Minimum number of procedures to satisfy ISO9001 requirements
Carrie11
Hi
I am new to the forum and could do with a bit of guidance. :bigwave: I am reviewing a Quality Manual and Procedures Manual which I have inherited. The format still appears to be to the 1994 standard i.e. a procedure for everything. As I understand it the 2000 edition only requires 6 mandatory documented procedures. Am I correct in my understanding and has anybody achieved certification with this minimum amount of procedures?
Hi
Six is the "magic" number, but the number of documented procedures you have should be determined by needs of the business, not the requirements of the standard (assuming you have the ones required).
Colin
Agree with Jim on this. However, I recently worked with a client who had just 5 documented procedures (documents and records were combined) and they had certification. Was it a good system? Not really, the company did not understand it and asked me to help them develop some more documented procedures.
You can have just one document that addresses all of the required procedures. (Note that "procedure," as in the phrase "documented procedure," is synonymous with "process."
Colin
Jim, nice to see that point clarified in CD1 of the proposed revised version too.
V
vanputten
Hello Jim:
Is the phrase "documented procedure" really synonymous with "process?" I do not agree based on the way you have written this but I think I understand your intent.
We may have many, may processes. ISO 9001 only requires 6 processes to be documented in as many documents as the oprganization chooses to have.
Also, there are many clauses that say an organization must have as many processes and documented procedures as needed by the organizaiton to have an effective management system. "Effective" is consistent product that meets requirements and satisfies the customer.
So my answer to the original question is that ISO 9001 requires as many documented procedures as you need but at least 6 processes must be documented.
Regards,
Dirk
Hello Jim:
Regards,
Dirk
If "procedure" isn't synonymous with "process" in the phrase "documented procedure," then why is the word "documented" necessary?
Welcome to the Cove, Crainford :bigwave:
In line with the previous responses I suggest that you focus less on the minimum number of procedures and more on what the users of your system need.
As has been said there is a number of things you have to describe in a written procedure (Clause 4.2.1c)...
You are also required to have documents "needed by the organization to ensure the effective planning, operation and control of its processes" (Clause 4.2.1d).
Finally, there is my longtime favourite: Clause 4.2.1, note 2...
ISO9001:2000 said:
The extent of the quality management system documentation can differ from one organization to another due to
a) the size of organization and type of activities,
b) the complexity of processes and their interactions, and
c) the competence of personnel.
This note is important, imo: It allows you to build a reasonable system, adapted to the needs of your organization.
/Claes
V
vanputten
Hello Jim:
Thank you for helping me to see the light.
I agree. Within the phrase "documented procedure", the word "procedure" is synonymos with the word "process."
Thank you helping me understand.
Regards,
Dirk
Hello Jim:
Regards,
Dirk
No problem. The issue stems from the fact that the ISO writer(s) could have just said "documented process" to begin with, knowing that many people associate "procedure" with a document.
A Minimum Number of Documented Procedures for TS 16949 IATF 16949 - Automotive Quality Systems Standard 0
P ISO 9001:2000 - Required Procedures or minimum required number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A The Minimum Number of Internal Auditors Required in an Organization Internal Auditing 37
D What is the minimum number of values to develop individual chart? Statistical Analysis Tools, Techniques and SPC 14
K What is the Minimum number of internal auditors required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Marc Internal Audit Mandays - Is there a set, or minimum, number? Internal Auditing 4
D Minimum number of Subgroups to assess Process Capability Statistical Analysis Tools, Techniques and SPC 3
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
F Regulatory Compliant Quality Management System - Bare Minimum EU Medical Device Regulations 2
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
somashekar ISO 13485 plus ISO 9001:2015 will now attract a minimum 2 day upgrade audit ISO 13485:2016 - Medical Device Quality Management Systems 9
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
B What is the minimum sample required for Performance Evaluation for IVD ? EU Medical Device Regulations 3
D Minimum requirements/experience/qualifications to be head of quality Career and Occupation Discussions 6
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
S Minimum documents required by AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
J Minitab Sample Size Calculation: 1 Sample t vs Minimum Sample Size for Means Using Minitab Software 3
G Why for a Shewhart chart the minimum feasible value for APL is 2401 units? Statistical Analysis Tools, Techniques and SPC 8
A Minimum Testing Requirements for a Clear Protective Equipment Barrier (Class II 510K) Other US Medical Device Regulations 1
V Critical Characteristics - Capability for a Minimum Specification APQP and PPAP 11
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Minimum Organization Structure to support TS16949 IATF 16949 - Automotive Quality Systems Standard 5
Q Minimum content required in a Quality Manual as per ISO 9001:2008 Quality Management System (QMS) Manuals 6
A ISO 13485 Supplier Monitoring Minimum Requirements Supplier Quality Assurance and other Supplier Issues 3
