which updates as a dimension is entered. this gives a 'dimensions x to y of z checks' on each page, similar to the automatic page x of y.
Quite proud of that bit!! :D
Thanks for the help, and feel free to use. :agree1:
D Microsoft Excel database to Stand-alone software Calibration and Metrology Software and Hardware 3
Q Controlling Multi-Tab Microsoft Excel Forms Excel .xls Spreadsheet Templates and Tools 5
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
O Chi Square Normality Test using Microsoft Excel Excel .xls Spreadsheet Templates and Tools 2
AnaMariaVR2 Guide to Microsoft Excel for Calculations, Statistics, and Plotting Data Excel .xls Spreadsheet Templates and Tools 11
M Microsoft Excel - Trouble with Auto-Entry of Dates Excel .xls Spreadsheet Templates and Tools 13
L 21 CFR Part 11 Requirements - Microsoft Excel Add-on Functions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Conditional Formatting for Microsoft Excel Excel .xls Spreadsheet Templates and Tools 2
Colin Changing the Colour of a Date in Microsoft Excel Excel .xls Spreadsheet Templates and Tools 4
L Pareto question Microsoft Excel Excel .xls Spreadsheet Templates and Tools 6
Marc Microsoft Excel zero-day vulnerability confirmed Excel .xls Spreadsheet Templates and Tools 2
C X-R chart - Microsoft Excel .xls Programmed X-R Chart Spreadsheet Excel .xls Spreadsheet Templates and Tools 61
W Sorting in Microsoft Excel .xls - I want to create a Pareto Chart Excel .xls Spreadsheet Templates and Tools 21
D Hyperlinks in Microsoft Excel and Word - Linking Documents Excel .xls Spreadsheet Templates and Tools 12
Q FMEA and Risk assessment in Microsoft Access FMEA and Control Plans 6
J Microsoft Smart Art Turtle Diagram Process Maps, Process Mapping and Turtle Diagrams 9
M Informational Microsoft Built a Bot to Match Patients to Clinical Trials Medical Device and FDA Regulations and Standards News 0
J Microsoft Teams to manage Internal Audit System? Internal Auditing 3
A Free software similar to Microsoft Project - Any suggestion? APQP and PPAP 5
Marc ASQ Linkedin Group - Microsoft Sharepoint discussion - June 2017 Quality Assurance and Compliance Software Tools and Solutions 0
Marc Microsoft to rip up P2P Skype, killing native Mac, Linux native apps World News 0
Marc Microsoft just bought LinkedIn For $196/Share World News 9
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
M Active X and latest update from Microsoft - Dec 2014 After Work and Weekend Discussion Topics 4
N Microsoft Word - How to make high-light go away after text is put in Excel .xls Spreadsheet Templates and Tools 5
insect warfare IRS pays Microsoft for Windows XP support After Work and Weekend Discussion Topics 2
Marc Microsoft to push out XP patch on March Patch Tuesday - 2014 After Work and Weekend Discussion Topics 19
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
V Alternative to Microsoft Office - Open Office vs. Google Docs After Work and Weekend Discussion Topics 26
Jim Wynne Have you tried Microsoft Windows 8? After Work and Weekend Discussion Topics 25
H 4.2.3 Document Control using Microsoft Sharepoint - Visibility of Draft Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Looking for Microsoft Dynamics AX Training Videos for Inspection Journals Manufacturing and Related Processes 1
michellemmm Pagination in Microsoft Word Documents Document Control Systems, Procedures, Forms and Templates 21
H AS9101D Microsoft Word Format: Worth It? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Creating a Traceability Database with Microsoft Access Document Control Systems, Procedures, Forms and Templates 7
Marc Microsoft Losing Big To Apple On Campus After Work and Weekend Discussion Topics 18
P Magic with Microsoft (things that could not be explained) Funny Stuff - Jokes and Humour 8
Marc Apple Dethrones Microsoft As World's Biggest Tech Company After Work and Weekend Discussion Topics 6
E Signature of Records - Microsoft Word forms Records and Data - Quality, Legal and Other Evidence 7
Claes Gefvenberg Microsoft Windows users: Which windows version are you using? March - April 2010 After Work and Weekend Discussion Topics 37
S Microsoft OneNote - Is anyone using Microsoft OneNote Quality Assurance and Compliance Software Tools and Solutions 13
D Microsoft Word problems Document Control Systems, Procedures, Forms and Templates 11
M Microsoft Sharepoint as Document Control Software - FDA Validation Requirements Document Control Systems, Procedures, Forms and Templates 15
Marc The Hidden Cost of Using Microsoft Software After Work and Weekend Discussion Topics 14
C Microsoft Access Database for In-Process Run Charts Quality Assurance and Compliance Software Tools and Solutions 4
Stijloor Microsoft's Ballmer: Windows 7 is nearly final After Work and Weekend Discussion Topics 13
Coury Ferguson Bill Gates to step down from Microsoft After Work and Weekend Discussion Topics 8
A Fullscope with Microsoft AX ERP System Manufacturing and Related Processes 1
B UK standards body taken to court over OOXML (Microsoft's Open office XML) Other ISO and International Standards and European Regulations 6
GStough Microsoft InfoPath - Anyone Ever Used This? Document Control Systems, Procedures, Forms and Templates 7
