P
thanks first,
i am a new learner in this field, so need your detail info so much. I would like to apply this MIL-STD-105E in our company which is electronic instrument manufacturer, we plan to start this plan and i am lacking knowlege in this.
Pls give comments if i wrong. i have seperated the task into 3 groups which is incoming, in proses, and outgoing. For incoming, the quality of supplier is Inspected. The operator will take the sample from the lot which the sample size would be determined from table or the "sqc" calculator. i use level II, normal, switching rule would be only applied if any special case occur. My problem is, at the end of the month, we wish to print up a report or a better way in graph, to know the quality of the suppliers. for this, how am i going to apply? the graph should be what against what??? if let say, i use Number of defective per hunderd unit in my end month quality chart, its only devided by lot size, how about sample size, do we take it into account, if no, is it accurate????and also is it the number of defective is equal to the rejected quantity in that particular sample size or it is the defect items after 100% inspection. or any others way or suggestion to obtain this? Another question is :How and when to apply average outgoing quality (AOQ) and Average outgoing quality limit (AOQL)
thanks a lot.
thanks a lot.
