Mil-Std-1916 Inspection Sampling question
diptankd
Hello everyone,
I have a question I hope you could help me with. If I pull a sample using mil-std-1916 say 192/100,000 on over time and DCMA is not avaliable to do the inspection concurently and I inspect the parts and everything is acceptable in my 192 parts so I accept them and green tag them and I have all my documentaion there so the parts are ready to be released. In the morning DCMA comes to work and pulls there own sample to there requirements and finds a defect, I did not check the parts 100% the 192 that I checked were good. I realize that the parts need to be screened for any more defects but, can I be written up for passing the parts even if my sample was good, could they hold me acoutable for passing defective parts? #2. If they are not doing the over time my manager is requiring me to do can DCMA tell me that I can or cannot check certain parts. unless they are present. Let me know what you think.
diptankd
O
osmqc
I have a different question: In Mil-Std-1916, what is the meaning of "single-sided specification" and "double-sided specification"?
David-D
MIL-STD-1916 utilizes single and double sided specifications in reference to variable sampling. Single sided means that there is only one end of the specification (minimum or maximum) she double sided specifications have both upper and lower limits. For example, "3.00" min work be single sided specification while 3+/- 0.005" is double sided.
This comes into account because the variable sampling of 1916 uses one parameter "k" for both single and double sided specs. It is analogous to a Cpk, assessing how close to the spec limit(s) the process/product is. For two sided specifications, 1916 additionally assessed the "F" parameter which is similar to the Cp assessing the potential capability of the process. Both of these are in addition to the requirement that all the individual samples conform to requirements. I'd suggest you look at paragraph 5.2.2.2.3 and table III of the spec
as well as the examples of 30.2 and 30.3 in the appendix. You may also find the guidance handbook MIL--HDBK-1916 useful as well.
If you don't have it, MIL-STD-1916 is available at:
http://quicksearch.dla.mil/qsDocDetails.aspx?ident_number=120287
David
Steve Prevette
Deming Disciple
Hello everyone,
In ANY random sample there is always the possibility that the parts you HAPPENED to choose were GOOD, but all the rest of the production run might be BAD. Highly unlikely (that is the whole point of random sampling) but could happen on occasion. You can always have a "false negative" now and then.
It should also be pointed out that you may not have been unlucky, and got a "representative" sample of the population and justifiably "Passed" it. I can just about guarantee that if you made 100,000 items, and the AQL is say 1%, that there is at least ONE bad item in the 99,808 items, and most likely about 998 of them!
What level of AQL and sampling did the contract specify? That would be the real question of accountability for passing defective parts.
T Significance of Key Characteristic definition change vs. MIL-STD-1916 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S MIL-STD-1916 vs MIL-STD-105E, which do you choose? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D The Best Way to Document In-Process Inspections using MIL-STD-1916 1/12 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C MIL-STD-1916 vs. MIL-STD-105E - What are the differences between the two documents? Quality Management System (QMS) Manuals 1
C MIL-STD-105E vs MIL-STD-1916 - Is 1916 the same as C=0? Preventive Action and Continuous Improvement 4
Marc MIL-STD-1916 "Acceptance on Zero (AOZ) Sampling Inspection" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Marc MIL-STD-810H - 31 January 2019 Various Other Specifications, Standards, and related Requirements 0
K MIL-STD-2000 Certification Requirements Manufacturing and Related Processes 9
G Mil-Std-130N, can calibration be a nationally traceable standard? Various Other Specifications, Standards, and related Requirements 0
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
J Mil Std 810 G test 516 vs IEC 60068-2-27 - Classic Waveform Shock Various Other Specifications, Standards, and related Requirements 1
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
alonFAI Fungus Testing per MIL-STD-810F Reliability Analysis - Predictions, Testing and Standards 6
E Post Machining Casting Defects with MIL-STD-2175 Requirements - Responsibility Manufacturing and Related Processes 9
R MIL-STD-120 replacement? Calibration Work Instructions refer to MIL-STD-120 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Mikishots Trying to locate a LEGIBLE MIL-STD-105E copy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
K Mil-Std-2132 (Nondestructive Examination Requirements) needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Difference between MIL-STD-105 and ISO 2859 AQL - Acceptable Quality Level 2
H Section Modulus - MIL-STD-883, Method 2004 - Definition Manufacturing and Related Processes 1
S MIL-STD-1686 for ESD Compliance help wanted Various Other Specifications, Standards, and related Requirements 3
V Using an AQL of 0,0 with MIL STD 105E AQL - Acceptable Quality Level 4
S Parts, Materials and Processes (PMP) Control Plan - Mil-Std-3018 Misc. Quality Assurance and Business Systems Related Topics 1
F MIL-STD-2073-1, Standard Practice for (US) Military Packaging Various Other Specifications, Standards, and related Requirements 0
M Evolution has taken away MIL-STD-1520 C - What to use now? MRB and PMR Nonconformance and Corrective Action 5
P Using Mil-STD-2000A as soldering specification Various Other Specifications, Standards, and related Requirements 14
T Mil Std Certification for a Semiconductor Burn-In Process provider Various Other Specifications, Standards, and related Requirements 2
A Definition Functional and Allocation Baselines - MIL-STD-973 Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Tell me why I should no longer reference MIL STD 105E? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
H Big Batch (Large Lot) Sampling - Label Printing - MIL-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
I Asian Supplier Sampling Plans besides MIL-STD-105? My thought was ISO 2859? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P MIL-STD 1235C - Is it still Valid or has it been Superseded by another Standard? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B. Various Other Specifications, Standards, and related Requirements 4
D Why should you use a Configuration Management Standard such as EIA 649 or Mil-Std-973 Document Control Systems, Procedures, Forms and Templates 3
D Why MIL-STD-105E is obsoleted but ANSI/ASQC Z1.4 is still implemented? Need Opinion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
A Looking for MIL-STD-1686B (MIL-STD-1686 revision B) Various Other Specifications, Standards, and related Requirements 4
T Acceptable AS9100 Receiving Inspection Sampling Plan - ANSI/ASQCZ1.4 vs. Mil-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E I need MIL-DTL-5765 - MIL-STD-5765 F Various Other Specifications, Standards, and related Requirements 2
G Does ISO 17025 Cover the elements in MIL-STD-45662A? ISO 17025 related Discussions 5
GStough Has Anyone Heard of Mil Std 155D? Various Other Specifications, Standards, and related Requirements 4
B How to work with Mil Std 105E OC curves? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S Receiving Inspection Plan Sample Size - Measuring Mil-Std Rivets - Fasteners Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Qualification Testing of New Products - Is there a MIL-STD or ANSI standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Mil-Std-105e - Average outgoing quality (AOQ) & Average outgoing quality level (AOQL) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to calibrate a Bore Indicator? MIL-STD-120 "Gage Inspection"? General Measurement Device and Calibration Topics 4
Marc The History and Rationale of the MIL-STD-810 testing standard Book, Video, Blog and Web Site Reviews and Recommendations 0
