MIL-STD-1916 vs MIL-STD-105E, which do you choose?
Saizi
I’m in a new company. I need to establish incoming material acceptance criteria. I have two options, MIL-STD-1916 and MIL-STD-105E.
I know MIL-STD-1916 was intended to replace MIL-STD-105E, but MIL-STD-105E is still widely used, and some companies use MIL-STD-1916.
If you are in the position to choose, which one do you choose, why?
CarolX
Hi Saizi and welcome to the Cove :bigwave:,
I moved your thread to this board.
If you scroll down to the bottome of this page you will find links to threads discussing this same subject.
harry
Welcome,
I am afraid you had got your facts wrong. Mil-Std-105E was discontinued but still in use in many countries. The commercial counterpart (replacement) is ANSI/ASQC Z1.4 or ISO 2859. I am not familiar with Mil-Std-1916 except that it is more associated with c=0 sampling and is definitely not a replacement for Mil-Std-105E.
Scroll down to the 'Similar Discussion Threads' box below to read some of our previous (and related) discussions.
Saizi
OK, I see.
Mil-Std-1916 is different to Mil-Std-105E.
Mil-Std-105E is more concerned with verifying the final product’s quality, providing enough protection to the supplier and the customer.
Mil-Std-1916 is more concerned with driving suppliers to continuous improvement, providing less protection to the supplier and the customer.
Mil-Std-1916 can not replace Mil-Std-105E.
I also read “MIL-STD-105E NOTICE2 26 March 2001”, which states,
“MIL-STD-105E, dated 10 May 1989, is hereby canceled without replacement. Current DOD. PREFERRED METHODS FOR ACCEPTANCE OF PRODUCTS are described in MIL-STD-1916, dated 1 April 1996, and should be considered for future acquisitions.”
Can anyone tell me if the Department of Defense has stopped using Mil-Std-105E and turned to Mil-Std-1916? I’m interested in this news because I think Mil-Std-1916 is a good standard, and I want to use it for incoming material quality inspection.
Stijloor
OK, I see.
History of this great classic Standard. Look here. And here.
Notice of cancellation.
Stijloor.
Saizi
The reason I want to use Mil-Std-1916 is that I don’t really care how good the inspection method is at identifying the quality level. If the incoming material’s quality is really bad, and I fail to find this out during the sampling inspection, the operators, who will use the material to do assembly, will always be there to point out the defetives, so I will know the exact incoming material’s quality level in the end anyway.
I’m more interested in put some pressure on the suppliers to let them improve their quality. The rejection rate of Mil-Std-1916 seems more visibly connected with the final yield than the rejection rate of Mil-Std-105E.
Stijloor
A search on "Incoming Inspection" here at The Cove Forums revealed this.
Some of the threads and posts may be of interest to you.
Stijloor.
harry
Mil-Std-1916 is certainly superior in that when lot acceptance is based on only a sample of the total lot quantity, all of the samples should be defect free for outright acceptance.
Sure, you can do what you like if you are the customer but you must specify it during the contract negotiation stage. There certainly will be some cost implications if you choose to implement a zero acceptance plan.
Saizi
Does anyone have some success stories in implementing Mil-Std-1916 for incoming material sampling to share?
T Significance of Key Characteristic definition change vs. MIL-STD-1916 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D The Best Way to Document In-Process Inspections using MIL-STD-1916 1/12 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Mil-Std-1916 Inspection Sampling question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C MIL-STD-1916 vs. MIL-STD-105E - What are the differences between the two documents? Quality Management System (QMS) Manuals 1
C MIL-STD-105E vs MIL-STD-1916 - Is 1916 the same as C=0? Preventive Action and Continuous Improvement 4
Marc MIL-STD-1916 "Acceptance on Zero (AOZ) Sampling Inspection" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Marc MIL-STD-810H - 31 January 2019 Various Other Specifications, Standards, and related Requirements 0
K MIL-STD-2000 Certification Requirements Manufacturing and Related Processes 9
G Mil-Std-130N, can calibration be a nationally traceable standard? Various Other Specifications, Standards, and related Requirements 0
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
J Mil Std 810 G test 516 vs IEC 60068-2-27 - Classic Waveform Shock Various Other Specifications, Standards, and related Requirements 1
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
alonFAI Fungus Testing per MIL-STD-810F Reliability Analysis - Predictions, Testing and Standards 6
E Post Machining Casting Defects with MIL-STD-2175 Requirements - Responsibility Manufacturing and Related Processes 9
R MIL-STD-120 replacement? Calibration Work Instructions refer to MIL-STD-120 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Mikishots Trying to locate a LEGIBLE MIL-STD-105E copy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
K Mil-Std-2132 (Nondestructive Examination Requirements) needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Difference between MIL-STD-105 and ISO 2859 AQL - Acceptable Quality Level 2
H Section Modulus - MIL-STD-883, Method 2004 - Definition Manufacturing and Related Processes 1
S MIL-STD-1686 for ESD Compliance help wanted Various Other Specifications, Standards, and related Requirements 3
V Using an AQL of 0,0 with MIL STD 105E AQL - Acceptable Quality Level 4
S Parts, Materials and Processes (PMP) Control Plan - Mil-Std-3018 Misc. Quality Assurance and Business Systems Related Topics 1
F MIL-STD-2073-1, Standard Practice for (US) Military Packaging Various Other Specifications, Standards, and related Requirements 0
M Evolution has taken away MIL-STD-1520 C - What to use now? MRB and PMR Nonconformance and Corrective Action 5
P Using Mil-STD-2000A as soldering specification Various Other Specifications, Standards, and related Requirements 14
T Mil Std Certification for a Semiconductor Burn-In Process provider Various Other Specifications, Standards, and related Requirements 2
A Definition Functional and Allocation Baselines - MIL-STD-973 Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Tell me why I should no longer reference MIL STD 105E? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
H Big Batch (Large Lot) Sampling - Label Printing - MIL-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
I Asian Supplier Sampling Plans besides MIL-STD-105? My thought was ISO 2859? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P MIL-STD 1235C - Is it still Valid or has it been Superseded by another Standard? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B. Various Other Specifications, Standards, and related Requirements 4
D Why should you use a Configuration Management Standard such as EIA 649 or Mil-Std-973 Document Control Systems, Procedures, Forms and Templates 3
D Why MIL-STD-105E is obsoleted but ANSI/ASQC Z1.4 is still implemented? Need Opinion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
A Looking for MIL-STD-1686B (MIL-STD-1686 revision B) Various Other Specifications, Standards, and related Requirements 4
T Acceptable AS9100 Receiving Inspection Sampling Plan - ANSI/ASQCZ1.4 vs. Mil-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
E I need MIL-DTL-5765 - MIL-STD-5765 F Various Other Specifications, Standards, and related Requirements 2
G Does ISO 17025 Cover the elements in MIL-STD-45662A? ISO 17025 related Discussions 5
GStough Has Anyone Heard of Mil Std 155D? Various Other Specifications, Standards, and related Requirements 4
B How to work with Mil Std 105E OC curves? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S Receiving Inspection Plan Sample Size - Measuring Mil-Std Rivets - Fasteners Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Qualification Testing of New Products - Is there a MIL-STD or ANSI standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Mil-Std-105e - Average outgoing quality (AOQ) & Average outgoing quality level (AOQL) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to calibrate a Bore Indicator? MIL-STD-120 "Gage Inspection"? General Measurement Device and Calibration Topics 4
Marc The History and Rationale of the MIL-STD-810 testing standard Book, Video, Blog and Web Site Reviews and Recommendations 0
