Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to?
H
hammadchmst
I am trying to make a factorial design with 3 factors;
Factor 1 - no. of variables 4
Factor 2 - no. of variables 3
Factor 3 - no. of variables 2
I am just new to Minitab. and not good at Stats.
Can anybody plz let me know - How to make factorial design with 3 factors (4x3x2)
Regards,
Hammad
Did you mean number of levels = 4, 3 & 2? If you did, you will need to use the General full factorial.
optomist1
A Sea of Statistics
Hi hammadchmst,
below is a Minitab how to article link on their website.....pretty detailed should work....this addresses Minitab 18....sometimes posting the underlying data set helps the cove to help.....hope this helps optomist1
Select a factorial design - Minitab
H
hammadchmst
I have 3 factor..
Factor 1 has 4 points (2.0, 1.0, 0.5, and 0.2)
Factor 2 has 3 points (0.5, 0.1, and 0)
Factor 3 has 2 points (5 and 30)
How to make the design?
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
A Interactions - Minitab Factorial Design Using Minitab Software 9
E Center Point Residuals on a Factorial Design using Minitab Quality Tools, Improvement and Analysis 3
B How to use Minitab to create this Fractional Factorial Design Matrix Using Minitab Software 2
T How create a Fractional Factorial Design with Minitab Using Minitab Software 3
D Analyze of Fractional Factorial Design in Minitab - I didn't get F and P- values Using Minitab Software 4
C Analyzing Full Factorial Design in Minitab Using Minitab Software 5
T Conduct a fractional factorial 2^13-5 experiment with Minitab Using Minitab Software 4
J Minitab Factorial Experiments - Excluding certain values Using Minitab Software 3
R Minitab Fractional Factorial Data Entry Help Using Minitab Software 5
I Excel based Gage R&R VS Minitab calculation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Select the 1 Supplier based on the Parts Durability from 6 Supplier Samples using Minitab Using Minitab Software 11
A One-factor and multiple-response Minitab optimization Using Minitab Software 0
O Problem in Minitab - ERROR * Factor Voltage is highly correlated with other terms Using Minitab Software 10
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
S Asterisk in DOE minitab software Using Minitab Software 23
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 7
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
