MIL-STD-2000 Certification Requirements
K
koehlke
I am auditing a contract manufacturer of cable assemblies. The drawing they are building to calls out certification to MIL-STD-2000, as a minimum. I know that the specification was cancelled without a superseding document, and I remember another document that states that it cannot be used in new acquisitions. The assembler that performed the assembly was certified to J-STD-001 and IPC-620 at one time, but those certifications have expired. Does the supplier have to be certified to MIL-STD-2000 or have active certification to J-STD-001 and IPC-620 to be compliant or is this a nonconformance?
normzone
No - the drawing needs to be updated or they need to have a record from their customer specifying what they really want.
K
koehlke
Sorry for the late answer. I didn't get an email about your post.
They did bring it up in Contract review that MIL-STD-2000 was called out and they countered with the obsolescence and J-STD-001 in their review.
I'm not sure I agree with holding companies to be certified to obsolete specifications when there are current industry accepted specifications. MIL-STD-2000 was obsoleted but J-STD-001 was not adapted by the DOD as its replacement so this is a grey area for me.
Al Rosen
The drawing should have been updated or the exception noted on the PO. If neither was done, technically it's a finding and they can work out a CA with the customer, who will probably accept the J-std since they will not have to change the drawing or PO and the j-std is equivalent to the mil-std.
BTW, that issue at Contract review should have resulted in an action item.
K
koehlke
Ok that makes sense.
One last question. Does J-STD-001 and IPC/WHMA-A-620 require ongoing certification? The supplier has assemblers and inspectors that were trained and certified to J-STD-001 and IPC/WHMA-A-620, but have allowed the certifications to expire. Their people are still doing the same jobs they were doing when they were certified, and good performance reviews. Does this meet the requirements of 1.10 Personnel Proficiency in J-STD-001, and 1.11 Personnel Proficiency of IPC/WHMA-A-620 or do they need to be re-certified to meet the spec requirements?
Al Rosen
Good performance reviews don't meet the requirements.
The certs expire after 2 years and re-certification is required. Another issue is that J-STD-001 is a process standard with more requirements than operator certification that the Contract Manufacturer will probably not be meeting.
QLearning
Al, my question regarding J-std-001 requirements are a bit broader. We are a pcb assembly house. One of our customers has asked us about building to J-STD-001. One area we are evaluating, is how this requirement to us will affect our customer part vendors, specifically, our pcb vendor. I see in the standard Section 9 on PCB requirements, but not sure what else we need to look at for our vendors to meet.
Any help will be greatly appreciated.
Al Rosen
Al, my question regarding J-std-001 requirements are a bit broader. ....
J-STD-001 is for your process. Look at table 1-1 in J-STD-001 and determine the applicable standard(s) required for the PCB type. Be sure to understand what they are and verify that your supplier is knowledgeable in the requirements of the standards.[/QUOTE]
QLearning
Al,
Thank you very much for your quick reply. Based on your response, it seems that there should be no reason for our PCB fab vendor to increase price to us, just because we are building to J-std-001. Is this assumption correct?
B New to ISO 14971. Comparing to MIL-STD-882 ISO 14971 - Medical Device Risk Management 7
C What Theory is MIL-STD-105E Sample Size Code Letters Based on? Quality Tools, Improvement and Analysis 3
C MIL STD vs ASTM General Measurement Device and Calibration Topics 4
D ANSI/ASQC Z1.9 VS MIL-STD-1916 for Continuous Sampling Lean in Manufacturing and Service Industries 2
Marc MIL-STD-810H - 31 January 2019 Various Other Specifications, Standards, and related Requirements 0
G Mil-Std-130N, can calibration be a nationally traceable standard? Various Other Specifications, Standards, and related Requirements 0
M Help interpreting MIL-STD-105E Single Sampling Plans Tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A MIL STD 105 D or ISO 2859-2? Receiving Metal Sheets Quality Tools, Improvement and Analysis 6
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
J Mil Std 810 G test 516 vs IEC 60068-2-27 - Classic Waveform Shock Various Other Specifications, Standards, and related Requirements 1
C Medical Device Tracking Sampling Plan using MIL-STD-105E Other US Medical Device Regulations 4
alonFAI Fungus Testing per MIL-STD-810F Reliability Analysis - Predictions, Testing and Standards 6
E Post Machining Casting Defects with MIL-STD-2175 Requirements - Responsibility Manufacturing and Related Processes 9
R MIL-STD-120 replacement? Calibration Work Instructions refer to MIL-STD-120 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Mikishots Trying to locate a LEGIBLE MIL-STD-105E copy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
K Mil-Std-2132 (Nondestructive Examination Requirements) needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Difference between MIL-STD-105 and ISO 2859 AQL - Acceptable Quality Level 2
H Section Modulus - MIL-STD-883, Method 2004 - Definition Manufacturing and Related Processes 1
S MIL-STD-1686 for ESD Compliance help wanted Various Other Specifications, Standards, and related Requirements 3
V Using an AQL of 0,0 with MIL STD 105E AQL - Acceptable Quality Level 4
S Parts, Materials and Processes (PMP) Control Plan - Mil-Std-3018 Misc. Quality Assurance and Business Systems Related Topics 1
F MIL-STD-2073-1, Standard Practice for (US) Military Packaging Various Other Specifications, Standards, and related Requirements 0
M Evolution has taken away MIL-STD-1520 C - What to use now? MRB and PMR Nonconformance and Corrective Action 5
T Significance of Key Characteristic definition change vs. MIL-STD-1916 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Using Mil-STD-2000A as soldering specification Various Other Specifications, Standards, and related Requirements 14
T Mil Std Certification for a Semiconductor Burn-In Process provider Various Other Specifications, Standards, and related Requirements 2
A Definition Functional and Allocation Baselines - MIL-STD-973 Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
S MIL-STD-1916 vs MIL-STD-105E, which do you choose? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
C How to select the requirements for Continuous Sampling Plan (CSP-1&F), Mil-Std 1235C? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Tell me why I should no longer reference MIL STD 105E? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
H Big Batch (Large Lot) Sampling - Label Printing - MIL-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
I Asian Supplier Sampling Plans besides MIL-STD-105? My thought was ISO 2859? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P MIL-STD 1235C - Is it still Valid or has it been Superseded by another Standard? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Electronics Die Component - Military Standard 883 vs. MIL STD 750 TM2010 B. Various Other Specifications, Standards, and related Requirements 4
D Why should you use a Configuration Management Standard such as EIA 649 or Mil-Std-973 Document Control Systems, Procedures, Forms and Templates 3
D Why MIL-STD-105E is obsoleted but ANSI/ASQC Z1.4 is still implemented? Need Opinion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
Al Rosen Looking for MIL-STD-1686B (MIL-STD-1686 revision B) Various Other Specifications, Standards, and related Requirements 4
D The Best Way to Document In-Process Inspections using MIL-STD-1916 1/12 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T Acceptable AS9100 Receiving Inspection Sampling Plan - ANSI/ASQCZ1.4 vs. Mil-STD-105E Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
D Mil-Std-1916 Inspection Sampling question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E I need MIL-DTL-5765 - MIL-STD-5765 F Various Other Specifications, Standards, and related Requirements 2
G Does ISO 17025 Cover the elements in MIL-STD-45662A? ISO 17025 related Discussions 5
GStough Has Anyone Heard of Mil Std 155D? Various Other Specifications, Standards, and related Requirements 4
B How to work with Mil Std 105E OC curves? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
S Receiving Inspection Plan Sample Size - Measuring Mil-Std Rivets - Fasteners Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Qualification Testing of New Products - Is there a MIL-STD or ANSI standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Mil-Std-105e - Average outgoing quality (AOQ) & Average outgoing quality level (AOQL) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S How to calibrate a Bore Indicator? MIL-STD-120 "Gage Inspection"? General Measurement Device and Calibration Topics 4
