MIG Welding Failure Modes and PFMEA Sample Needed ASAP
K
kbock
I am looking for a sample PFMEA for an aluminum MIG welding process. My company is new to welding as this is going to be our first production cell. I am trying to figure out what information is needed in the FMEA so that when our team meets to create this, I can make sure the correct info is in there. Any help would be EXTREMELY helpful. Thanks.
*After doing more research, I feel that I need to update my inquiry. I think that I am looking more for specific failure modes for aluminum MIG welding. This way, we can get our minds going in the right direction for making our own FMEA.
P
prototyper
Are you performing manual or robotic welding?
Other things to consider are the type of wire (Is it compatable with the grade of aluminium?), the wire thickness, the weld settings (current, voltage, pulsed or non pulsed), the torch position and angle to the weld. Consider the age and cleanliness of the wire and parent material. Also the preparation of the weld joint.
Hope this helps.
K
kbock
Thanks. This information will help greatly.:agree: We are doing manual welding. The wire has been chosen for us by the company that we bought the welder through. It is matched to the material as well. The weld settings are going to be determined once we get the welder in house and set up.
SteelMaiden
Do you have any welders that have actually done this type of welding? (as in a professional welder vs. someone who has only been exposed to "backyard welding"?) A good welder can can help you put together your PFMEA, and I recommend that you include them in this process of putting together your FMEA. Too many times we rely on what others have done and ignore the resources in our own plants. FMEAs are meant to be a collaborative project including personnel from all depts involved.:2cents:
K
kbock
I agree with you that a PFMEA should be a collaborative project but unfortunately we do not have anyone in house that is an experienced welder. We are actually looking to send a few of our operators for training. We are going to get our electrical department, maintenance, set-up, operators and quality in on the writing FMEA, along with myself for engineering. I am hoping that with people from all departments, we will catch the majority of the potential problems. Thanks for your help.
Q
Quality-Geek
Have you asked the power source supplier if they can participate in the FMEA or provide any information? They should be "experts," and very aware of not only what can go wrong, but why it happens and common controld to prevent it.
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 5
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
B Mig Welding WPS (Welding Procedure Specification) and Welder Qualification Procedure Manufacturing and Related Processes 5
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
3 General MIG Weld Workmanship Standard or Procedure Manufacturing and Related Processes 2
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
M Butt welding of 13Cr tubing Manufacturing and Related Processes 0
A Adjusting Calibration Intervals for Welding related Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Help with 8.5.1 regarding Welding Procedure Specifications (WPS's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A AWS (American Welding Society) D17.1 & D17.2 Welding - Looking for help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Q Welding filler material verification Manufacturing and Related Processes 4
C ISO9000 and CWF (Certified Welding Fabricator) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V What document to use to document Welding PV testing - Supplier to Ford APQP and PPAP 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
A Innovation in Laser Welding Manufacturing and Related Processes 2
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
J Welding Process Validation Plan Qualification and Validation (including 21 CFR Part 11) 19
R Please help me with Welding Symbols Manufacturing and Related Processes 5
F New Inspector Welding Test example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
J Welding - WPS and PQR per AWS D17.1 Questions Various Other Specifications, Standards, and related Requirements 9
S Audit Points for Auditing a Welding Supplier General Auditing Discussions 14
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
A Pressure Vessel Welding Question Various Other Specifications, Standards, and related Requirements 4
A Resistance Welding Customer Complaints - Cracking and Pitting Root Causes Customer Complaints 4
N CE Mark (CE directives) for Welding Electrodes CE Marking (Conformité Européene) / CB Scheme 5
M Welding Inspection Sampling - How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Health and safety within a workshop - welding Occupational Health & Safety Management Standards 7
R Analysis of Welding Parameters - Can Taguchi methods provide equation? Using Minitab Software 11
K Environmental Aspects and Impacts of a Welding Process (ISO 14001) ISO 14001:2015 Specific Discussions 5
K Small Welding Shop going for AC7004 (NADCAP) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Welding - to Validate or Not? If so, How? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Aluminum Castings Defects - Welding and what to Mark with Manufacturing and Related Processes 3
M HSLA100 (High Strength Low Alloy Steel) Welding Procedure and Consumables Manufacturing and Related Processes 3
S What SMAW Filler Metal for Welding 310 material to G-30 Hastelloy material? Manufacturing and Related Processes 6
H Statistical Methods in Welding, Drilling and Cutting Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Can you Passivate Stainless Steel after Spot Welding? Manufacturing and Related Processes 7
M Tig Welding Validation Information help wanted ISO 13485:2016 - Medical Device Quality Management Systems 6
B Does Welding Equipment need or require Calibration General Measurement Device and Calibration Topics 30
C Standards referenced in ISO 3834-2 Welding Other ISO and International Standards and European Regulations 9
Stijloor AIAG Welding System Assessment Webinar ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
F Inspection Companies in China - Rubber and Welding Manufacturing Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
