Minimum/ mandatory core processes AS9100
What are the Minimum/ mandatory core processes in AS9100 company?
I know a company providing (Service) a special process and they called Purchasing is a support process and not one of their core.
they also have 8.5.6 and 8.1.2 as support
I understand that AS9101 calls out Clause 8 to be core and PEAR, KPI,. etc is required for all Clause 8
please correct me if I am wrong here
It’s dependent on the scope. There are no accurate generalities. If a product manufacturer, buying isn’t a core process.
The company is a heat Treat Company
The organization outsources processing includes (tensile testing, X-ray testing, cleaning blasting & NDT). The organization also purchase from supplier (Thermocouples, wires, TUS temperature uniformity survey, calibration for hardness testing, etc.).
- AS9101 calls out clause 8 as an operational process and requires PEAR and KPI.. etc, correct?
- Company also listed (8.1.2 and 8.5.6) as support so those are not included in the PEARs. How product traceability, serial numbers, production changes.. etc are not operational and require PEAR according to AS9101?
Core processes are usually those which the organization does which is their “competency” - in this case heat treatment. They choose to buy those services such as testing and items like thermocouples are not product. Purchasing isn’t a core competency.
Traceability etc are things which are carried out but are not processes.
John Broomfield
The clue is in the name: core.
The core process is what you do to convert the needs of customers into cash in the bank (aka: the value stream). Or more simply: Get Work, Do Work, Get Paid.
Usually, for an SME, it’s just one; your service which may include manufacturing service.
Your core process will probably comprise several cross-functional or key processes that rely on the effective interaction of functions or departments. Your system also includes several processes that support, direct or improve the core to fulfill the mission of your organization.
what I meant by Core is their Key/ operational processes (according to ISO 9101), which is calls out the operational processes in clause 8.0 and they are requires PEAR and KPI meaning those are Core / / Key/ operational processes (contract, purchasing, design, production, repair)., correct me if I am wrong here !!
I have audited hundreds of companies over 6 years and have never seen a company calls out 8.1.2 support and not included it in their production process
or 8.5.6 (production changes) is not included in their production PEAR
So what if they determine that there is no Key/ core process at all? I should be ok with that too? Just because "they" determined?
btw, those changes in their manual done by someone just start QM position with Zero experience in AS9100
Please see my comment above this message and correct me if I am wrong. Thanks
S Minimum Samples for DFM discussion APQP and PPAP 10
S Minimum Retention Time for Records of internal audit results as per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C Document Record/Template Minimum Requirements ISO 13485:2016 - Medical Device Quality Management Systems 3
F Self-test minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
P Minimum Distance from Floor to Underneath of Machine Human Factors and Ergonomics in Engineering 5
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
F Regulatory Compliant Quality Management System - Bare Minimum EU Medical Device Regulations 2
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
somashekar ISO 13485 plus ISO 9001:2015 will now attract a minimum 2 day upgrade audit ISO 13485:2016 - Medical Device Quality Management Systems 9
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
B What is the minimum sample required for Performance Evaluation for IVD ? EU Medical Device Regulations 3
D Minimum requirements/experience/qualifications to be head of quality Career and Occupation Discussions 6
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Minimum documents required by AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
J Minitab Sample Size Calculation: 1 Sample t vs Minimum Sample Size for Means Using Minitab Software 3
G Why for a Shewhart chart the minimum feasible value for APL is 2401 units? Statistical Analysis Tools, Techniques and SPC 8
A Minimum Testing Requirements for a Clear Protective Equipment Barrier (Class II 510K) Other US Medical Device Regulations 1
V Critical Characteristics - Capability for a Minimum Specification APQP and PPAP 11
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Minimum Organization Structure to support TS16949 IATF 16949 - Automotive Quality Systems Standard 5
Q Minimum content required in a Quality Manual as per ISO 9001:2008 Quality Management System (QMS) Manuals 6
A ISO 13485 Supplier Monitoring Minimum Requirements Supplier Quality Assurance and other Supplier Issues 3
T New Packaging Line Performance Qualification (PQ) - Minimum Test Times ? Qualification and Validation (including 21 CFR Part 11) 3
F How to calculate the minimum Value of Mass needed for Scales Calibration? General Measurement Device and Calibration Topics 6
