Migrating to an ISO 13485:2016 Compliant Document Control System
G
gretzles
I am implementing an ISO 13485:2016 quality system. The company has previously been accredited to 9001 but haven't renewed it for several years. There is a legacy of documents that were previously controlled and are being used. These documents use several different document code systems (acquired from merging companies etc).
I'd appreciate any suggestions on how to migrate the existing documents over to the new system. Should I create another doc code system or try to use one of the existing ones. How do I manage the progress while some documents are controlled and others may appear to be (they have a doc code) but aren't controlled.
I want to minimise the confusion to the document users as much as possible.
Marc
The first question I have is what do you have at this point. Is it mostly paper, a mix of paper and electronic?
Is this one facility or do you have multiple locations?
I assume this is a manufacturing company - Is that a correct assumption?
G
gretzles
It is a manufacturing company.
The documents used in production are paper, however there are lots of other electronic documents that have been given codes, but have been let loose in the wild of shared network drives.
There are multiple facilities, however the scope of the quality system is initially only for one site. There is a large product range with only a couple of medical devices to be manufactured at this one location.
medi12
I think it depends on how the document code system is designed and whether you are able to identify all existing documents. There is no requirement regarding a document code system in the 13485 and it simply depends on YOUR requirements. So use the existing system if it is practicable/well established and you be able to identify all existing documents. If this is not the case, design a new Doc-Code-System.
Regarding your uncontrolled documents. The 13485 requires much more controlled document as the 9001, therefore it could be that currently uncontrolled documents must be controlled. It depends regarding all other docs. Either you need it internally and the staff must use these "uncontrolled" documents then I would control it to avoid any confusing.
Medi12
Marc
Document control isn't that big a deal with respect to the essential requirements. In medical devices, though, you will see more emphasis on reviews and approvals, electronic signatures and such (see medi12's post above, for example).
I would map out all the existing systems and make a plan which ties the existing plans together. If you believe there will be stability (no near term mergers, etc.) you should be able to make a plan.
What you will probably find is aspects such as budget restraints and such. That is, you may come up with a good system design which management will not fund (as an example). And, it may be that you can tie the systems together through a reference matrix.
The more details you give here, the more we can give our thoughts.
Do remember there is an entire forum on document control here which you can read through for thoughts.
G
gretzles
I'm leaning towards starting a new system so I can give more meaningful codes (currently everything just gets a sequential number no matter what kind of document it is) and so I can easily identify the documents that are controlled.
M Switching (Migrating) to a new QMS Software Package Document Control Systems, Procedures, Forms and Templates 14
S Migrating from paper based to electronic system 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Computer System Validation - Migrating to SAP Document Control Systems, Procedures, Forms and Templates 5
V Do we need help (a consultant) migrating from AS9100B to AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Anerol C Migrating Current Procedures to a New Procedure template - Are Approvals Needed? Document Control Systems, Procedures, Forms and Templates 7
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 3
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
