Min working experience for IATF 16949 third party auditor
Rameshwar25
Dear all
As per IATF rule book 5, clause 4.2 d), for a new IATF 1649 third party lead auditor, the required working experience is as following.
"must have four (4) years full time appropriate practical experience (including two (2) years dedicated to Quality Assurance and/or Quality Management activities) in within the past fifteen (15) years in an automotive manufacturing organization."
Based on this requirement, which one of these statement is correct.
1. Only four years working experience is sufficient for eligibility provided this four years experience is within last fifteen years.
OR
2. Fifteen years working experience is required out of which fours years should be in quality assurance or QMS.
Regards
RS
Coury Ferguson
Moderator here to help
Dear all
OR
Regards
RS
You may want to see if a 3rd Party CB would hire you and you would receive the balance of training needed. Just my opinion.
Rameshwar25
Yes, I want to know whether a person having five years experience (from 2013 to 2018) can be accepted by a CB for IATF 16949 third party auditor course.
Johnson
Dear all
OR
Regards
RS
Firstly, there is an error in your description, the fifteen (15 ) years should be ten (10) years.
I quoted the original content of the IATF "Rules for achieving and maintainning IATF recognition, 5th edition, 1st November 2016" as follows:
4.2 d) has four (4) years full time appropriate practical experience (including two (2) years dedicated to Quality Assurance and/or Quality Management activities) in the past ten (10 ) years in an organization meeting the applicability of IATF 16949 ( see section 1.0)
The interpretation is:
  • Totally you have to have at least 4 years working experience. This experience should be full time and practical, the work should be at an automotive organization which is applicable for IATF 16949 certification scope.
  • Among these 4 years, you must work on QA or QM function more than 2 years.
  • These 4 years working experience should be obtained in the recent 10 years. For example, if you worked as QM in automotive industry for 6 years in 12 years ago, but after that you work in a non-automotive industry, that 6 years of experience will not be counted.
  • You don’t need 10 years or working experience, 4 years is sufficient if it meet above requirements.
So your statement 1 would be correct if you have changed "fifteen years" to "ten years"
Hope it helps !
Johnson
T CMM Max/Min data and Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Stability with min/max sealing parameters? Other Medical Device Related Standards 1
S Max and Min form diameter inspection IATF 16949 - Automotive Quality Systems Standard 4
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
H Max and Min Load Determination for Steam Sterilization of Liquds EU Medical Device Regulations 1
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
kedarg6500 A380 Aluminium Elongation & Specific Gravity Min OR Max Various Other Specifications, Standards, and related Requirements 2
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
R CSA Descriptive Test Reports: PC-B's min 1.6mm thick requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
2 MIN/MAX - Oversea Supplier Raw Material Supermarket Pull Systems Lean in Manufacturing and Service Industries 3
R How to assess capability for parameters which has got either Min values or Max values Statistical Analysis Tools, Techniques and SPC 2
S Offline Laboratory Scale Gauges for Min Max Diameter of Round Steel Bars General Measurement Device and Calibration Topics 6
I Which control chart to use for SPC control for torque moment which value is min 15 Nm Statistical Analysis Tools, Techniques and SPC 7
R Effective case depth of .508mm MIN. How do I measure this? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D CP CPk from Min Max Data? Statistical Analysis Tools, Techniques and SPC 5
I Percentage of tolerance reported by supplier using the MIN or MAX dimension values Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q Gage Supplier - Need a 72" (min) Digital Read Out LLM for the Shop Floor General Measurement Device and Calibration Topics 2
P Rp with a 1.33 min Cpk (Rp?) - Anyone know what Rp represents? Capability, Accuracy and Stability - Processes, Machines, etc. 3
J How do I calculate the percentage of errors, when I know min, max, mean, cp and CPK Capability, Accuracy and Stability - Processes, Machines, etc. 3
N Working Voltage when high voltage flyback voltage is present IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T Working Voltage according to 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J Advice on documentation for project I am working on... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
G Why 1 MOPP to main voltage but 2 MOPP to working voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
shimonv Working with a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
shimonv Working with a software developer who is not setup for IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
John Broomfield Guidance on Safe Working During Covid-19 Pandemic Misc. Quality Assurance and Business Systems Related Topics 5
S Experience working with TUV SUD or Rheinland, and/or BSI Registrars and Notified Bodies 7
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
M Informational TGA-led IMDRF Personalised Medical Devices working group meets in Canberra Medical Device and FDA Regulations and Standards News 0
M Informational EU – Minutes of the 24 July 2019 SCHEER Working Group on safety of breast implants in relation to anaplastic large cell lymphoma (BIA-ALCL) meeting Medical Device and FDA Regulations and Standards News 0
Watchcat MDD, MDR/IVDR, Working Groups, Expert Panels, MEDDEVs and Other EU Guidances EU Medical Device Regulations 32
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
M Informational EU – 12th Meeting of the Working Group on Guidelines on benefit – risk assessment of Phthalates in Medical Devices Medical Device and FDA Regulations and Standards News 0
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Sidney Vianna ISO 9001 News Tirelessly Improving the Brand Integrity of ISO 9001 - Working Group under ISO TC 176 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
E Feeling ill when working with adhesives Occupational Health & Safety Management Standards 2
M Informational EU – SCHEER – Minutes of the Working Group meeting on guidelines on the benefit-risk assessment of the presence of phthalates in certain medical devic Medical Device and FDA Regulations and Standards News 1
T IEC60601-1: Isolation for an applied part with working voltage of 1500Vp. IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
J AS9100 - Working Outside of Scope of Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S ISO 13485 Cl. 6.2 Human Resources - Personnel working within the QMS ISO 13485:2016 - Medical Device Quality Management Systems 4
K Outsourced Major Processes - Working for Two Sister Companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Working for multiple CB's (Certification Bodies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
N Anyone working on NIST SP 800-171 (Network and Information Security)? Records and Data - Quality, Legal and Other Evidence 4
O Cleaning API Rotary Shoulder Connections Working Mates exposed to Outside Weather General Measurement Device and Calibration Topics 1
R Working on a 510(k) that is very similar to the predicate device Other US Medical Device Regulations 4
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
