Millipore Cleanliness Test Experiences
Bill Evans
#11
Re: Anyone with Millipore cleanliness test experiences?
Does anyone have a US distributor or contact information for an inexpensive
1) Filters
2) Labware (beakers, filter flask, Buchner funnel, stainless steel wash tub,
brushes)
3) Drying Oven
4) Wiegh scale for weighing filters & samples
rstocum
#12
bcsnave,
I found the following suppliers for these materials to be best:
Barney Corporation - www.barneycorp.com - filters
LSS - www.lss.com - labware of all kinds
Quincy Lab, Inc. - Model 10 lab oven
Quick's Supply - lab balances
I also recommend the Millipore company for the actual filtration system. You can get the individual items in the system for less by purchasing separately, but there is a lot to be said for being able to unpack the equipment, knock it together in 5 minutes, and start using it. Millipore was only about $100 more anyway.
True Position
#14
Are you associated with these organizations? ;)
Stijloor.
I'd give him the benefit of the doubt, if someone asked me for a company to purchase lab glassware from I'd recommend LSS. They are fairly big in the industry and usually nice to work with. As an added bonus you can count all the dogs in the catalog and try to win a prize.
Stijloor
#15
Hawat,
Over the years, I have made many recommendations here at The Cove Forums. To remove all doubt, I put a disclaimer in my post stating that I am not associated with the recommended organization.
Stijloor.
rstocum
#16
No affiliations with any of them. If I am ever recommending who to buy solenoids or medical equipment from, be highly suspicious of my motives. The millipore was a major pain in my rear for a while, so I am happy to help anyone get a leg up on implementing it.
John Peter R
#17
Hi rstocum,
Did you ever find the source of your non-ferrous metallic particles? Did you consider contamination coming from the brushes you were using to clean off the parts?
rstocum
#18
Bear in mind this was nearly a decade ago, and I no longer work there. Yes, we did consider contamination from the brushes and the rest of the cleaning equipment, which consisted of a stainless steel tub and funnel, and several beakers. The entire set of cleaning equipment was cleaned in our lab sink at the conclusion of each round of testing. At one point, for thoroughness, we did a test after cleaning the set once, and another test after cleaning the set three times. There was no difference. We also examined our parts and the elements of the cleaning equipment that would fit, under our microscope. The debris was present on the parts before testing, and present in much lower amounts on the cleaning equipment. I don't remember if I mentioned any of this in previous posts, but we eventually found the main source of the stuff was in the parts cleaning system the parts were cleaned in. We ended up creating a preventive maintenance protocol and schedule to drain the cleaning tanks, scrub and rinse them, and wipe down the air dry chamber. The particle size and quantity went way down after implementing that.
somashekar
#19
Terminal filtration of your cleaning media can be mostly your savior....
You may get various types based on the fluid you handle and the pressure used.
V Millipore Testing & Component Cleanliness Management Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
D ISO: 13485:2016 Sec. 7.5.2 (C) - Requirements for cleanliness of product or contamination control ISO 13485:2016 - Medical Device Quality Management Systems 2
D CMM Room cleanliness requirements ISO 17025 related Discussions 7
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
V Cleanliness/Bioburden for Non-Sterile Gas Path Medical Devices Other Medical Device Regulations World-Wide 7
M Cleanliness and Contamination question (Medical Device Component Manufacturer) ISO 13485:2016 - Medical Device Quality Management Systems 2
GURU SDI Cleanliness Requirements for Initial Samples Customer Complaints 4
M Orthopedic Devices and Implants Manufacturing Cleanliness Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
S The Right Cleanliness Test Standard for Coolers and Radiators Other ISO and International Standards and European Regulations 3
J ISO 13485:2003 Section 7.5.1.2.1 Cleanliness of Product ISO 13485:2016 - Medical Device Quality Management Systems 1
S Cleanliness Requirements for Raw Materials Used in a Controlled Environment Quality Manager and Management Related Issues 4
C ISO 13485 Clause 7.5.1.2.1 Cleanliness of Product and Contamination Control Question ISO 13485:2016 - Medical Device Quality Management Systems 7
B ISO 13485 7.5.1.2.1 Cleanliness and Contamination of Product Requirements ISO 13485:2016 - Medical Device Quality Management Systems 5
R Cleanliness of Product & Service and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 6
C Cleanliness Specifications that apply to non-sterile medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
J Can "7.5.1.2 cleanliness of product and contamination control" be non-applicable? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Dyne Pen Testing for cleanliness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S What is ISO 16232? Road vehicles - Cleanliness IATF 16949 - Automotive Quality Systems Standard 7
ScottK Service Media - Definition in NASA KSC-C-123H - Surface Cleanliness for Fluid Systems Various Other Specifications, Standards, and related Requirements 2
D Tube Cleanliness Level - 10 microns nominal - New Customer Requirement Career and Occupation Discussions 3
J Cleanliness of Manufacturing Area for Orthopedic Devices and Implants ISO 13485:2016 - Medical Device Quality Management Systems 13
Q Production on Plastics Drums - Process Flow and Maintaining Cleanliness Manufacturing and Related Processes 2
M Ford Cleanliness Testing Specification ES-XXXX-6B616-AA for Valvetrain Components Various Other Specifications, Standards, and related Requirements 5
R Definition Cleanliness standard - What is? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
I Assembly Work Surface Cleanliness - Plastic Table Tops and Embedded Metal Chips Manufacturing and Related Processes 9
A 7.5.1.2.1 Cleanliness of Product and Contamination Control - Service Provider Service Industry Specific Topics 2
M Definition Cleanliness - TS 16949:2002 Clause 6.4.2 - Cleanliness Of Premises - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 11
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
